While upgrading through "Software Updater", it faced with an error:
Could not install the package:
/tmp/apt-dpkg-install-JCuWPV/07-apparmor_2.13.3-7ubuntu5.2_amd64.deb package may not be in working state
Please consider supporting a bug report.
new apparmor package pre-installation script subprocess returened error exit status 1
And it continued. The process ended with could not install upgrade.
The upgrade has aborted. Your system could be in an unstable state. A recovery will run now (dpkg--configure-a)
After which it showed
The upgrade is completed but there were errors during the upgrade process.
The system did not go through cleaning up and restarting process and everything aborted.
What to do now? Should I remove Apparmor package or what reinstall it or what?
Error404
  • 8,278
  • 35
  • 60
Spectra
  • 211
Same problem here. I did:
apt --fix-broken install
apt autoremove
apt update && apt upgrade
And again:
apt upgrade
Then it worked.
