I need to set up dual screen. I've tried countless of ways but failed. Right now, I have re-installed x server so everything is at it's default. How do I switch to dual monitor with one being portrait (and left of) the other, the main screen?
Asked
Active
Viewed 1,021 times
I would recommend using Nvidia-Xserver-settings for that if you have an Nvidia card (guess so from post title).
- Go to X server display configuration.
- Click on detect displays and click on your extra monitor.
- In configuration select Twinview.
- Choose resolution and position, left of, right of, etc...
- Apply changes...and voila, it should work.
If you want to automate the process you can also consider using Disper it was my life saver for everyday use of dual monitors.
leousa
- 984
