Once I upgraded from Ubuntu 23.04 to 23.10 and I Can't boot to it anymore!
Gave up waiting for root device. Common problems:
 - Boot args (cat /proc/cmdline)
   - Check rootdelay= (did the system wait long enough?)
   - Check root= (did the system wait for the right device?)
 - Missing modules (cat /proc/modules; ls /dev)
ALERT! UUID=c0fc479f-b1cc-4e85-962b-43a72eec9e91 does not exist. Dropping to a shell!
BusyBox v1.36.1 (Ubuntu 1:1.36.1-3ubuntu1) built-in shell (ash) Enter 'help' for a lost of built-in commands. (initramfs)
I maked sure that in the BIOS settings the Sata opration in the system configration is AHCI not RAID
I am currently running ubunut on live usb. I changed the UUID in the /etc/fstab file to 'dev/sdb5'. and update-grub and reboot but nothing changed!
/etc/fstab:
GNU nano 7.2                       /etc/fstab
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point>   <type>  <options>       <dump>  <pass>
# / was on /dev/sdb5 during curtin installation
# /dev/disk/by-uuid/c0fc479f-b1cc-4e85-962b-43a72eec9e91 / ext4 defaults 0 1
# /boot/efi was on /dev/sdb1 during curtin installation
#/ dev/disk/by-uuid/1292-A439 /boot/efi vfat defaults 0 1
# UUID=c0fc479f-b1cc-4e85-962b-43a72eec9e91 / ext4 defaults 0 1
/dev/sdb5 / ext4 errors=remount-ro 0 1 /swapfile swap swap defaults 0 0 /swap.img none swap sw 0 0 LABEL=Omar /mnt/Omar auto nosuid,nodev,nofail,x-gvfs-show 0 0 /dev/sdc4 /mnt/sdc4 auto nosuid,nodev,nofail,x-gvfs-show 0 0
blkid
/dev/sdb5: UUID="c0fc479f-b1cc-4e85-962b-43a72eec9e91" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="a2f6a2d2-f40f-cd41-b4a7-61b12759b403"
/dev/loop1: BLOCK_SIZE="131072" TYPE="squashfs"
/dev/sdd2: SEC_TYPE="msdos" LABEL_FATBOOT="ESP" LABEL="ESP" UUID="6F54-CACE" BLOCK_SIZE="512" TYPE="vfat" PARTLABEL="Appended2" PARTUUID="2a585014-a55f-4771-aef0-695c6f9e0059"
/dev/sdd1: BLOCK_SIZE="2048" UUID="2023-10-16-11-29-57-00" LABEL="Ubuntu 23.10.1 amd64" TYPE="iso9660" PARTLABEL="ISO9660" PARTUUID="2a585014-a55f-4771-aef3-695c6f9e0059"
/dev/sdd4: LABEL="writable" UUID="10e8c979-c7d9-4177-8fc4-d35e6e07519e" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="ab5ae46b-1d76-4bc4-89aa-bfdce9a78047"
/dev/loop8: BLOCK_SIZE="131072" TYPE="squashfs"
/dev/sdb4: BLOCK_SIZE="512" UUID="01D9D8E852906F70" TYPE="ntfs" PARTUUID="4be8ef1d-c5da-4121-b27e-7d2b3503538b"
/dev/sdb3: BLOCK_SIZE="512" UUID="01D9D8E850480610" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="64b110ca-af78-4621-80d3-4f19c7181db2"
/dev/sdb1: UUID="1292-A439" BLOCK_SIZE="512" TYPE="vfat" PARTLABEL="EFI System Partition" PARTUUID="684257cf-73a2-482d-a9e1-11ce37103972"
/dev/loop6: BLOCK_SIZE="131072" TYPE="squashfs"
/dev/loop4: BLOCK_SIZE="131072" TYPE="squashfs"
/dev/loop11: BLOCK_SIZE="131072" TYPE="squashfs"
/dev/loop2: BLOCK_SIZE="131072" TYPE="squashfs"
/dev/loop0: BLOCK_SIZE="131072" TYPE="squashfs"
/dev/loop9: BLOCK_SIZE="131072" TYPE="squashfs"
/dev/sdc1: BLOCK_SIZE="512" UUID="01D9E9BD38CA67E0" TYPE="ntfs" PARTUUID="209e706a-01"
/dev/loop7: BLOCK_SIZE="131072" TYPE="squashfs"
/dev/sda2: UUID="C5B4-CDD0" BLOCK_SIZE="512" TYPE="vfat" PARTLABEL="Basic data partition" PARTUUID="000fa007-bb10-5095-3efd-db2d0e401f00"
/dev/sda1: LABEL="Omar" BLOCK_SIZE="512" UUID="01DA00F083D02BE0" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="f64af970-d8e4-01d9-b878-257b72ecec00"
/dev/loop5: BLOCK_SIZE="131072" TYPE="squashfs"
/dev/loop12: BLOCK_SIZE="131072" TYPE="squashfs"
/dev/loop3: BLOCK_SIZE="131072" TYPE="squashfs"
/dev/loop10: BLOCK_SIZE="131072" TYPE="squashfs"
/dev/sdd3: PARTLABEL="Gap1" PARTUUID="2a585014-a55f-4771-aef1-695c6f9e0059"
/dev/sdb2: PARTLABEL="Microsoft reserved partition" PARTUUID="ffb570be-97c1-4b52-ae3a-59c8da2a3101"
fdisk -l
Disk /dev/loop0: 1.62 GiB, 1734254592 bytes, 3387216 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop1: 412.77 MiB, 432820224 bytes, 845352 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop2: 776.54 MiB, 814256128 bytes, 1590344 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop3: 240.51 MiB, 252190720 bytes, 492560 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop4: 73.9 MiB, 77492224 bytes, 151352 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop5: 4 KiB, 4096 bytes, 8 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop6: 11.2 MiB, 11747328 bytes, 22944 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop7: 496.98 MiB, 521121792 bytes, 1017816 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/sda: 465.76 GiB, 500107862016 bytes, 976773168 sectors Disk model: ST500DM002-1BD14 Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disklabel type: gpt Disk identifier: EC95E2E0-B1C9-03B3-B878-257B72ECEC00
Device Start End Sectors Size Type /dev/sda1 4096 523642879 523638784 249.7G Microsoft basic data /dev/sda2 523642880 976764927 453122048 216.1G Microsoft basic data
Disk /dev/sdb: 238.47 GiB, 256060514304 bytes, 500118192 sectors Disk model: SAMSUNG MZ7LN256 Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: gpt Disk identifier: 0E99A25E-4EAC-4265-964D-4D4FF9CF3DD0
Device Start End Sectors Size Type /dev/sdb1 2048 4392959 4390912 2.1G EFI System /dev/sdb2 4392960 4425727 32768 16M Microsoft reserved /dev/sdb3 4425728 251897855 247472128 118G Microsoft basic data /dev/sdb4 251897856 253358079 1460224 713M Windows recovery environment /dev/sdb5 253358080 500117503 246759424 117.7G Linux filesystem
Disk /dev/sdc: 298.09 GiB, 320072933376 bytes, 625142448 sectors Disk model: SAMSUNG HD322GJ Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: dos Disk identifier: 0x209e706a
Device Boot Start End Sectors Size Id Type /dev/sdc1 2048 625127423 625125376 298.1G 7 HPFS/NTFS/exFAT
Disk /dev/sdd: 28.82 GiB, 30943995904 bytes, 60437492 sectors Disk model: DataTraveler 3.0 Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: gpt Disk identifier: 2A585014-A55F-4771-AEF2-695C6F9E0059
Device Start End Sectors Size Type /dev/sdd1 64 10094759 10094696 4.8G Microsoft basic data /dev/sdd2 10094760 10104795 10036 4.9M EFI System /dev/sdd3 10104796 10105395 600 300K Microsoft basic data /dev/sdd4 10108928 60436479 50327552 24G Linux filesystem
Disk /dev/loop8: 91.69 MiB, 96141312 bytes, 187776 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop9: 10.52 MiB, 11026432 bytes, 21536 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop10: 40.86 MiB, 42840064 bytes, 83672 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop11: 452 KiB, 462848 bytes, 904 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop12: 130.95 MiB, 137310208 bytes, 268184 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
SMART test results on sdb5 (where Ubuntu installed on)
smartctl 7.3 2022-02-28 r5338 [x86_64-linux-6.5.0-9-generic] (local build)
Copyright (C) 2002-22, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION === Model Family: Samsung based SSDs Device Model: SAMSUNG MZ7LN256HCHP-000L7 Serial Number: S20HNXAH205538 LU WWN Device Id: 5 002538 d00000000 Firmware Version: EMT03L6Q User Capacity: 256,060,514,304 bytes [256 GB] Sector Size: 512 bytes logical/physical Rotation Rate: Solid State Device TRIM Command: Available Device is: In smartctl database 7.3/5319 ATA Version is: ACS-2, ATA8-ACS T13/1699-D revision 4c SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Fri Nov 10 18:03:23 2023 UTC SMART support is: Available - device has SMART capability. SMART support is: Enabled
=== START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED
General SMART Values: Offline data collection status: (0x00) Offline data collection activity was never started. Auto Offline Data Collection: Disabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 0) seconds. Offline data collection capabilities: (0x53) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. No Offline surface scan supported. Self-test supported. No Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 133) minutes. SCT capabilities: (0x003d) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported.
SMART Attributes Data Structure revision number: 1 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0 9 Power_On_Hours 0x0032 092 092 000 Old_age Always - 37035 12 Power_Cycle_Count 0x0032 096 096 000 Old_age Always - 3629 170 Unused_Rsvd_Blk_Ct_Chip 0x0032 100 100 010 Old_age Always - 0 171 Program_Fail_Count_Chip 0x0032 100 100 010 Old_age Always - 0 172 Erase_Fail_Count_Chip 0x0032 100 100 010 Old_age Always - 0 173 Wear_Leveling_Count 0x0033 087 087 005 Pre-fail Always - 268 174 Unexpect_Power_Loss_Ct 0x0032 099 099 000 Old_age Always - 416 178 Used_Rsvd_Blk_Cnt_Chip 0x0013 100 100 010 Pre-fail Always - 0 180 Unused_Rsvd_Blk_Cnt_Tot 0x0013 100 100 010 Pre-fail Always - 723 184 End-to-End_Error 0x0033 100 100 097 Pre-fail Always - 0 187 Uncorrectable_Error_Cnt 0x0032 100 100 000 Old_age Always - 0 194 Temperature_Celsius 0x0032 070 035 000 Old_age Always - 30 199 CRC_Error_Count 0x003e 099 099 000 Old_age Always - 1 233 Media_Wearout_Indicator 0x0013 086 086 000 Pre-fail Always - 14529068 241 Total_LBAs_Written 0x0032 099 099 000 Old_age Always - 25725 242 Total_LBAs_Read 0x0032 099 099 000 Old_age Always - 40003 249 NAND_Writes_1GiB 0x0032 099 099 000 Old_age Always - 68640
syslog file
https://filetransfer.io/data-package/R92DQfAA#link
UPDATE:
I found that the grub.cfg file still have the UUID not /dev/sdb5 as I mentioned in the fstab file. I updated-grup after I changed fstab file
/boot/grub/grub.cfg
# DO NOT EDIT THIS FILE
# It is automatically generated by grub-mkconfig using templates
# from /etc/grub.d and settings from /etc/default/grub
BEGIN /etc/grub.d/00_header
if [ -s $prefix/grubenv ]; then set have_grubenv=true load_env fi if [ "${initrdfail}" = 2 ]; then set initrdfail= elif [ "${initrdfail}" = 1 ]; then set next_entry="${prev_entry}" set prev_entry= save_env prev_entry if [ "${next_entry}" ]; then set initrdfail=2 fi fi if [ "${next_entry}" ] ; then set default="${next_entry}" set next_entry= save_env next_entry set boot_once=true else set default="0" fi
if [ x"${feature_menuentry_id}" = xy ]; then menuentry_id_option="--id" else menuentry_id_option="" fi
export menuentry_id_option
if [ "${prev_saved_entry}" ]; then set saved_entry="${prev_saved_entry}" save_env saved_entry set prev_saved_entry= save_env prev_saved_entry set boot_once=true fi
function savedefault { if [ -z "${boot_once}" ]; then saved_entry="${chosen}" save_env saved_entry fi } function initrdfail { if [ -n "${have_grubenv}" ]; then if [ -n "${partuuid}" ]; then if [ -z "${initrdfail}" ]; then set initrdfail=1 if [ -n "${boot_once}" ]; then set prev_entry="${default}" save_env prev_entry fi fi save_env initrdfail fi; fi } function recordfail { set recordfail=1 if [ -n "${have_grubenv}" ]; then if [ -z "${boot_once}" ]; then save_env recordfail; fi; fi } function load_video { if [ x$feature_all_video_module = xy ]; then insmod all_video else insmod efi_gop insmod efi_uga insmod ieee1275_fb insmod vbe insmod vga insmod video_bochs insmod video_cirrus fi }
if [ x$feature_default_font_path = xy ] ; then font=unicode else insmod part_gpt insmod ext2 set root='hd1,gpt5' if [ x$feature_platform_search_hint = xy ]; then search --no-floppy --fs-uuid --set=root --hint-bios=hd1,gpt5 --hint-efi=hd1,gpt5 --hint-baremetal=ahci1,gpt5 --hint='hd1,gpt5' c0fc479f-b1cc-4e85-962b-43a72eec9e91 else search --no-floppy --fs-uuid --set=root c0fc479f-b1cc-4e85-962b-43a72eec9e91 fi font="/usr/share/grub/unicode.pf2" fi
if loadfont $font ; then set gfxmode=auto load_video insmod gfxterm fi terminal_output gfxterm insmod part_gpt insmod ext2 set root='hd1,gpt5' if [ x$feature_platform_search_hint = xy ]; then search --no-floppy --fs-uuid --set=root --hint-bios=hd1,gpt5 --hint-efi=hd1,gpt5 --hint-baremetal=ahci1,gpt5 --hint='hd1,gpt5' c0fc479f-b1cc-4e85-962b-43a72eec9e91 else search --no-floppy --fs-uuid --set=root c0fc479f-b1cc-4e85-962b-43a72eec9e91 fi insmod gfxmenu loadfont ($root)/usr/share/grub/themes/Vimix/dejavu_32.pf2 loadfont ($root)/usr/share/grub/themes/Vimix/dejavu_sans_12.pf2 loadfont ($root)/usr/share/grub/themes/Vimix/dejavu_sans_14.pf2 loadfont ($root)/usr/share/grub/themes/Vimix/dejavu_sans_16.pf2 loadfont ($root)/usr/share/grub/themes/Vimix/dejavu_sans_24.pf2 loadfont ($root)/usr/share/grub/themes/Vimix/dejavu_sans_48.pf2 loadfont ($root)/usr/share/grub/themes/Vimix/terminus-12.pf2 loadfont ($root)/usr/share/grub/themes/Vimix/terminus-14.pf2 loadfont ($root)/usr/share/grub/themes/Vimix/terminus-16.pf2 loadfont ($root)/usr/share/grub/themes/Vimix/terminus-18.pf2 insmod jpeg insmod png set theme=($root)/usr/share/grub/themes/Vimix/theme.txt export theme if [ "${recordfail}" = 1 ] ; then set timeout=30 else if [ x$feature_timeout_style = xy ] ; then set timeout_style=hidden set timeout=0
Fallback hidden-timeout code in case the timeout_style feature is
unavailable.
elif sleep --interruptible 0 ; then set timeout=0 fi fi
END /etc/grub.d/00_header
BEGIN /etc/grub.d/05_debian_theme
set menu_color_normal=white/black set menu_color_highlight=black/light-gray
END /etc/grub.d/05_debian_theme
BEGIN /etc/grub.d/10_linux
function gfxmode { set gfxpayload="${1}" if [ "${1}" = "keep" ]; then set vt_handoff=vt.handoff=7 else set vt_handoff= fi } if [ "${recordfail}" != 1 ]; then if [ -e ${prefix}/gfxblacklist.txt ]; then if [ ${grub_platform} != pc ]; then set linux_gfx_mode=keep elif hwmatch ${prefix}/gfxblacklist.txt 3; then if [ ${match} = 0 ]; then set linux_gfx_mode=keep else set linux_gfx_mode=text fi else set linux_gfx_mode=text fi else set linux_gfx_mode=keep fi else set linux_gfx_mode=text fi export linux_gfx_mode menuentry 'Ubuntu' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-simple-c0fc479f-b1cc-4e85-962b-43a72eec9e91' { recordfail load_video gfxmode $linux_gfx_mode insmod gzio if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi insmod part_gpt insmod ext2 set root='hd1,gpt5' if [ x$feature_platform_search_hint = xy ]; then search --no-floppy --fs-uuid --set=root --hint-bios=hd1,gpt5 --hint-efi=hd1,gpt5 --hint-baremetal=ahci1,gpt5 --hint='hd1,gpt5' c0fc479f-b1cc-4e85-962b-43a72eec9e91 else search --no-floppy --fs-uuid --set=root c0fc479f-b1cc-4e85-962b-43a72eec9e91 fi linux /boot/vmlinuz-6.5.0-10-generic root=UUID=c0fc479f-b1cc-4e85-962b-43a72eec9e91 ro quiet splash $vt_handoff initrd /boot/initrd.img-6.5.0-10-generic } submenu 'Advanced options for Ubuntu' $menuentry_id_option 'gnulinux-advanced-c0fc479f-b1cc-4e85-962b-43a72eec9e91' { menuentry 'Ubuntu, with Linux 6.5.0-10-generic' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-6.5.0-10-generic-advanced-c0fc479f-b1cc-4e85-962b-43a72eec9e91' { recordfail load_video gfxmode $linux_gfx_mode insmod gzio if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi insmod part_gpt insmod ext2 set root='hd1,gpt5' if [ x$feature_platform_search_hint = xy ]; then search --no-floppy --fs-uuid --set=root --hint-bios=hd1,gpt5 --hint-efi=hd1,gpt5 --hint-baremetal=ahci1,gpt5 --hint='hd1,gpt5' c0fc479f-b1cc-4e85-962b-43a72eec9e91 else search --no-floppy --fs-uuid --set=root c0fc479f-b1cc-4e85-962b-43a72eec9e91 fi echo 'Loading Linux 6.5.0-10-generic ...' linux /boot/vmlinuz-6.5.0-10-generic root=UUID=c0fc479f-b1cc-4e85-962b-43a72eec9e91 ro quiet splash $vt_handoff echo 'Loading initial ramdisk ...' initrd /boot/initrd.img-6.5.0-10-generic } menuentry 'Ubuntu, with Linux 6.5.0-10-generic (recovery mode)' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-6.5.0-10-generic-recovery-c0fc479f-b1cc-4e85-962b-43a72eec9e91' { recordfail load_video insmod gzio if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi insmod part_gpt insmod ext2 set root='hd1,gpt5' if [ x$feature_platform_search_hint = xy ]; then search --no-floppy --fs-uuid --set=root --hint-bios=hd1,gpt5 --hint-efi=hd1,gpt5 --hint-baremetal=ahci1,gpt5 --hint='hd1,gpt5' c0fc479f-b1cc-4e85-962b-43a72eec9e91 else search --no-floppy --fs-uuid --set=root c0fc479f-b1cc-4e85-962b-43a72eec9e91 fi echo 'Loading Linux 6.5.0-10-generic ...' linux /boot/vmlinuz-6.5.0-10-generic root=UUID=c0fc479f-b1cc-4e85-962b-43a72eec9e91 ro single recovery nomodeset dis_ucode_ldr echo 'Loading initial ramdisk ...' initrd /boot/initrd.img-6.5.0-10-generic } menuentry 'Ubuntu, with Linux 6.5.0-9-generic' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-6.5.0-9-generic-advanced-c0fc479f-b1cc-4e85-962b-43a72eec9e91' { recordfail load_video gfxmode $linux_gfx_mode insmod gzio if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi insmod part_gpt insmod ext2 set root='hd1,gpt5' if [ x$feature_platform_search_hint = xy ]; then search --no-floppy --fs-uuid --set=root --hint-bios=hd1,gpt5 --hint-efi=hd1,gpt5 --hint-baremetal=ahci1,gpt5 --hint='hd1,gpt5' c0fc479f-b1cc-4e85-962b-43a72eec9e91 else search --no-floppy --fs-uuid --set=root c0fc479f-b1cc-4e85-962b-43a72eec9e91 fi echo 'Loading Linux 6.5.0-9-generic ...' linux /boot/vmlinuz-6.5.0-9-generic root=/dev/sdb5 ro quiet splash $vt_handoff } menuentry 'Ubuntu, with Linux 6.5.0-9-generic (recovery mode)' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-6.5.0-9-generic-recovery-c0fc479f-b1cc-4e85-962b-43a72eec9e91' { recordfail load_video insmod gzio if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi insmod part_gpt insmod ext2 set root='hd1,gpt5' if [ x$feature_platform_search_hint = xy ]; then search --no-floppy --fs-uuid --set=root --hint-bios=hd1,gpt5 --hint-efi=hd1,gpt5 --hint-baremetal=ahci1,gpt5 --hint='hd1,gpt5' c0fc479f-b1cc-4e85-962b-43a72eec9e91 else search --no-floppy --fs-uuid --set=root c0fc479f-b1cc-4e85-962b-43a72eec9e91 fi echo 'Loading Linux 6.5.0-9-generic ...' linux /boot/vmlinuz-6.5.0-9-generic root=/dev/sdb5 ro single recovery nomodeset dis_ucode_ldr } menuentry 'Ubuntu, with Linux 6.2.0-36-generic' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-6.2.0-36-generic-advanced-c0fc479f-b1cc-4e85-962b-43a72eec9e91' { recordfail load_video gfxmode $linux_gfx_mode insmod gzio if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi insmod part_gpt insmod ext2 set root='hd1,gpt5' if [ x$feature_platform_search_hint = xy ]; then search --no-floppy --fs-uuid --set=root --hint-bios=hd1,gpt5 --hint-efi=hd1,gpt5 --hint-baremetal=ahci1,gpt5 --hint='hd1,gpt5' c0fc479f-b1cc-4e85-962b-43a72eec9e91 else search --no-floppy --fs-uuid --set=root c0fc479f-b1cc-4e85-962b-43a72eec9e91 fi echo 'Loading Linux 6.2.0-36-generic ...' linux /boot/vmlinuz-6.2.0-36-generic root=UUID=c0fc479f-b1cc-4e85-962b-43a72eec9e91 ro quiet splash $vt_handoff echo 'Loading initial ramdisk ...' initrd /boot/initrd.img-6.2.0-36-generic } menuentry 'Ubuntu, with Linux 6.2.0-36-generic (recovery mode)' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-6.2.0-36-generic-recovery-c0fc479f-b1cc-4e85-962b-43a72eec9e91' { recordfail load_video insmod gzio if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi insmod part_gpt insmod ext2 set root='hd1,gpt5' if [ x$feature_platform_search_hint = xy ]; then search --no-floppy --fs-uuid --set=root --hint-bios=hd1,gpt5 --hint-efi=hd1,gpt5 --hint-baremetal=ahci1,gpt5 --hint='hd1,gpt5' c0fc479f-b1cc-4e85-962b-43a72eec9e91 else search --no-floppy --fs-uuid --set=root c0fc479f-b1cc-4e85-962b-43a72eec9e91 fi echo 'Loading Linux 6.2.0-36-generic ...' linux /boot/vmlinuz-6.2.0-36-generic root=UUID=c0fc479f-b1cc-4e85-962b-43a72eec9e91 ro single recovery nomodeset dis_ucode_ldr echo 'Loading initial ramdisk ...' initrd /boot/initrd.img-6.2.0-36-generic } }
END /etc/grub.d/10_linux
BEGIN /etc/grub.d/10_linux_zfs
END /etc/grub.d/10_linux_zfs
BEGIN /etc/grub.d/20_linux_xen
END /etc/grub.d/20_linux_xen
BEGIN /etc/grub.d/25_bli
if [ "$grub_platform" = "efi" ]; then insmod bli fi
END /etc/grub.d/25_bli
BEGIN /etc/grub.d/30_os-prober
END /etc/grub.d/30_os-prober
BEGIN /etc/grub.d/30_uefi-firmware
if [ "$grub_platform" = "efi" ]; then fwsetup --is-supported if [ "$?" = 0 ]; then menuentry 'UEFI Firmware Settings' $menuentry_id_option 'uefi-firmware' { fwsetup } fi fi
END /etc/grub.d/30_uefi-firmware
BEGIN /etc/grub.d/40_custom
This file provides an easy way to add custom menu entries. Simply type the
menu entries you want to add after this comment. Be careful not to change
the 'exec tail' line above.
END /etc/grub.d/40_custom
BEGIN /etc/grub.d/41_custom
if [ -f ${config_directory}/custom.cfg ]; then source ${config_directory}/custom.cfg elif [ -z "${config_directory}" -a -f $prefix/custom.cfg ]; then source $prefix/custom.cfg fi
END /etc/grub.d/41_custom
Omar_Hafez
  • 137
OMG, I fixed it!!
First of all, I don't really know what exactly the problem was. However, I found that the EFI partition might be corrupted. I followed these steps to fix this (And I think this can solve most boot problems like this).
Here is my recipe to solve most of the booting problems:
1) Create a boot-repair USB:
some Linux distros do not support boot-repair like Ubuntu 23 so it's a good idea to create your boot-repair disk
2) Boot to the live boot-repair USB
It's a modified Lubuntu distro that contains a boot-repair tool and some other tools fixing other booting problems. Run the boot-repair tool and click recommended repair. This Can solve most of the problems. If this didn't solve your problems please continue reading.
3) Clear everything
  • here you should format the EFI partition as it might be corrupted (like in my case) (you can use the GParted tool already installed in the boot-repair live USB.
  • Now You can recreate this EFI partition using this way Or you can regenerate it using Windows USB (If you have Windows dual booted with Ubuntu) for UFEI MBR
  • In case you restored it using the Windows USB method and restored the Windows EFI partition you will be able to boot to your Windows once you boot to it open the cmd and administrator and run these commands:
    bcdedit /set {bootmgr} displaybootmenu yes
    bcdedit /set {bootmgr} path \EFI\ubuntu\grubx64.efi
  • Delete these files (or take them as backups): etc/default/grub boot/grub/grub.cfg
  • Check the `etc/fstab' file and make sure that no errors in it. You can take a look at this question here and there are a lot of topics online about how to fix the broken fstab file.
  • run these commands to mount and chroot your Ubuntu in the live USB terminal but replace the sdb5 with the partition where your Ubuntu is installed on.
    sudo mount /dev/sdb5 /mnt && mount --rbind /dev /mnt/dev && mount --rbind /proc /mnt/proc && mount --rbind /sys /mnt/sys && chroot /mnt bash
  • Now run this command to regenerate 'etc/default/grub' file:
    sudo apt-get remove --purge grub-pc && apt-get install grub-pc
  • and then update-grub
4) Run the boot-repair tool again
here everything should work very well.:)
Omar_Hafez
  • 137
