How Do I Verify Ubuntu 22.04 ISO Download
I'm having issues installing Ubuntu 22.04 iso on an old PC. So I'm checking all the steps. step 1 was to verify the iso file and I followed the steps suggested at https://ubuntu.com/tutorials/how-to-verify-ubuntu#1-overview The latter steps didn't seem to work. ie the command "gpg --keyid-format long --verify SHA256SUMS.gpg SHA256SUMS" produced the result: gpg: can't open signed data 'SHA256SUMS' gpg: can't hash datafile: No such file or directory
and also the command "sha256sum -c SHA256SUMS 2>&1 | grep OK" got no result. I interpreted this as a bad checksum so I downloaded the iso file again and followed the same procedure. But got the same result.
Think I'll just have to try the install again.
Following through the instructions that you are following, at Step 3 or page https://ubuntu.com/tutorials/how-to-verify-ubuntu#3-download-checksums-and-signatures you will see
However, if you didn’t, not to worry - the checksums and the signature are consistent for the image, so even if you downloaded your ISO file from a different source, as long as it is fresh and hasn’t been updated in the interim, you can fetch these files from the http://releases.ubuntu.com page for the relevant release.
From there you can download the SHA256SUMS and SHA256SUMS.gpg files. I have also conveniently added them here for you:
wget http://releases.ubuntu.com/jammy/SHA256SUMS
wget http://releases.ubuntu.com/jammy/SHA256SUMS.gpg
Now when you run the command of gpg --keyid-format long --verify SHA256SUMS.gpg SHA256SUMS you will probably get something like the following with the missing key:
$ gpg --keyid-format long --verify SHA256SUMS.gpg SHA256SUMS
gpg: Signature made Thu 10 Aug 2023 12:33:07 PM MDT
gpg:                using RSA key 843938DF228D22F7B3742BC0D94AA3F0EFE21092
gpg: Can't check signature: No public key
To import your key it is the command from gpg but remember to add 0x to the beginning of the key since it is in hexadecimal format.
gpg --keyid-format long --keyserver hkp://keyserver.ubuntu.com --recv-keys 0x843938DF228D22F7B3742BC0D94AA3F0EFE21092
Now your key check should pass:
gpg: BAD signature from "Ubuntu CD Image Automatic Signing Key (2012) <cdimage@ubuntu.com>" [unknown]
Now when you run the sha256sum command it should verify if your downloaded ISO is OK or not:
$ sha256sum -c SHA256SUMS 2>&1 | grep OK
ubuntu-22.04.3-desktop-amd64.iso: OK
Terrance
  • 43,712
