I am running out of space on my main SSD. I just realized that Dropbox and Megasync are mounted and syncing on sda2 which is on this drive (which accounts for most of space), although I thought I'd mounted them on sdb1 which is on a much larger HDD.
I have 3 questions:
  1. Is there a way I can easily remount them on sdb1 from the terminal or will I have to reinstall?
  2. Is it actually possible to sync from a directory that is not mounted on root?
  3. Can I mount the whole /home directory on /dev/sdb so all files are there and the SSD is kept free for processing?
System info:
  • Operating System: Ubuntu Studio 22.04
  • KDE Plasma Version: 5.24.7
  • KDE Frameworks Version: 5.92.0
  • Qt Version: 5.15.3
  • Kernel Version: 6.2.0-1017-lowlatency (64-bit)
  • Graphics Platform: X11
  • Processors: 12 × Intel Xeon CPU E5-1650 v3 @ 3.50GHz
  • Memory: 31.3 GB RAM
  • Graphics Processor: Quadro K2200/PCIe/SSE2
SMBIOS 2.8 present.
Handle 0x0001, DMI type 1, 27 bytes
System Information
        Manufacturer: Hewlett-Packard
        Product Name: HP Z440 Workstation
        Version: Not Specified
        Serial Number: CZC615BPGD
        UUID: 8ec24007-035d-11e6-9c43-bc00000c0000
        Wake-up Type: Power Switch
        SKU Number: F5W13AV
        Family: 103C_53335X G=D
Handle 0x0006, DMI type 32, 11 bytes System Boot Information Status: No errors detected
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS loop0 7:0 0 55.7M 1 loop /snap/core18/2796 loop1 7:1 0 55.7M 1 loop /snap/core18/2812 loop2 7:2 0 4K 1 loop /snap/bare/5 loop3 7:3 0 63.4M 1 loop /snap/core20/1974 loop4 7:4 0 63.5M 1 loop /snap/core20/2015 loop5 7:5 0 73.9M 1 loop /snap/core22/864 loop6 7:6 0 6.4M 1 loop /snap/curl/1754 loop7 7:7 0 240.3M 1 loop /snap/firefox/3358 loop8 7:8 0 245.6M 1 loop /snap/firefox/3416 loop9 7:9 0 164.8M 1 loop /snap/gnome-3-28-1804/198 loop10 7:10 0 349.7M 1 loop /snap/gnome-3-38-2004/143 loop11 7:11 0 497M 1 loop /snap/gnome-42-2204/141 loop12 7:12 0 91.7M 1 loop /snap/gtk-common-themes/1535 loop13 7:13 0 130.8M 1 loop /snap/heroic/265 loop14 7:14 0 130.8M 1 loop /snap/heroic/290 loop15 7:15 0 40.8M 1 loop /snap/snapd/20092 loop16 7:16 0 40.9M 1 loop /snap/snapd/20290 loop17 7:17 0 74.1M 1 loop /snap/core22/1033 sda 8:0 1 238.5G 0 disk ├─sda1 8:1 1 300M 0 part /boot/efi └─sda2 8:2 1 238.2G 0 part /var/snap/firefox/common/host-hunspell / sdb 8:16 1 1.8T 0 disk └─sdb1 8:17 1 1.8T 0 part /media/jamesm/Graceland sr0 11:0 1 1024M 0 rom
karel
  • 122,292
  • 133
  • 301
  • 332
By default, the locations where these cloud sync applications store the data are determined by the application. for example, Dropbox by default creates a ~/Dropbox directory to store the synced data. Whether and how you can change the locations where these tools store the data depends on the tool, and can be found from either their documentation or dedicated support forums.
Again, this merely depend on what these tools allow you to do.
Yes, you can, but that has wider implications than controlling where these tools sync data.
If you cannot change the location where these tools look for their data, then you can have them look on a different location either by using symbolic links (by far easiest, but I am not sure if that will work with either of these tools, or by redirecting to the different location using a bound --bind (somewhat more complicated to set this up, but guaranteed to work with each of these tools).
I recommend you start testing if a simple symbolic link works. Stop the Dropbox daemon. Move e.g. the "Dropbox" directory to a new drive. Then, create a symbolic link in the original location with the name "Dropbox" and restart the daemon. Check if that works.
If that does not work, a bound --bind surely will work. The --bind option allows to mount one directory on another. Thus again, move e.g. the "Dropbox" folder to the new location, leave an empty "Dropbox" folder in the original location, and then mount the moved Dropbox folder on the empty folder in the original location. To automate that process, you can add a line that sets up the mount in /etc/fstab.
vanadium
  • 97,564
