I'm following these instructions to install OS Spoofer on an Ubuntu virtual machine. Ubuntu is freshly installed, and I have not changed the "/etc/apt/sources.list" file
https://github.com/segofensiva/OSfooler-ng?tab=readme-ov-file
Here are the commands I've tried so far:
git clone https://github.com/segofensiva/OSfooler-ng.git
wget http://mirrors.kernel.org/ubuntu/pool/universe/n/nfqueue-bindings/python-nfqueue_0.5-1build2_amd64.deb
sudo dpkg -i python-nfqueue_0.5-1build2_amd64.deb
Reading database ... 200577 files and directories currently installed.) Preparing to unpack python-nfqueue_0.5-1build2_amd64.deb ... Unpacking python-nfqueue (0.5-1build2) ... dpkg: dependency problems prevent configuration of python-nfqueue: python-nfqueue depends on python (>= 2.7); however: Package python is not installed. python-nfqueue depends on python (<< 2.8); however:
Package python is not installed. python-nfqueue depends on libnetfilter-queue1; however: Package libnetfilter-queue1 is not installed. python-nfqueue depends on libpython2.7 (>= 2.7); however: Package libpython2.7 is not installed.dpkg: error processing package python-nfqueue (--install): dependency problems - leaving unconfigured Errors were encountered while processing: python-nfqueue
sudo apt --fix-broken install
sudo apt-get install libpython2.7 libnetfilter-queue1
Selecting previously unselected package python-nfqueue. (Reading database ... 201278 files and directories currently installed.) Preparing to unpack python-nfqueue_0.5-1build2_amd64.deb ... Unpacking python-nfqueue (0.5-1build2) ... dpkg: dependency problems prevent configuration of python-nfqueue:
python-nfqueue depends on python (>=2.7); however: Package python is not installed.
python-nfqueue depends on python (<< 2.8); however: Package python is not installed. dpkg: error processing package python-nfqueue (--install): dependency problems - leaving unconfigured Errors were encountered while processing: python-nfqueue
python2 --version
Command 'python2' not found, but can be installed with: sudo apt install python2
This simply results in the same error message as above.
I currently have installed:
Python 2.7.18
Python 3.10.12.
Please help me figure out how to fix this dependency.
Thank you.
EDIT:
I tried the following command, it gives me a new error message. I reverted my VM to a fresh install snapshot, and tried again, but same result:
sudo apt install ./python-nfqueue_0.5-1build2_amd64.deb
Reading package lists... Done Building dependency tree... Done Reading state information... Done Note, selecting 'python-nfqueue' instead of './python-nfqueue_0.5-1build2_amd64.deb' Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation:
The following packages have unmet dependencies: python-nfqueue : Depends: python (>= 2.7) but it is not installable Depends: python (< 2.8) but it is not installable E: Unable to correct problems, you have held broken packages.
