I mistakenly clicked install audio packages in Ubuntu Studio Installer, and even after cancelling, my apps menu is cluttered with a whole lot of junk apps.
Where can I find the full audio package list to delete them all please?
sudo apt update
sudo apt purge ubuntustudio-audio ubuntustudio-audio-core
sudo apt autoremove
This should uninstall the [meta]packages and autoremove should uninstall the dependencies that were automatically installed by the system.
So the following command will search for packages by the keyword "ubuntustudio" and filter the results to only list results that contain the word "audio":
apt-cache search ubuntustudio | grep -i audio
On 20.04, this returns 3 packages. ubuntustudio-audio, ubuntustudio-audio-core, and ubuntustudio-audio-plugins.
I left out the ubuntustudio-audio-plugins as they may be helpful although it will probably be removed as a dependency anyhow but in any case and if you still have packages remaining that you don't want, you can try to explicitly purge that as well:
sudo apt purge ubuntustudio-audio-plugins
sudo apt autoremove
The following commands will list the packages that these 3 packages depend on (the packages that are automatically installed):
apt-cache show ubuntustudio-audio | grep -i depends
apt-cache show ubuntustudio-audio-core | grep -i depends
apt-cache show ubuntustudio-audio-plugins | grep -i depends
The apt-cache show command lists detailed information about a package and here we filter only the line for dependencies, "depends".
