I have two similar laptops, both thinkpad P series. I will outline their specs:
New Laptop:
Old Laptop:
By all of the specs, the new laptop should be sigificantly faster, and this is what most benchmarks show (sysbench cpu shows ~40% increase in new laptop, gcc compilation time is ~900 sec vs ~1300, Disk IO are within a few hundred kB/s over 150GB test, although old was technically faster).
The exception that's really killing me though is building petalinux (yocto/bitbake) projects. Starting with the same projects, the build times are (new - old), 40min - 10min, 60min - 20min for two different projects I work on frequently. I am not sure what is causing this slowdown though and I have tried a number of things:
Monitoring processes shows both systems have all CPUs pinned during most of the build, I tried limiting threads so that the 'efficiency cores' would not come into play in case they were somehow causing issues, but that only slowed things down. The new machine also doesnt seem to be spending resources in a significantly different way (as far as kernel vs user utilization shown in htop). Also tried the answers here with no success. I looked through the output of perf on the new machine but without knowing more what I'm looking for, that hasnt been helpful so I haven't run it on the old machine to compare, thats on the list.
Some main things I could use some help explaining/advice how to test: I notice that the new machine never seems to break 3.2GHz as reported by /proc/cpuinfo CPU MHz (assuming that's accurate) while the old machine seems to spend most of its time around 3.8-4 on all cores during the build. This is very confusing to me looking at the CPU specs. I also notice that the fans on the new laptop seem to be incredibly aggressive compared to the old one, I wonder if I am being heavily throttled? Temperatures reported by both seem a bit useless; Individual core temps vary by up to ~25 C on both machines, with some cores hitting the 'critical' temp of 100C while others hovered in the 80s. Overall CPU temp was more stable but equally high in both machines.
I need to look into this more but the first answer I saw in regards to determining that was to check CPU MHz value. Obviously I am not getting the advertised max speed, but I am unsure where to start looking into why.
I am starting to suspect after writing and reading all that, that my performance cores are being throttled as if they are efficiency cores
Update 1:
After viewing this answer, I checked the scaling_governor for my first CPU, and noticed it was in powersave despite the GUI settings being in performance mode. I set them all to performance and was happy to see my performance cores jump to 4+ GHz and complete a part of the build process quicker than before. Sadly, it has since returned to mostly 3.3-3.8 and the build is once again taking far longer.
Douglas B
  • 169
