BACKGROUND
  1. A new 1TB SSD was outfitted with 22.04 server.
  2. I think pvscan indicates the SSD physical space is 928.46GB:
    PV /dev/sda3 VG ubuntu-vg lvm2 [<928.46 GiB / <828.46 GiB free] Total: 1 [<928.46 GiB] / in use: 1 [<928.46 GiB] / in no VG: 0 [0 ]
  3. My limited understanding of the subject matter per Andy's post:
    • Physical Volume (PV) => The physical space on a drive.
    • Volume Group (VG) => An abstracted amount of drive space that can be split between multiple drives/devices.
    • Logical Volume (LV) => The space that ubuntu "sees"
ISSUE
df -h
returns:
I would think that the Available space should total to slightly less than 1TB.The screenshot indicates available space is 86GB. If the database grows and needs more than 86GB, do I have a problem and if yes, what needs to be done? I would like the database to be able to access / use the entire SSD if it needs it.
pvdisplay & vgdisplay return:
user@mysql:~$ sudo pvdisplay
  --- Physical volume ---
  PV Name               /dev/sda3
  VG Name               ubuntu-vg
  PV Size               928.46 GiB / not usable 4.00 MiB
  Allocatable           yes
  PE Size               4.00 MiB
  Total PE              237685
  Free PE               212085
  Allocated PE          25600
  PV UUID               jPdsbk-LYcP-uAPA-9yNP-vyJ2-hCQn-otcxpn
user@mysql:~$ sudo vgdisplay
  --- Volume group ---
  VG Name               ubuntu-vg
  System ID
  Format                lvm2
  Metadata Areas        1
  Metadata Sequence No  2
  VG Access             read/write
  VG Status             resizable
  MAX LV                0
  Cur LV                1
  Open LV               1
  Max PV                0
  Cur PV                1
  Act PV                1
  VG Size               <928.46 GiB
  PE Size               4.00 MiB
  Total PE              237685
  Alloc PE / Size       25600 / 100.00 GiB
  Free  PE / Size       212085 / <828.46 GiB
  VG UUID               YPWO13-whTj-QHxd-7G1a-xO7W-kSeJ-zuUVPp
QUESTION
I think I need help interpreting the information returned: will MySQL have access to the 900+GB to store data or does a procedure need to be performed to enable access to the 900+GB?
gatorback
  • 6,523
