The display brightness adjustment while using Ubuntu 20.04 on my Thinkpad T14s (AMD CPU + iGPU) does not work.
Specifically, the brightness slider in the settings does not change the brightness of the screen, and the brightness keys similarly does nothing (a popup with the brightness symbol and the currently level appears, though this does not change the actual screen brightness).
What I've tried so far:
Editing the GRUB_CMDLINE_LINUX_DEFAULT line in /etc/default/grub to GRUB_CMDLINE_LINUX_DEFAULT="quiet splash acpi_backlight=vendor acpi_osi=linux" (as outl2ined in this answer)
Editing the GRUB_CMDLINE_LINUX_DEFAULT line in /etc/default/grub to GRUB_CMDLINE_LINUX_DEFAULT="quiet splash pcie_aspm=force acpi_backlight=native" (as outlined in this answer)
Updating all the drivers through:
sudo apt update
sudo apt upgrade
sudo ubuntu-drivers autoinstall
and updating using the Software Updater app
I've also tried writing to the brightness file with: echo 5 | sudo tee /sys/class/backlight/acpi_video0/brightness
Output of sudo lshw -c video:
*-display UNCLAIMED
description: VGA compatible controller
product: Advanced Micro Devices, Inc. [AMD/ATI]
vendor: Advanced Micro Devices, Inc. [AMD/ATI]
physical id: 0
bus info: pci@0000:c3:00.0
version: dd
width: 64 bits
clock: 33MHz
capabilities: pm pciexpress msi msix vga_controller bus_master cap_list
configuration: latency=0
resources: iomemory:2c0-2bf memory:2c00000000-2c0fffffff memory:90000000-901fffff ioport:1000(size=256) memory:90500000-9057ffff
Output of xrandr:
xrandr: Failed to get size of gamma for output default
Screen 0: minimum 1920 x 1200, current 1920 x 1200, maximum 1920 x 1200
default connected primary 1920x1200+0+0 0mm x 0mm
1920x1200 77.00*
