I have a laptop connected to a second monitor using a vga port. No proprietary drivers used. When I go to System Preferences --> Monitor and I turn that on it doesn't look as it should, and it's rotated 90 degrees clockwise or anti-clockwise. I can't choose Normal on the rotation dropdown menù in the monitor preferences.
I wonder if there is a workaround to make it look normal.
Braiam
  • 69,112
vonValle
  • 191
6 Answers6
10
Ok, just solved it. I typed in the terminal:
xrandr --output VGA1 --mode 1280x1024 --rotate normal
If you have the same kind of problem, you have to change "VGA1" with the right output (just type xrandr in the terminal to have a list of your your video outputs) and "1280x1024" with the resolution you want.
Eliah Kagan
  • 119,640
vonValle
  • 191
I had this problem just now. It seems that Ubuntu has a limit to how wide the virtual screen can be, so it rotates the second one if that will make it fit under the limit. Try positioning the second screen below the first in the display settings.
After a fresh install, on my system the laptop screen was rotated 90 degrees. To solve it, I logged off, and selected Ubuntu 2D. I was confused at first because I had been running two screens previously, and had no problems. I remember originally when I connected the monitor to the VGA port, it complained thaT I didn't have enough video memory to run the resolution configuration that I asked for. It told me to switch to Ubuntu 2D. On the fresh install, I had the monitor hooked up to the VGA port -- and it didn't complain this time except rotate laptop screen 90 degrees which was confusing.
I found a workaround to this problem after researching and experimenting on it for a couple hours. I have a Acer 22" monitor and an HP Pavilion dv2000 laptop. Here are the steps that resolved the issue for me.
  1. I went into the Menu for the monitor itself (buttons along the bottom of the display) and found the "Wide-Mode" setting and turned it off. At this point the display was still sideways, but in a narrow view that doesn't use the full width of the screen. The display is now centered in the monitor with two black bars on the sides of the screen.
  2. I went into the Ubuntu display properties and selected Mirror Displays. This displayed the same content at the same resolution on both monitors (my primary display being my laptop screen) and set the second monitor display in a normal upright position. This had the same effect on the laptop monitor as on the secondary, in that the display does not take up the full width of the screen.
  3. I then deselected Mirror Displays. This turned off the display mirroring but left both displays in the correct orientation with the same resolution. Now neither display covers the full area of the screen, but at least they do both work! Changing the resolution on either monitor results in an error message, but this workaround will serve the purpose for now.
Radu Rădeanu
  • 174,089
  • 51
  • 332
  • 407
I managed to work-around this problem from "Displays" (GUI), without having to resort to xrandr, by the following sequence:
  1. mirror (& apply)
  2. turn off laptop's monitor in docking station, whilst leaving (current and low) resolution unchanged (& apply)
  3. finally, ramp up resolution on external monitor to max. (& apply)
Note, though, that this is exactly what I was after:
  • laptop-monitor off
  • external monitor on
which might not be what you're after (but in which case xrandr might do the trick)...
I had the same problems. At first my second monitor looked good with a resolution of 1440x900, but after I changed my settings, it kept turning the screen and the normal mode was no longer available.
xrandr --output VGA1 --auto --rotate normal
Does solve the problem temporarily, but I have to redo this after login etc.
I moved back from Unity 3D to Metacity 2D, see: Is it possible to change Unity 3D to 2D and will I gain any performance boost after that?
Now the problem is solved, I can select the right resolution as well as the normal orientation. There is a bug in Unity 3D, because it complains about the resolution not fitting the 2K frame, 1440 is not over 2K!
