I was trying to do a apt-get update && apt-get upgrade on my Ubuntu and end up with the following error
$ sudo apt update
Get:1 file:/var/cudnn-local-tegra-repo-ubuntu2004-8.6.0.166 InRelease [1,575 B]
Hit:2 https://cli.github.com/packages stable InRelease
Get:3 https://repo.download.nvidia.com/jetson/common r35.4 InRelease [2,555 B]
Hit:4 https://download.docker.com/linux/ubuntu focal InRelease
Get:5 https://repo.download.nvidia.com/jetson/t234 r35.4 InRelease [2,547 B]
Hit:6 http://ports.ubuntu.com/ubuntu-ports focal InRelease
Get:7 http://ports.ubuntu.com/ubuntu-ports focal-updates InRelease [114 kB]
Hit:8 http://packages.ros.org/ros2/ubuntu focal InRelease
Hit:9 http://ports.ubuntu.com/ubuntu-ports focal-backports InRelease
Hit:10 http://ports.ubuntu.com/ubuntu-ports focal-security InRelease
Fetched 119 kB in 2s (64.5 kB/s)
Reading package lists... Done
Building dependency tree
1 package can be upgraded. Run 'apt list --upgradable' to see it.
The one package that can be upgraded was libc-bin.
$ apt list --upgradable
Listing... Done
libc-bin/focal-updates,focal-security 2.31-0ubuntu9.14 arm64 [upgradable from: 2.31-0ubuntu9.12]
N: There are 2 additional versions. Please use the '-a' switch to see them.
When trying to upgrade the result was as follow
$ sudo apt upgrade
Calculating upgrade... Done
Get more security updates through Ubuntu Pro with 'esm-apps' enabled:
libavformat58 libavfilter7 libpython3.9-minimal libswresample3
libpython3.9-stdlib libzmq5 iperf3 python2.7-minimal libpython2.7 python2.7
python3.9 libpostproc55 python3.9-minimal libavcodec58 libavutil56
libswscale5 libopenexr24 libsdl2-2.0-0 libmysofa1 libiperf0
libpython2.7-minimal libpython2.7-stdlib python3-scipy
Learn more about Ubuntu Pro at https://ubuntu.com/pro
The following packages will be upgraded:
libc-bin
1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
1 standard LTS security update
Need to get 0 B/501 kB of archives.
After this operation, 1,024 B of additional disk space will be used.
Do you want to continue? [Y/n] y
(Reading database ... 161696 files and directories currently installed.)
Preparing to unpack .../libc-bin_2.31-0ubuntu9.14_arm64.deb ...
Unpacking libc-bin (2.31-0ubuntu9.14) over (2.31-0ubuntu9.12) ...
dpkg: error processing archive /var/cache/apt/archives/libc-bin_2.31-0ubuntu9.14_arm64.deb (--unpack):
unable to stat './usr/lib/locale/C.UTF-8/LC_NUMERIC' (which I was about to install): Bad message
Ubuntu details :
$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 20.04.6 LTS
Release: 20.04
Codename: focal
What I tried ?
- Followed a similar issue fix available at here.
- Tried to
purgethe package and reinstall it. But, received a warning when trying to remove the package. - Tried force install
- Used
--fix-brokenflag withupdateandupgradecommand
