I am struggling to do my release upgrade from Ubuntu 23.04 to 23.10. The release upgrade depends on all packages being upgraded, and one upgrade is held back.
$ sudo do-release-upgrade
Checking for a new Ubuntu release
Please install all available updates for your release before upgrading
When updating and upgrading all packages, the package libgd3 fails to upgrade
$ sudo apt upgrade
The following packages have been kept back:
  libgd3
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
The package depends on a package that is not installable,
 libgd3 : Depends: libavif13 (>= 0.9.3) but it is not installable
I have therefore installed libavif13 from source, but to no avail (as I do not know how to indicate the library to apt [and unsure whether this makes sense]). libavif apparently has newer installation candidates, such as libavif15, I have no idea why libgd3 would depend on the outdated libavif13.
I am honestly lost here and would appreciate any hint as to how to resolve this dependency.
Thank you all and cheers
edit: as requested, the output of apt policy libgd3
$ sudo apt policy libgd3
libgd3:
  Installed: 2.3.3-7ubuntu2
  Candidate: 2.3.3-9+ubuntu22.04.1+deb.sury.org+1
  Version table:
     2.3.3-9+ubuntu22.04.1+deb.sury.org+1 500
        500 https://ppa.launchpadcontent.net/ondrej/php/ubuntu jammy/main amd64 Packages
 *** 2.3.3-7ubuntu2 500
        500 http://xx.archive.ubuntu.com/ubuntu lunar/main amd64 Packages
        100 /var/lib/dpkg/status
Mr.Cave
Ondrej PPA for PHP only supports Ubuntu LTS releases. So it is stuck with 22.04 version constraints, from which some were dropped from Ubuntu 23.10.
You need to manually install these packages from 22.04:
libyuv0
libabsl20210324
libdav1d5
libgav1-0
libavif13
libtiff5
with sudo dpkg -i <deb-file>. The needed deb files can for example be downloaded from there (needs some searching):
http://archive.ubuntu.com/ubuntu/pool/universe/
You can also for example search in the UI on https://ubuntu.pkgs.org/ which will also give you the download location on the ubuntu archive pool. Make sure to pick the correct CPU architecture (most likely amd64 if you are unsure, but dpkg will tell you if you picked the wrong one, it won't screw up).
Then you can install libgd5 using apt. After doing so, I suggest to
sudo apt-mark minimize-manual
Then it will auto cleanup when Ubuntu 24.04 releases and the ondrej PHP PPA will finally be upgraded as well.
foobar
  • 123
Let us try some methods,
Since there is a dependency issue, try to manually upgrade the libgd3 package.
sudo apt --with-new-pkgs upgrade libgd3
If it fails you can manually install the package,
sudo apt install libgd3
Hope that fixes your issue!
