My laptop recently couldn't enter GUI mode and could only enter CLI mode. I've looked for a solution on the internet but most people suggest doing:
sudo apt-get --reinstall ubuntu-desktop
Unfortunately, I accidentally deleted the network-manager so now my laptop can't connect to the internet.
How to return Ubuntu to GUI mode after deleting network-manager?
I am assuming you are using the LTS 22.04 version of Ubuntu.
Network Manager is not required to connect to the internet. Assuming you have a DHCP server on your network, and you have the phyiscal connection/Wifi connected. Then in a shell as root or using sudo run:
ip -br a                     ##I find using -br is easier to read, specially if you have a lot of interfaces
Identify the name of the interface you using, eg eno1, enps0f3, eth0. Also confirm the interface is up. If it is up, skip to the next dot point, if it is not run:
ip link set <int name> up
If the interface was down, and you have bought it up, check if it has an ip address now. Often the interface will be setup to request an IP from the dhcp server when it is bought up.
  • Check connectivity
If you have an IP address it now has an ip address, and is up, try and "ping 8.8.8.8" if you can, then you now have internet, almost, maybe.
The internet uses DNS to link domain names to IP addresses, to check if DNS is setup correctly, ping google.com (or any domain you know). If the address is converted to an IP, then your are good to go. Now you can reinstall NetworkManager (if you want) and Ubuntu Desktop.
  • Fixing DNS
To fix dns, we first want to check the current status of resolv.conf. run:
ls -la /etc/resolv.conf
resolv.conf may be a ASCII file, or a symbolic link to another file. eg: ../run/resolvconf/resolv.conf or /run/systemd/resolve/stub-resolv.conf
If it is a link to another file, confirm that file exists. having a broken link is a common problem that can break dns. If the link is broken, you can either create the file where the link points to, or remove the link, and recreate the resolv.conf file (see below for how ot recreate the file)
If the link is correct, or /etc/resolv.conf is a file. run cat:
cat /etc/resolv.conf
THe output will be something like:
nameserver 127.0.0.53
options edns0 trust-ad
search somelocal.domain
or
nameserver 10.10.10.10
If you have 127.0.0.53 or another 127.x.x.x address then your system is using a local service that proxies your dns requests. As you are wanting to install NetworkManager, that will take over dns once fixed, the quickest fix is to tempory override the settings, and let NetworkManager do its black magic to the dns.
  • Create / Update server resolv.conf is using.
The quickest way to fix dns is by overriding the file/creating resolv.conf by running:
echo nameserver 8.8.8.8 > /etc/resolv.conf      **or the location the symbolic link points to, if you had a broken link.
this command sets your system to use the google name server that we confirmed in step one, we could reach this should get you online, and then you can install fix what you need.
  • Fixing the GUI without reinstalling - maybe
When Ubuntu boots, it will either load the graphical interface by using a display manager, there is a few of them out there, use the one you like. xfwm, part of xfce4 is my prefered.
to confirm what is the current setting run:
systemctl get-default
if the output is graphical.target, then your system is setup to load the GUI, normally on tty7. If it shows multi-user.target, then you are set to boot to console, normally tty1.
to change run
systemctl set-default graphical.target    ** or multi-user.target if that is your prefered.
This may fix the issue that you are haivng with the GUI. Also note, you can often start the GUI, unles sit is broken, by running startx on the console, or via a ssh client that has been setup either with ssh-X-Forwarding or a remote X11 server. Once your GUI has loaded, you may be able to the fix the problem you have within the GUI.
Luke Attard
  • 1,065
