I followed this answer: https://askubuntu.com/a/162230
I edit limits.conf, now it is
* soft nofile 65536
* hard nofile 65536
* soft nproc  65536
* hard nproc  Unlimited
root soft nofile 65536
root hard nofile 65536
Also, I edit both "/etc/pam.d/common-session" and "/etc/pam.d/common-session-noninteractive". Add the line at the end of both files:
session required pam_limits.so
And I restarted the Ubuntu, but "prlimit" still shows
NOFILE  ... 1024  65536 files
ulimit -n also shows 1024
How could I change this permanently?
Ryan
  • 33
The easiest way to change this is to put ulimit -S -n 65536 in your shell init file (.bashrc possibly).
user10489
  • 5,533
I think this is a bug.
I also cannot change these values, even if I specify to systemd LimitNOFILE as a user setting or as a system setting, dependant services crash because of nofile limits being 1024 irrespective of the settings in limits...
To work around it, I forced the limit as root user to 65535 using ulimit... It needs to be applied each boot.
I followed the below instructions to permanently set ulimit -n which controls the number of open files in ubuntu:
set ulimit
# available limit
user@ubuntu:~$ ulimit -n
1024
To increase the available limit to say 65535
user@ubuntu:~$ sudo vim /etc/sysctl.conf
add the following line to it
fs.file-max = 65535
sudo vim /etc/security/limits.conf
add following lines to it
  • soft nproc 65535
  • hard nproc 65535
  • soft nofile 65535
  • hard nofile 65535
root soft nproc 65535
root hard nproc 65535
root soft nofile 65535
root hard nofile 65535
edit the following file
user@ubuntu:~$ sudo vim /etc/pam.d/common-session
add this line to it
run this to refresh with new config
user@ubuntu:~$ sudo sysctl -p
logout and login and try the following command
user@ubuntu:~$ ulimit -n 65535
It is important to increase the limit, i.e. the max value 65536.
But I also needed these steps:
For me it helped to adjust the /etc/systemd/system.conf and the /etc/systemd/user.conf.
[Manager] DefaultLimitNOFILE=65536
After that, just reload with
sudo systemctl daemon-reexec
then it worked. Maybe this will help someone.
