When I start a terminal, I see this:
Welcome to Ubuntu 20.04.6 LTS (GNU/Linux 5.4.0-165-generic x86_64)
System information as of jeu 26 oct 2023 11:16:34 CEST
System load: 0.45
Usage of /: 49.7% of 455.20GB
Memory usage: 50%
Swap usage: 19%
Processes: 182
Users logged in: 0
=> /bu is using 91.9% of 1.79TB
But when I use du or df, I get:
$ df
Sys. de fichiers blocs de 1K Utilisé Disponible Uti% Monté sur
udev 457888 0 457888 0% /dev
tmpfs 97128 3040 94088 4% /run
/dev/sdc 1920645740 1765707476 57348560 97% /bu
~$ sudo du /bu
4 /bu/lost+found
1765707472 /bu
The results given by du and df (97% used) are identical but very different from the value given by system information (91.9% used). Why is this?
The results (at least in %) are identical for various forms of df:
$ df --si
Sys. de fichiers Taille Utilisé Dispo Uti% Monté sur
/dev/sdc 2,0T 1,9T 59G 97% /bu
$ df -H
~$ df -h
/dev/sdc 1,8T 1,7T 55G 97% /bu
------ Edit - Results of lsbk ----
As askeh by Hannu, here is the output. This time, FSUSE% is at 92%, conform to motd. So, it seems the content of the 'MOTD' is based on some extraction of lsblkid. I updated the question title accordingly.
lsblk -ap -o +MOUNTPOINT,FSTYPE,LABEL,PARTLABEL,FSUSE%,STATE,MODEL
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT MOUNTPOINT FSTYPE LABEL PARTLABEL FSUSE% STATE MODEL
/dev/loop0 7:0 0 0 loop
/dev/loop7 7:7 0 0 loop
/dev/sda 8:0 0 465,8G 0 disk running WDC_WD5003ABYX-18WERA0
├─/dev/sda1 8:1 0 243M 0 part /boot /boot ext2 60%
├─/dev/sda2 8:2 0 1K 0 part
└─/dev/sda5 8:5 0 465,5G 0 part LVM2_member
├─/dev/mapper/servamtex2-root
│ 253:0 0 462,7G 0 lvm / / ext4 50% running
└─/dev/mapper/servamtex2-swap_1
253:2 0 2,8G 0 lvm [SWAP] [SWAP] swap running
/dev/sdb 8:16 0 465,8G 0 disk running WDC_WD5002ABYS-18B1B0
├─/dev/sdb2 8:18 0 1K 0 part
└─/dev/sdb5 8:21 0 465,5G 0 part LVM2_member
├─/dev/mapper/servamtex-root
│ 253:1 0 462,7G 0 lvm /servamtex-old /servamtex-old ext4 12% running
└─/dev/mapper/servamtex-swap_1
253:3 0 2,8G 0 lvm swap running
/dev/sdc 8:32 0 1,8T 0 disk /bu /bu ext4 92% running ST2000NM0033-9ZM175
------ Edit 2 df used space ----
My question does not relate to interpretation of df results but why is there a discrepancy between MOTD system information and df information. A possible cause is the difference of 5% as pointed out by @muru
