Recently the suspend-to-hibernate function stopped working reliably. It happens that my battery is drained, although it should have went into hibernation.
This is what
journalctl | grep suspend
shows:
Nov 26 05:09:15 XYZ kernel: PM: suspend entry (s2idle)
Nov 26 05:09:15 XYZ kernel: PM: suspend exit
Nov 26 05:09:15 XYZ systemd[1]: systemd-suspend-then-hibernate.service: Main process exited, code=exited, status=1/FAILURE
Nov 26 05:09:15 XYZ systemd[1]: systemd-suspend-then-hibernate.service: Failed with result 'exit-code'.
Nov 26 05:09:15 XYZ systemd[1]: suspend-then-hibernate.target: Job suspend-then-hibernate.target/start failed with result 'dependency'.
Nov 26 05:09:15 XYZ systemd[1]: systemd-suspend-then-hibernate.service: Consumed 2.151s CPU time.
Nov 26 05:09:15 XYZ ModemManager[1057]: <info> [sleep-monitor-systemd] system is about to suspend
Nov 26 05:09:15 XYZ systemd-sleep[137140]: Entering sleep state 'suspend'...
Nov 26 05:09:15 XYZ kernel: PM: suspend entry (deep)
Nov 26 05:09:35 XYZ kernel: PM: suspend exit
Nov 26 05:09:35 XYZ kernel: PM: suspend entry (s2idle)
And this just happened in a cycle, until the battery was drained. So my understanding is, somehow there is a dependency, that prevents it from hibernation?
Performing suspend or hibernate via terminal works fine:
systemctl suspend
Nov 26 16:39:11 XYZ ModemManager[933]: <info> [sleep-monitor-systemd] system is about to suspend
Nov 26 16:39:14 XYZ systemd-sleep[19184]: Entering sleep state 'suspend'...
Nov 26 16:39:14 XYZ kernel: PM: suspend entry (deep)
Nov 26 16:39:27 XYZ kernel: printk: Suspending console(s) (use no_console_suspend to debug)
Nov 26 16:39:27 XYZ kernel: PM: suspend exit
Nov 26 16:39:27 XYZ systemd[1]: systemd-suspend.service: Deactivated successfully.
Nov 26 17:21:10 XYZ ModemManager[933]: <info> [sleep-monitor-systemd] system is about to suspend
Nov 26 17:22:31 XYZ kernel: printk: Suspending console(s) (use no_console_suspend to debug)
Any ideas?
Update:
Seems I cut off the journalctl content at the wrong place. I did now the following:
- perform sudo systemctl suspend, then save journalctl
- perform sudo hibernate, then save journalctl
- perform sudo suspend-then-hibernate, then save journalctl
- close the lid (which should trigger suspend-then-hibernate), then save journalctl
This showed that #1-3 are working fine, while #4 fails. Here the relevant log part for #3:
Dez 12 20:52:05 XYZ systemd[1]: Starting Record successful boot for GRUB...
Dez 12 20:52:05 XYZ systemd[1]: Starting Suspend; Hibernate if not used for a period of time...
Dez 12 20:52:05 XYZ systemd-sleep[8780]: Entering sleep state 'suspend'...
Dez 12 20:52:05 XYZ kernel: PM: suspend entry (deep)
Dez 12 20:52:26 XYZ kernel: Filesystems sync: 0.006 seconds
Dez 12 20:52:26 XYZ kernel: Freezing user space processes
Dez 12 20:52:26 XYZ kernel: Freezing user space processes completed (elapsed 0.004 seconds)
Dez 12 20:52:26 XYZ kernel: OOM killer disabled.
Dez 12 20:52:26 XYZ kernel: Freezing remaining freezable tasks
Dez 12 20:52:26 XYZ kernel: Freezing remaining freezable tasks completed (elapsed 0.001 seconds)
and for #4:
Dez 12 21:19:10 XYZ systemd[1]: Starting Record successful boot for GRUB...
Dez 12 21:19:10 XYZ systemd[1]: Starting Suspend; Hibernate if not used for a period of time...
Dez 12 21:19:10 XYZ systemd-sleep[19771]: Entering sleep state 'suspend'...
Dez 12 21:19:10 XYZ kernel: PM: suspend entry (deep)
Dez 12 21:19:10 XYZ kernel: Filesystems sync: 0.033 seconds
Dez 12 21:19:30 XYZ kernel: Freezing user space processes
Dez 12 21:19:30 XYZ kernel: Freezing user space processes failed after 20.007 seconds (1 tasks refusing to freeze, wq_busy=0):
Dez 12 21:19:30 XYZ kernel: task:modprobe state:D stack:0 pid:19662 ppid:1948 flags:0x00004006
Dez 12 21:19:30 XYZ kernel: Call Trace:
And this behaviour just repeats itself, until the battery is drained. Searching for modprobe did not give any clarity to this. Any ideas?
Update 2:
Think I've found the issue.. I often have to restart pulseaudio (via pulseaudio -k && sudo alsa force-reload, from here), due to audio issues and seems this procedure is running in the background and blocking it then facepalm. A fast check of lid-closing with successful trigger of suspend-then-hibernate after a fresh restart confirmed this for now.
