root@vmi1433468:~# sudo apt install mariadb-server mariadb-client -y
Reading package lists... Done
Building dependency tree
mariadb-client : Depends: mariadb-client-10.3 (>= 1:10.3.22-1ubuntu1) but it is not going to
be installed
mariadb-server : Depends: mariadb-server-10.3 (>= 1:10.3.22-1ubuntu1) but it is not going to
be installed
I need help please
sotirov
  • 4,379
JeanHz
You probably have some MySQL packages installed on your system. MariaDB is a drop-in replacement for MySQL and both use the same library names and files (both in /var/lib/mysql and /etc/mysql/my.conf). Check this post: Why does Ubuntu prohibit installing both MySQL and MariaDB via apt? for more details.
Use apt list --installed | grep mysql and look for mysql-server, mysql-client-8.0 and other similar packages.
If you want to install MariaDB, you will have to uninstall these. You can remove them manually one by one or use apt with wildcard(*) like this:
sudo apt remove mysql*
sudo apt autoremove
sotirov
  • 4,379
