I've downloaded:
cnijfilter-ip100series-3.70-1-deb.tar.gz
cnijfilter-ip100series-3.70-1-rpm.tar.gz
cnijfilter-source-3.70-1.tar.gz
I tried following the installation instructions from Canon, but it failed. I continued to try answers given in ask Ubuntu where the only one that actually started driver installations is: ./install.sh
Unfortunately I'm stuck with several errors according to below.
./install.sh
[sudo] password for thomas:
Canon Inkjet Printer Driver
Version 3.70
Copyright CANON INC. 2001-2012
All Rights Reserved.
Command executed = sudo dpkg -iG ./packages/cnijfilter-common_3.70-1_amd64.deb
Selecting previously unselected package cnijfilter-common.
(Reading database ... 204048 files and directories currently installed.)
Preparing to unpack .../cnijfilter-common_3.70-1_amd64.deb ...
Unpacking cnijfilter-common (3.70-1) ...
Setting up cnijfilter-common (3.70-1) ...
Processing triggers for libc-bin (2.35-0ubuntu3.5) ...
Command executed = sudo dpkg -iG ./packages/cnijfilter-ip100series_3.70-1_amd64.deb
Selecting previously unselected package cnijfilter-ip100series.
(Reading database ... 204065 files and directories currently installed.)
Preparing to unpack .../cnijfilter-ip100series_3.70-1_amd64.deb ...
Unpacking cnijfilter-ip100series (3.70-1) ...
dpkg: dependency problems prevent configuration of cnijfilter-ip100series:
cnijfilter-ip100series depends on libpango1.0-0 (>= 1.12.3); however:
Package libpango1.0-0 is not installed.
cnijfilter-ip100series depends on libpng12-0 (>= 1.2.8rel); however:
Package libpng12-0 is not installed.
cnijfilter-ip100series depends on libtiff4; however:
Package libtiff4 is not installed.
dpkg: error processing package cnijfilter-ip100series (--install):
dependency problems - leaving unconfigured
Command executed = sudo dpkg -P cnijfilter-ip100series
(Reading database ... 204273 files and directories currently installed.)
Removing cnijfilter-ip100series (3.70-1) ...
Purging configuration files for cnijfilter-ip100series (3.70-1) ...
Command executed = sudo dpkg -P cnijfilter-common
Removing cnijfilter-common (3.70-1) ...
Purging configuration files for cnijfilter-common (3.70-1) ...
