I can't connect the original Xbox 360 controller to my PC with a cable. I'm trying to follow this tutorial: https://askubuntu.com/a/1438948 First, i installed xboxdrv with
sudo apt-add-repository ppa:rael-gc/ubuntu-xboxdrv
sudo apt-get update
sudo apt-get install ubuntu-xboxdrv
Then i added xpad to a blacklist by editing the /etc/modprobe.d/blacklist.conf
Then i unload the module withsudo rmmod xpad
Then i remove jstest-gtk and reinstall it with
sudo apt-get purge jstest-gtk
sudo apt-get install xboxdrv
sudo apt-get install jstest-gtk
And made a file /etc/default/xboxdrv with following text in:
[xboxdrv]
silent = true
controller 1
trigger-as-button = true
dpad-as-button = true
deadzone = 4000
controller 2
next-controller = true
deadzone = 4000
controller 3
deadzone = 4000
controller 4
deadzone = 4000
[xboxdrv-daemon]
dbus = disabled
However, when I run sudo xboxdrv, I get the following output:
xboxdrv 0.8.8 - http://pingus.seul.org/~grumbel/xboxdrv/ Copyright © 2008-2011 Ingo Ruhnke grumbel@gmail.com Licensed under GNU GPL version 3 or later http://gnu.org/licenses/gpl.html This program comes with ABSOLUTELY NO WARRANTY. This is free software, and you are welcome to redistribute it under certain conditions; see the file COPYING for details.
-- [ ERROR ] ------------------------------------------------------ No Xbox or Xbox360 controller found
Then I tried to follow this tutorial: https://steamcommunity.com/app/221410/discussions/0/558748653738497361/?l=french&ctp=6
And when I run evtest /dev/input/eventxx (i've tried all events from 0 to 16 with controller plugged in), nothing happens.
The lsusb command gives me this output:
Bus 003 Device 017: ID 045e:028f Microsoft Corp. Xbox360 Wireless Controller
