When I used the exe file to install it it works on first start. Then when I restart it and boot from it, I get a purple screen then it flashes to the login screen what happend to the ubuntu logo?
to put it simply, the graphic driver loads slower than the rest of the system. I fixed it with these directions.
Get your precious Plymouth splash screen back
I didn't not follow the directions from this particular website, I couldn't find the one I used but these are the correct direction. I have mine back and can now remove the "quiet splash" and see the boot messages if needed.
Edit: while there is an detailed explanation of why you might want to check out, I and going to copy and paste the instructions below in case the link expires.
Open a virtual terminal and type the following command:
sudo gedit /etc/initramfs-tools/conf.d/splashThis file may not exist, so you may be creating it from scratch now.
Enter the following content on the file you opened on the previous step:
FRAMEBUFFER=yClose and save the file.
Now, run the following command to commit the change:
sudo update-initramfs -uReboot and enjoy your Plymouth splash screen.
- 7,157
