The fan speed control when running Ubuntu 23.10 on a Raspberry Pi 5 does not appear to be working. The fan runs at near maximum speed all the time and the cur_state in /sys/class/thermal/cooling_device0/ is stuck at the value of 4 no matter what the CPU temperature. I suspect it is related to this fault reported on Raspberry Pi OS: https://forums.raspberrypi.com/viewtopic.php?t=356881
Anyone else had any success with this?
Steve Pringle
  • 89
This has since been fixed as part of a kernel update.
You can update your Ubuntu Server installation with:
sudo apt update
sudo apt upgrade
After a reboot, the fan speed will behave as expected.
There is now a patch to a kernel build in ppa:waveform/fan-fix (https://launchpad.net/~waveform/+archive/ubuntu/fan-fix) which should serve as a temporary fix until the next kernel release. This allows the fan speed control to work ,but there is some concern that the hysteresis is being ignored, so this may not be the final fix.
Steve Pringle
  • 89
Its annoying, what I've been doing is just swapping the value until we get a new stable kernel:
sudo bash
cat > /sys/class/thermal/cooling_device0/cur_state
<CTRL-D>
Billy
I was also annoyed by this and decided to let Python do all the work. Feel free to use this https://pastebin.com/SbFb4LYE .
from subprocess import run as srun, PIPE
from time import sleep
from datetime import timedelta as td, datetime as dt
Use step values to activate desired FAN value
STEP1 = 48 STEP2 = 60 STEP3 = 65 STEP4 = 72
SLEEP_TIMER = 1
TICKS = 3 DELTA_TEMP = 3 DATETIME_FORMAT = '%Y-%m-%d %H:%M:%S' fanControlFile = '/sys/class/thermal/cooling_device0/cur_state'
def main(): print("Running FAN control for RPI5 Ubuntu") t0 = dt.now()
command = f'tee -a {fanControlFile} &gt; /dev/null'
oldSpeed = 0
ticks = 0
speed = 1
lastTemp = 0
while True:
    sleep(SLEEP_TIMER) # force 1 second timer, just to reduce polling calls
    t1 = dt.now()
    if(t1 + td(minutes=TICKS) &gt; t0):
        t0 = t1
        tempOut = getOutput('vcgencmd measure_temp')
        try:
            cels = int(tempOut.split('temp=')[1][:2])
        except:
            cels = 40
        if STEP1 &lt; cels &lt; STEP2:
            speed = 1
        elif STEP2 &lt; cels &lt; STEP3:
            speed = 2
        elif STEP3 &lt; cels &lt; STEP4:
            speed = 3
        elif cels &gt;= STEP4:
            speed = 4
        deltaTempNeg = lastTemp - DELTA_TEMP
        deltaTempPos = lastTemp + DELTA_TEMP
        if oldSpeed != speed and not(deltaTempNeg &lt;= cels &lt;= deltaTempPos):
            print(f'oldSpeed: {oldSpeed} | newSpeed: {speed}')
            print(f'{deltaTempNeg}ºC &lt;= {cels}ºC &lt;= {deltaTempPos}ºC')
            print(f'{&quot;#&quot;*30}\n' +
                f'Updating fan speed!\t{t0.strftime(DATETIME_FORMAT)}\n' +
                f'CPU TEMP: {cels}ºC\n' +
                f'FAN speed will be set to: {speed}\n' +
                f'{&quot;#&quot;*30}\n')
            _command = f'echo {speed} | sudo {command}'
            callShell(_command, debug=True)
            checkVal = getOutput(f'cat {fanControlFile}')
            print(f'Confirm FAN set to speed: {checkVal}')
            oldSpeed = speed
            lastTemp = cels
            ticks = 0
        # Log minor details
        ticks += 1
        if(ticks &gt; TICKS * 3):
            ticks = 0
            print(f'Current Temp is: {cels}ºC\t{t0.strftime(DATETIME_FORMAT)}')
def callShell(cmd, shell=True, debug=False): if debug: print(f'Calling: [{cmd}]') return srun(f'''{cmd}''', stdout=PIPE, shell=shell)
def getOutput(cmd, shell=True): stdout = callShell(cmd, shell=shell).stdout
try:
    stdout = stdout.decode('utf-8')
except:
    pass
return stdout
RUN SCRIPT
main()
karel
  • 122,292
  • 133
  • 301
  • 332
