I've just moved from 20.04 to 22.04 and the screen shot behaviour has changed. Previously I could use [ctrl]+[shift]+[PrtScr] to turn the pointer into cross-hairs. I could then select an area which would be copied to the copy/paste buffer. It was super convenient.
Now that shortcut doesn't exist. I have to do [PrtScn] then drag the four corners of a selection frame around the screen to capture the desired area. It's a massive step back for usability. Is there any way to get the previous functionality back?
AlanG
It's not a setting. Gnome changed the built-in screenshot code. There's no going back to 20.04 behavior while running 22.04.
  • You can try a screenshot application with has different behavior.
  • You can reinstall Ubuntu 20.04.
user535733
  • 68,493
