In ubuntu 22.04.2 I am trying to read the data coming from a serial port. To find the correct port I do
sudo dmesg | grep tty
which gives
[    0.117304] printk: console [tty0] enabled
[    0.793135] 0000:00:16.3: ttyS4 at I/O 0x3060 (irq = 19, base_baud = 115200) is a 16550A
[    4.136977] usb 3-6.3.2: FTDI USB Serial Device converter now attached to ttyUSB0
[27184.158691] ftdi_sio ttyUSB0: FTDI USB Serial Device converter now disconnected from ttyUSB0
[27190.409672] usb 3-6.3.2: FTDI USB Serial Device converter now attached to ttyUSB0
after disconnecting and reconnecting the USB device (around time 28180). Then according to this suggestion I do
screen /dev/ttyUSB0 115200
but all I get is
[screen is terminating]
So how to do it AS SIMPLE AS POSSIBLE without setting up configuration, clicking through menues or navigating on the command line through complex setup stuff? I just want to listen to some information that comes from this serial connection (which is connected to the laptop via USB).
On windows I could use
  • hterm
  • putty
  • MOBA xterm
But what to use on ubuntu?
Alex
  • 1,115
It seems minicom is in fact what I can use simply. I installed it using
sudo apt-get install minicom
and then I use
to find the correct device, and using
sudo minicom -b 115200 -o -D /dev/ttyUSB0
if your device is /dev/ttyUSB0. You have to specify the baudrate -b 115200, I start it uninitialized -o and specify the device to connect to -D /dev/ttyUSB0.
Alex
  • 1,115
Since you have screen still installed, double check if the user has the proper group permissions to interact with the serial device. From this post it suggests adding your user to the dialout group with usermod -a -G dialout $USER. If all else fails, maybe try with sudo screen instead.
kyrlon
  • 174
Nice program is also tio:
tio -b 9600 /dev/ttyUSB0
It is greate for Arduino and similar devices with USB, as ESP8266.
xerostomus
  • 1,060
