12
I have one problem with upgrading of nvidia package. After last updating of this package I faced with such message:
$ sudo apt-get upgrade
Reading package lists... Done
Building dependency tree... Done
You might want to run 'apt --fix-broken install' to correct these.
 nvidia-dkms-535 : Depends: nvidia-kernel-common-535 (= 535.129.03-0ubuntu1) but 535.129.03-0ubuntu0.22.04.1 is installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
I tried to solve this problem by this command:
$ sudo apt --fix-broken install
Correcting dependencies... Done
The following package was automatically installed and is no longer required:
  nvidia-firmware-535-535.129.03
Use 'sudo apt autoremove' to remove it.
The following additional packages will be installed:
The following packages will be upgraded:
1 upgraded, 0 newly installed, 0 to remove and 32 not upgraded.
1 not fully installed or removed.
Need to get 0 B/38,3 MB of archives.
After this operation, 61,2 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
(Reading database ... 291692 files and directories currently installed.)
Preparing to unpack .../nvidia-kernel-common-535_535.129.03-0ubuntu1_amd64.deb .
Unpacking nvidia-kernel-common-535 (535.129.03-0ubuntu1) over (535.129.03-0ubunt
u0.22.04.1) ...
dpkg: error processing archive /var/cache/apt/archives/nvidia-kernel-common-535_
535.129.03-0ubuntu1_amd64.deb (--unpack):
 trying to overwrite '/lib/firmware/nvidia/535.129.03/gsp_ga10x.bin', which is a
lso in package nvidia-firmware-535-535.129.03 535.129.03-0ubuntu0.22.04.1
dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
 /var/cache/apt/archives/nvidia-kernel-common-535_535.129.03-0ubuntu1_amd64.deb
But it didn't work.
Do you have any suggestions how to fix this problem?
karel
  • 122,292
  • 133
  • 301
  • 332
Please open up your terminal and try the following:
sudo dpkg -i --force-overwrite /var/cache/apt/archives/nvidia-kernel-common-535_535.129.03-0ubuntu1_amd64.deb
Then run:
Wish you the very best!
ducky
  • 378
