For example, it looks like I'll need to start with Ubuntu 23.04 to get support for my hardware. As of this writing this is the non-LTS version, which only has 9 months of support. Will it be possible to upgrade directly from this version to the corresponding LTS release when it becomes available?
No, you will have to upgrade to 23.10 and then to 24.04 ...
But 23.10 is available for download now, so you can skip 23.04 if you want to.
- 7,191
The previous two answers failed to mention that:
- You can start with a non-LTS and upgrade until your reach an LTS (for example, 23.04 → 23.10 → 24.04).
- Once you are on an LTS, you can edit the file
/etc/update-manager/release-upgradesand switch from "normal" (= non-LTS) to "lts". - After that, you will only need to upgrade from LTS to LTS (e.g. 24.04 → 26.04 → 28.04 etc).
If you later decide to switch back to the non-LTS schedule, you should wait until the first non-LTS (following immediately an LTS) is released (for example, 24.04 → 24.10) and edit this file back to "normal".
More information can be found in this answer.
- 13,420
Ubuntu uses a two year development cycle for the LTS; the cycle for 24.04 LTS started just after release of Ubuntu 22.04 LTS or the prior LTS.
The development progress can be seen via the 3 non-LTS releases show the progress; ie. 22.10, 23.04 & 23.10, and you can release-upgrade to that system from the LTS anytime (ie. 22.04 would have release-upgraded to 22.10 after its release, but after it went EOL, the release-upgrade moved you to 23.04 which is where it is currently. Once on that cycle however, you need to release-upgrade through each release as per Soren's answer.
Your alternative is to remain on 22.04 LTS, and after release of Ubuntu 24.04.1, you will be able to release-upgrade from one LTS to the next LTS release.
- 33,561
