I see that many people having problems around same things but I wasn't able to solve my problem by examining them. I bought a custom pc with rog crosshair x670e hero motherboard which has Intel AX210 as Blutooth adaptor and the supported driver seems to be installed. However I can't connect to bluetooth devices even tough they appear in the device list.
JBL Flip 5: It rarely connects and even if it connects it doesn't give sound or give out of sync and low quality sound
HP 350/355 multi-device-bluetooth-keyboard: Can't connect remains as "Not set up" in the list or gives a window that has the pairing number but dissappears in a matter of second.
Ubuntu version:
lsb_release -a
LSB Version: core-11.1.0ubuntu4-noarch:security-11.1.0ubuntu4-noarch
Distributor ID: Ubuntu
Description: Ubuntu 22.04.3 LTS
Release: 22.04
Codename: jammy
Kernel Version:
uname -r
6.2.0-35-generic
Adaptor:
lspci -nnk
08:00.0 Network controller [0280]: Intel Corporation Wi-Fi 6 AX210/AX211/AX411 160MHz [8086:2725] (rev 1a)
Subsystem: Intel Corporation Wi-Fi 6 AX210 160MHz [8086:0024]
Kernel driver in use: iwlwifi
Kernel modules: iwlwifi
$ lsusb
Bus 003 Device 002: ID 8087:0032 Intel Corp. AX210 Bluetooth
drivers:
ls /lib/firmware/intel/ | grep ibt-0041
ibt-0041-0041.ddc
ibt-0041-0041.sfi
sudo dmesg | grep Blu
[ 4.588446] Bluetooth: Core ver 2.22
[ 4.588462] Bluetooth: HCI device and connection manager initialized
[ 4.588464] Bluetooth: HCI socket layer initialized
[ 4.588466] Bluetooth: L2CAP socket layer initialized
[ 4.588469] Bluetooth: SCO socket layer initialized
[ 4.667153] Bluetooth: hci0: Firmware timestamp 2022.5 buildtype 1 build 38020
[ 4.673885] Bluetooth: hci0: Found device firmware: intel/ibt-0041-0041.sfi
[ 4.673893] Bluetooth: hci0: Boot Address: 0x100800
[ 4.673896] Bluetooth: hci0: Firmware Version: 132-5.22
[ 4.673897] Bluetooth: hci0: Firmware already loaded
[ 5.385074] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 5.385077] Bluetooth: BNEP filters: protocol multicast
[ 5.385080] Bluetooth: BNEP socket layer initialized
[ 5.385851] Bluetooth: MGMT ver 1.22
[ 19.775291] Bluetooth: RFCOMM TTY layer initialized
[ 19.775295] Bluetooth: RFCOMM socket layer initialized
[ 19.775298] Bluetooth: RFCOMM ver 1.11
[ 345.172075] Bluetooth: hci0: Opcode 0x 401 failed: -16
[ 454.285254] Bluetooth: hci0: Opcode 0x 401 failed: -16
Even if I manage to connect the keyboard, it would connect and disconnect rapidly then finally disconnect for good. I believe that is the reason why even If I connect the prompts on the screen is delayed or the key presses gets missed.
