I am working on a Dell Inspiron 15 5000 series laptop which is dual booted for Ubuntu 22.04 and Window 11. The /sda5 partition contains the OS while /sda10 partition was for /home. Windows is working fine.
The problem started with a power loss. I skipped the disk check on restart as I was in hurry. However, we lost the power again. The restart blinked on disk check and immediately went to command line “need root password for maintenance”. I tried sudo user password which did not work. After sometime, login screen appeared and I found myself stuck in login loop. Steps taken by me till now: -
- I made a live USB and found that data on
/sda10is fine while/sda5/homewas empty (/home was /sda10). Gparted - Using the excellent comment by Eliah Kagan https://askubuntu.com/a/147023/491560 here I created a root password.
- I tried
fsck -y /dev/sda5andfsck -A -y /dev/sda5which did not show any result. - I rebooted and provided my newly created root password. It led me to command line screen where even fsck was not possible. Login Loop still persisted.
- I used Live USB again and created a new user ‘rec’ with sudo privilege. This got an entry in /home directory.
- I tried
e2fsck -yf /dev/sda5. It actually processed. - On returning to normal login, Login Loop still exists for newly created ‘rec’ user.
- I got following details when I checked the grub edit.
setparams 'Ubuntu...' recordfail set gxfpayload... insmod part_msdos insmod ext2 set root=... search --no-floppy... linux /boot/vmlinuz-2.6.38... initrd /boot/initrd.img-2.6.... - The memtest is giving kernel shim error.
- The
df -Thcommand doesn’t show /sda10 or window partition. Gparted shows all.
The /sda5 and /sda10 partition was not created by me. I was getting some BIOS bugs but system is working fine. I can’t update BIOS as it requires laptop battery.
I have some online programs running. Due to my work, reformatting /sda5 is my last option.
Ask anything more that may be needed. Thank you for your help.
