I ran out of space for my Ubuntu OS and decided to extend it by unallocating space from Windows OS partition and assigning it to Ubuntu. Ubuntu worked right afterwards but Windows won't boot up. Windows ran its own file check and "fixed" files, and booted up but now Ubuntu is not booting up. Now, when I want to boot Ubuntu, it's not GNU/Linux and just black screen.
I used a live USB Stick with Boot-Repair to fix things and it suggested to purge GRUB and reinstall it. I had issues with that and did everything I could. For example, I had problems with packages and I just manually was "fixing" them (?). But now, it just says grub-efi purge is cancelled. I think I really broken things. I did my own research, and the solutions are very closely connected with EFI partitions and changing things there and I'm kind of scared to do that right now.
Boot-Repair Boot Info Summary:
============================== Boot Info Summary ===============================
=> No boot loader is installed in the MBR of /dev/nvme0n1.
=> No known boot loader is installed in the MBR of /dev/sda.
nvme0n1p1: _____________________________________________________________________
File system: vfat
Boot sector type: Windows 8/10/11/2012: FAT32
Boot sector info: No errors found in the Boot Parameter Block.
Operating System:
Boot files:
nvme0n1p2: _____________________________________________________________________
File system:
Boot sector type: -
Boot sector info:
nvme0n1p3: _____________________________________________________________________
File system: ntfs
Boot sector type: Windows 8/10/11/2012: NTFS
Operating System: Windows 10 or 11
Boot files:
nvme0n1p4: _____________________________________________________________________
File system: ntfs
Operating System:
Boot files:
nvme0n1p5: _____________________________________________________________________
File system: ext4
Boot sector type: -
Boot sector info:
Operating System: Ubuntu 22.04.3 LTS
Boot files: /boot/grub/grub.cfg /etc/fstab /etc/default/grub
sda1: __________________________________________________________________________
File system: vfat
Operating System:
Boot files: /boot/grub/grub.cfg /efi/boot/bootx64.efi
/efi/boot/grubx64.efi /efi/boot/mmx64.efi
================================ 2 OS detected =================================
OS#1: Ubuntu 22.04.3 LTS on nvme0n1p5
OS#2: Windows 10 or 11 on nvme0n1p3
================================ Host/Hardware =================================
CPU architecture: 64-bit
Video: GA107M [GeForce RTX 3050 Mobile] TigerLake-H GT1 [UHD Graphics] from NVIDIA Corporation Intel Corporation
Live-session OS is Ubuntu 64-bit (Ubuntu 22.04.3 LTS, jammy, x86_64)
===================================== UEFI =====================================
BIOS/UEFI firmware: V1.18(1.18) from Insyde Corp.
The firmware is EFI-compatible, and is set in EFI-mode for this live-session.
No EFI in dmseg.
SecureBoot disabled (confirmed by mokutil).
BootCurrent: 0000
Timeout: 0 seconds
BootOrder: 0000,0001,0002,2001,2002,2003
Boot0000* Linpus lite HD(1,GPT,d890c60c-56a1-4c95-8377-d22b508a032e,0x800,0x39bb7e0)/File(\EFI\Boot\grubx64.efi)RC
Boot0001* Windows Boot Manager HD(1,GPT,f9395298-f076-48ab-9d99-76af71f5c8f1,0x800,0x32000)/File(\EFI\Microsoft\Boot\bootmgfw.efi)WINDOWS.........x...B.C.D.O.B.J.E.C.T.=.{.9.d.e.a.8.6.2.c.-.5.c.d.d.-.4.e.7.0.-.a.c.c.1.-.f.3.2.b.3.4.4.d.4.7.9.5.}....................
Boot0002* ubuntu HD(1,GPT,f9395298-f076-48ab-9d99-76af71f5c8f1,0x800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot2001* EFI USB Device RC
Boot2002* EFI DVD/CDROM RC
Boot2003* EFI Network RC
============================= Drive/Partition Info =============================
Disks info: ____________________________________________________________________
nvme0n1 : is-GPT, no-BIOSboot, has---ESP, not-usb, not-mmc, has-os, has-win, 2048 sectors * 512 bytes
Partitions info (1/3): _________________________________________________________
nvme0n1p1 : no-os, 64, nopakmgr, no-docgrub, nogrub, nogrubinstall, no-grubenv, noupdategrub, not-far
nvme0n1p3 : is-os, 64, nopakmgr, no-docgrub, nogrub, nogrubinstall, no-grubenv, noupdategrub, farbios
nvme0n1p4 : no-os, 64, nopakmgr, no-docgrub, nogrub, nogrubinstall, no-grubenv, noupdategrub, farbios
nvme0n1p5 : is-os, 64, apt-get, signed grub-pc grub-efi , grub2, grub-install, grubenv-ng, update-grub, farbios
Partitions info (2/3): _________________________________________________________
nvme0n1p1 : is---ESP, part-has-no-fstab, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot
nvme0n1p3 : isnotESP, part-has-no-fstab, no-nt, haswinload, no-recov-nor-hid, no-bmgr, notwinboot
nvme0n1p4 : isnotESP, part-has-no-fstab, no-nt, no-winload, recovery-or-hidden, no-bmgr, notwinboot
nvme0n1p5 : isnotESP, fstab-has-goodEFI, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot
Partitions info (3/3): _________________________________________________________
nvme0n1p1 : not--sepboot, no---boot, part-has-no-fstab, not-sep-usr, no---usr, part-has-no-fstab, no--grub.d, nvme0n1
nvme0n1p3 : not--sepboot, no---boot, part-has-no-fstab, not-sep-usr, no---usr, part-has-no-fstab, no--grub.d, nvme0n1
nvme0n1p4 : not--sepboot, no---boot, part-has-no-fstab, not-sep-usr, no---usr, part-has-no-fstab, no--grub.d, nvme0n1
nvme0n1p5 : not--sepboot, with-boot, fstab-without-boot, not-sep-usr, with--usr, fstab-without-usr, std-grub.d, nvme0n1
fdisk -l (filtered): ___________________________________________________________
Disk nvme0n1: 476.94 GiB, 512110190592 bytes, 1000215216 sectors
Disk identifier: 8BECBD3C-43DC-45B2-9BCE-419172A7FA16
Start End Sectors Size Type
nvme0n1p1 2048 206847 204800 100M EFI System
nvme0n1p2 206848 239615 32768 16M Microsoft reserved
nvme0n1p3 239616 862603263 862363648 411.2G Microsoft basic data
nvme0n1p4 998420480 1000210431 1789952 874M Windows recovery environment
nvme0n1p5 862603264 998420479 135817216 64.8G Linux filesystem
Partition table entries are not in disk order.
Disk sda: 28.87 GiB, 30995907072 bytes, 60538881 sectors
Disk identifier: 7045AE4E-C377-40BC-BF76-917289018D38
sda1 2048 60538847 60536800 28.9G Microsoft basic data
parted -lm (filtered): _________________________________________________________
sda:31.0GB:scsi:512:512:gpt:Kingston DataTraveler 3.0:;
1:1049kB:31.0GB:31.0GB:fat32:Main Data Partition:msftdata;
nvme0n1:512GB:nvme:512:512:gpt:WDC PC SN530 SDBPNPZ-512G-1114:;
1:1049kB:106MB:105MB:fat32:EFI system partition:boot, esp;
2:106MB:123MB:16.8MB::Microsoft reserved partition:msftres;
3:123MB:442GB:442GB:ntfs:Basic data partition:msftdata;
5:442GB:511GB:69.5GB:ext4::;
4:511GB:512GB:916MB:ntfs::hidden, diag;
blkid (filtered): ______________________________________________________________
NAME FSTYPE UUID PARTUUID LABEL PARTLABEL
sda
└─sda1 vfat B6BD-2780 d890c60c-56a1-4c95-8377-d22b508a032e UBUNTU 22_0 Main Data Partition
nvme0n1
├─nvme0n1p1 vfat FEAB-FFD7 f9395298-f076-48ab-9d99-76af71f5c8f1 EFI system partition
├─nvme0n1p2 87545613-096d-40e8-b3a7-aedaaf5de1fc Microsoft reserved partition
├─nvme0n1p3 ntfs 020CB7520CB73F89 141a3195-2de2-4709-9ceb-9d28505a636e Basic data partition
├─nvme0n1p4 ntfs 424AB0C34AB0B4CF 0cc59d7c-896c-4023-ae10-1ca6b68a498e
└─nvme0n1p5 ext4 9e5a9876-5906-4a22-b0ef-6b0c527bde57 0a780072-4375-4fdd-9863-73ce29f81570
Mount points (filtered): _______________________________________________________
Avail Use% Mounted on
/dev/nvme0n1p4 76.1M 91% /mnt/boot-sav/nvme0n1p4
/dev/nvme0n1p5 29.8G 48% /mnt
/dev/sda1 24.2G 16% /cdrom
Mount options (filtered): ______________________________________________________
=================== nvme0n1p5/boot/grub/grub.cfg (filtered) ====================
GNU/Linux 9e5a9876-5906-4a22-b0ef-6b0c527bde57
GNU/Linux, with Linux 6.2.0-35-generic 9e5a9876-5906-4a22-b0ef-6b0c527bde57
GNU/Linux, with Linux 6.2.0-34-generic 9e5a9876-5906-4a22-b0ef-6b0c527bde57
Windows Boot Manager (on nvme0n1p1) osprober-efi-FEAB-FFD7
END /etc/grub.d/30_os-prober
END /etc/grub.d/30_uefi-firmware
======================== nvme0n1p5/etc/fstab (filtered) ========================
<file system> <mount point> <type> <options> <dump> <pass>
/ was on /dev/nvme0n1p5 during installation
UUID=9e5a9876-5906-4a22-b0ef-6b0c527bde57 / ext4 errors=remount-ro 0 1
/boot/efi was on /dev/nvme0n1p1 during installation
UUID=FEAB-FFD7 /boot/efi vfat umask=0077 0 1
/swapfile none swap sw 0 0
==================== nvme0n1p5/etc/default/grub (filtered) =====================
GRUB_DISABLE_OS_PROBER=false
================= nvme0n1p5: Location of files loaded by Grub ==================
GiB - GB File Fragment(s)
440.186527252 = 472.646684672 boot/grub/grub.cfg 1
413.935695648 = 444.460068864 boot/vmlinuz 1
437.938472748 = 470.232854528 boot/vmlinuz-6.2.0-34-generic 2
413.935695648 = 444.460068864 boot/vmlinuz-6.2.0-35-generic 1
437.938472748 = 470.232854528 boot/vmlinuz.old 2
433.646598816 = 465.624489984 boot/initrd.img 70
444.735122681 = 477.530701824 boot/initrd.img-6.2.0-34-generic 203
433.646598816 = 465.624489984 boot/initrd.img-6.2.0-35-generic 70
444.735122681 = 477.530701824 boot/initrd.img.old 203
=================== nvme0n1p5: ls -l /etc/grub.d/ (filtered) ===================
-rwxr-xr-x 1 root root 18683 Dec 18 2022 10_linux
-rwxr-xr-x 1 root root 43031 Dec 18 2022 10_linux_zfs
-rwxr-xr-x 1 root root 14387 Dec 18 2022 20_linux_xen
-rwxr-xr-x 1 root root 13369 Dec 18 2022 30_os-prober
-rwxr-xr-x 1 root root 1372 Dec 18 2022 30_uefi-firmware
-rwxr-xr-x 1 root root 700 May 17 05:35 35_fwupd
-rwxr-xr-x 1 root root 214 Dec 18 2022 40_custom
-rwxr-xr-x 1 root root 215 Dec 18 2022 41_custom
====================== sda1/boot/grub/grub.cfg (filtered) ======================
Try or Install Ubuntu
Ubuntu (safe graphics)
OEM install (for manufacturers)
Boot from next volume
UEFI Firmware Settings
Test memory
==================== sda1: Location of files loaded by Grub ====================
?? = ?? boot/grub/grub.cfg 1
Suggested repair: ______________________________________________________________
The default repair of the Boot-Repair utility will purge (in order to unsign) and reinstall the grub-efi of
nvme0n1p5,
using the following options: nvme0n1p1/boot/efi
Additional repair will be performed: unhide-bootmenu-10s use-standard-efi-file restore-efi-backups
Final advice in case of suggested repair: ______________________________________
Please do not forget to make your UEFI firmware boot on the Ubuntu 22.04.3 LTS entry (nvme0n1p1/efi/**/grub.efi (** will be updated in the final message) file) !
If your computer reboots directly into Windows, try to change the boot order in your UEFI firmware.
If your UEFI firmware does not allow to change the boot order, change the default boot entry of the Windows bootloader.
For example you can boot into Windows, then type the following command in an admin command prompt:
bcdedit /set {bootmgr} path \EFI**\grub.efi (** will be updated in the final message)
paste.ubuntu.com ko ()
paste.debian.net ko (https://paste.debian.net/)
