####@flash:~/Documents/app_dev/test_one$ dart run jni:setup -p jni -s src/calculation
selecting source directories: [src/calculation, /home/####/.pub-cache/hosted/pub.dev/jni-0.7.2/src]
Target newer than source, skipping build.
+ [.dart_tool/jni/jni_native_build_JKXCIO] cmake /home/####/Documents/app_dev/test_one/src/calculation
-- The C compiler identification is GNU 11.4.0
-- Check for working C compiler: /usr/bin/cc
-- Check for working C compiler: /usr/bin/cc -- broken
-- Configuring incomplete, errors occurred!
See also "/home/####/Documents/app_dev/test_one/.dart_tool/jni/jni_native_build_JKXCIO/CMakeFiles/CMakeOutput.log".
See also "/home/####/Documents/app_dev/test_one/.dart_tool/jni/jni_native_build_JKXCIO/CMakeFiles/CMakeError.log".
CMake Error at /snap/flutter/141/usr/share/cmake-3.16/Modules/CMakeTestCCompiler.cmake:60 (message):
  The C compiler
    "/usr/bin/cc"
  is not able to compile a simple test program.
It fails with the following output:
Change Dir: /home/#####/Documents/app_dev/test_one/.dart_tool/jni/jni_native_build_JKXCIO/CMakeFiles/CMakeTmp
Run Build Command(s):/usr/bin/gmake cmTC_fcc09/fast && /usr/bin/gmake -f CMakeFiles/cmTC_fcc09.dir/build.make CMakeFiles/cmTC_fcc09.dir/build gmake[1]: Entering directory '/home/#####/Documents/app_dev/test_one/.dart_tool/jni/jni_native_build_JKXCIO/CMakeFiles/CMakeTmp' Building C object CMakeFiles/cmTC_fcc09.dir/testCCompiler.c.o /usr/bin/cc -o CMakeFiles/cmTC_fcc09.dir/testCCompiler.c.o -c /home/####/Documents/app_dev/test_one/.dart_tool/jni/jni_native_build_JKXCIO/CMakeFiles/CMakeTmp/testCCompiler.c Linking C executable cmTC_fcc09 /snap/flutter/141/usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_fcc09.dir/link.txt --verbose=1 /usr/bin/cc -B/snap/flutter/current/usr/lib/gcc/x86_64-linux-gnu/9 -B/snap/flutter/current/usr/lib/x86_64-linux-gnu -B/snap/flutter/current/lib/x86_64-linux-gnu -B/snap/flutter/current/usr/lib/ -L/snap/flutter/current/usr/lib/gcc/x86_64-linux-gnu/9 -L/snap/flutter/current/usr/lib/x86_64-linux-gnu -L/snap/flutter/current/lib/x86_64-linux-gnu -L/snap/flutter/current/usr/lib/ -lblkid -lgcrypt -llzma -llz4 -lgpg-error -luuid -lpthread -ldl -lepoxy -lfontconfig -B/snap/flutter/current/usr/lib/gcc/x86_64-linux-gnu/9 -B/snap/flutter/current/usr/lib/x86_64-linux-gnu -B/snap/flutter/current/lib/x86_64-linux-gnu -B/snap/flutter/current/usr/lib/ -L/snap/flutter/current/usr/lib/gcc/x86_64-linux-gnu/9 -L/snap/flutter/current/usr/lib/x86_64-linux-gnu -L/snap/flutter/current/lib/x86_64-linux-gnu -L/snap/flutter/current/usr/lib/ -lblkid -lgcrypt -llzma -llz4 -lgpg-error -luuid -lpthread -ldl -lepoxy -lfontconfig CMakeFiles/cmTC_fcc09.dir/testCCompiler.c.o -o cmTC_fcc09 /snap/flutter/current/usr/bin/ld: /usr/lib/gcc/x86_64-linux-gnu/11/liblto_plugin.so: error loading plugin: /snap/flutter/141/usr/bin/../../lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.33' not found (required by /usr/lib/gcc/x86_64-linux-gnu/11/liblto_plugin.so) collect2: error: ld returned 1 exit status gmake[1]: *** [CMakeFiles/cmTC_fcc09.dir/build.make:87: cmTC_fcc09] Error 1 gmake[1]: Leaving directory '/home/####/Documents/app_dev/test_one/.dart_tool/jni/jni_native_build_JKXCIO/CMakeFiles/CMakeTmp' gmake: *** [Makefile:121: cmTC_fcc09/fast] Error 2
CMake will not be able to correctly generate this project. Call Stack (most recent call first): CMakeLists.txt:8 (project)
Command exited with status code 1
  • [.dart_tool/jni/jni_native_build_JKXCIO] cmake --build .
gmake: *** No targets specified and no makefile found. Stop.
Command exited with status code 2
  • [.dart_tool/jni/jni_native_build_KGJRRZ] cmake /home/#####/.pub-cache/hosted/pub.dev/jni-0.7.2/src
-- The C compiler identification is GNU 11.4.0 -- Check for working C compiler: /usr/bin/cc -- Check for working C compiler: /usr/bin/cc -- broken -- Configuring incomplete, errors occurred! See also "/home/####/Documents/app_dev/test_one/.dart_tool/jni/jni_native_build_KGJRRZ/CMakeFiles/CMakeOutput.log". See also "/home/#####/Documents/app_dev/test_one/.dart_tool/jni/jni_native_build_KGJRRZ/CMakeFiles/CMakeError.log".
CMake Error at /snap/flutter/141/usr/share/cmake-3.16/Modules/CMakeTestCCompiler.cmake:60 (message): The C compiler
"/usr/bin/cc"
Change Dir: /home/####/Documents/app_dev/test_one/.dart_tool/jni/jni_native_build_KGJRRZ/CMakeFiles/CMakeTmp
Run Build Command(s):/usr/bin/gmake cmTC_c70af/fast && /usr/bin/gmake -f CMakeFiles/cmTC_c70af.dir/build.make CMakeFiles/cmTC_c70af.dir/build
gmake[1]: Entering directory '/home/#####/Documents/app_dev/test_one/.dart_tool/jni/jni_native_build_KGJRRZ/CMakeFiles/CMakeTmp'
Building C object CMakeFiles/cmTC_c70af.dir/testCCompiler.c.o
/usr/bin/cc    -o CMakeFiles/cmTC_c70af.dir/testCCompiler.c.o   -c /home/#####/Documents/app_dev/test_one/.dart_tool/jni/jni_native_build_KGJRRZ/CMakeFiles/CMakeTmp/testCCompiler.c
Linking C executable cmTC_c70af
/snap/flutter/141/usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_c70af.dir/link.txt --verbose=1
/usr/bin/cc    -B/snap/flutter/current/usr/lib/gcc/x86_64-linux-gnu/9 -B/snap/flutter/current/usr/lib/x86_64-linux-gnu -B/snap/flutter/current/lib/x86_64-linux-gnu -B/snap/flutter/current/usr/lib/ -L/snap/flutter/current/usr/lib/gcc/x86_64-linux-gnu/9 -L/snap/flutter/current/usr/lib/x86_64-linux-gnu -L/snap/flutter/current/lib/x86_64-linux-gnu -L/snap/flutter/current/usr/lib/ -lblkid -lgcrypt -llzma -llz4 -lgpg-error -luuid -lpthread -ldl -lepoxy -lfontconfig -B/snap/flutter/current/usr/lib/gcc/x86_64-linux-gnu/9 -B/snap/flutter/current/usr/lib/x86_64-linux-gnu -B/snap/flutter/current/lib/x86_64-linux-gnu -B/snap/flutter/current/usr/lib/ -L/snap/flutter/current/usr/lib/gcc/x86_64-linux-gnu/9 -L/snap/flutter/current/usr/lib/x86_64-linux-gnu -L/snap/flutter/current/lib/x86_64-linux-gnu -L/snap/flutter/current/usr/lib/ -lblkid -lgcrypt -llzma -llz4 -lgpg-error -luuid -lpthread -ldl -lepoxy -lfontconfig  CMakeFiles/cmTC_c70af.dir/testCCompiler.c.o  -o cmTC_c70af
gmake[1]: *** [CMakeFiles/cmTC_c70af.dir/build.make:87: cmTC_c70af] Error 1
gmake[1]: Leaving directory '/home/####/Documents/app_dev/test_one/.dart_tool/jni/jni_native_build_KGJRRZ/CMakeFiles/CMakeTmp'
gmake: *** [Makefile:121: cmTC_c70af/fast] Error 2
  • [.dart_tool/jni/jni_native_build_KGJRRZ] cmake --build .
