I try setup laravel app with docker container on my local kubuntu 22.04 and got error :
$ make init
Building containers
docker-compose build --no-cache
make: docker-compose: No such file or directory
make: *** [Makefile:13: build] Error 127
I suppose as not long time ago docker-compose has changed it's format I got this error :
master@master-at-home:/Project$ sudo apt install docker-compose
Reading package lists... Done
Building dependency tree... Done
python3-setuptools : Depends: python3-pkg-resources (= 59.6.0-1.2) but 59.6.0-1.2ubuntu0.22.04.1 is to be installed
Now in my system I have :
master@master-at-home:/Project$ uname -a
Linux master-at-home 6.2.0-35-generic #35~22.04.1-Ubuntu SMP PREEMPT_DYNAMIC Fri Oct 6 10:23:26 UTC 2 x86_64 x86_64 x86_64 GNU/Linux
master@master-at-home:/Project$ lsb_release -d; uname -r; uname -i
Description: Ubuntu 22.04.3 LTS
6.2.0-35-generic
x86_64
In docker-compose.yml of the project I found :
services:
laravel.test:
build:
context: ./docker/8.2
dockerfile: Dockerfile
No pointing to real version of docker in this docker-compose file, like I usually have in docker projects
version: '3.X'
Why I got error with python3-setuptools package and how have I to install docker-compose ?
Would it fix my problem ?
