We are upgrading from Ubuntu 18.04 to 22.04 on an m5a.large system in AWS (two vCPUs). We installed GNU Parallel from the Ubuntu repos.
On Ubuntu 18.04:
# parallel --number-of-cores
On Ubuntu 22.04:
Again, these are both on an m5a.large instance (2 vCPUs).
Any idea why parallel is not recognizing the second CPU?
More data on the Ubuntu 22.04 systems. Most things show 2 cores, but some things only show 1. For example:
lscpu shows 2 CPUs:
# lscpu | egrep CPU
CPU op-mode(s):                     32-bit, 64-bit
CPU(s):                             2
On-line CPU(s) list:                0,1
CPU family:                         23
NUMA node0 CPU(s):                  0,1
/proc/cpuinfo shows 2:
# cat /proc/cpuinfo |egrep processor
processor       : 0
processor       : 1
nproc shows 2:
# nproc
dmidecode only shows 1:
# dmidecode -t processor | egrep -i "cpu|core"
        Socket Designation: CPU 0
        Core Count: 1
        Core Enabled: 1
                Multi-Core
getconf shows 2:
# getconf _NPROCESSORS_ONLN
Update: As requested below, the full cpuinfo and lscpu.
cpuinfo:
processor       : 0
vendor_id       : AuthenticAMD
cpu family      : 23
model           : 1
model name      : AMD EPYC 7571
stepping        : 2
microcode       : 0x800126e
cpu MHz         : 2199.738
cache size      : 512 KB
physical id     : 0
siblings        : 2
core id         : 0
cpu cores       : 1
apicid          : 0
initial apicid  : 0
fpu             : yes
fpu_exception   : yes
cpuid level     : 13
wp              : yes
flags           : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ht syscall nx mmxext fxsr_opt pdpe1gb rdtscp lm constant_tsc rep_good nopl nonstop_tsc cpuid extd_apicid aperfmperf tsc_known_freq pni pclmulqdq ssse3 fma cx16 sse4_1 sse4_2 movbe popcnt aes xsave avx f16c rdrand hypervisor lahf_lm cmp_legacy cr8_legacy abm sse4a misalignsse 3dnowprefetch topoext vmmcall fsgsbase bmi1 avx2 smep bmi2 rdseed adx smap clflushopt sha_ni xsaveopt xsavec xgetbv1 clzero xsaveerptr arat npt nrip_save
bugs            : sysret_ss_attrs null_seg spectre_v1 spectre_v2 spec_store_bypass retbleed smt_rsb srso div0
bogomips        : 4399.47
TLB size        : 2560 4K pages
clflush size    : 64
cache_alignment : 64
address sizes   : 48 bits physical, 48 bits virtual
power management:
processor : 1 vendor_id : AuthenticAMD cpu family : 23 model : 1 model name : AMD EPYC 7571 stepping : 2 microcode : 0x800126e cpu MHz : 2199.738 cache size : 512 KB physical id : 0 siblings : 2 core id : 0 cpu cores : 1 apicid : 1 initial apicid : 1 fpu : yes fpu_exception : yes cpuid level : 13 wp : yes flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ht syscall nx mmxext fxsr_opt pdpe1gb rdtscp lm constant_tsc rep_good nopl nonstop_tsc cpuid extd_apicid aperfmperf tsc_known_freq pni pclmulqdq ssse3 fma cx16 sse4_1 sse4_2 movbe popcnt aes xsave avx f16c rdrand hypervisor lahf_lm cmp_legacy cr8_legacy abm sse4a misalignsse 3dnowprefetch topoext vmmcall fsgsbase bmi1 avx2 smep bmi2 rdseed adx smap clflushopt sha_ni xsaveopt xsavec xgetbv1 clzero xsaveerptr arat npt nrip_save bugs : sysret_ss_attrs null_seg spectre_v1 spectre_v2 spec_store_bypass retbleed smt_rsb srso div0 bogomips : 4399.47 TLB size : 2560 4K pages clflush size : 64 cache_alignment : 64 address sizes : 48 bits physical, 48 bits virtual power management:
lscpu:
Architecture:            x86_64   CPU op-mode(s):        32-bit, 64-bit   Address sizes:         48 bits physical, 48 bits virtual   Byte Order:            Little Endian CPU(s):                  2   On-line CPU(s) list:   0,1 Vendor ID:               AuthenticAMD   Model name:            AMD EPYC 7571
    CPU family:          23
    Model:               1
    Thread(s) per core:  2
    Core(s) per socket:  1
    Socket(s):           1
    Stepping:            2
    BogoMIPS:            4399.47
    Flags:               fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ht syscall nx mmxext fxsr_opt pdpe1gb rdtscp lm constant_tsc rep_good nopl nons
                         m sse4a misalignsse 3dnowprefetch topoext vmmcall fsgsbase bmi1 avx2 smep bmi2 rdseed adx smap clflushopt sha_ni xsaveopt xsavec xgetbv1 clzero xsaveerptr arat npt nrip_save Virtualization features:    Hypervisor vendor:     KVM   Virtualization type:   full Caches (sum of all):        L1d:           32 KiB (1 instance)   L1i:                   64 KiB (1 instance)   L2: 512 KiB (1 instance)   L3:                    8 MiB (1 instance) NUMA: NUMA node(s):          1   NUMA node0 CPU(s):     0,1 Vulnerabilities: Gather data sampling:  Not affected   Itlb multihit:         Not affected   L1tf:                  Not affected   Mds:                  Not affected   Meltdown:              Not affected   Mmio stale data:  Not affected   Retbleed:              Mitigation; untrained return thunk; SMT vulnerable   Spec rstack overflow:  Mitigation; safe RET, no microcode   Spec store bypass:     Vulnerable   Spectre v1:         Mitigation; usercopy/swapgs barriers and __user pointer sanitization   Spectre v2:            Mitigation; Retpolines, STIBP disabled, RSB filling, PBRSB-eIBRS Not affected   Srbds:                 Not affected   Tsx async abort:       Not affected
Though I think the real problem is with dmidecode, which only shows one CPU. dmidecode -t processor:
# dmidecode 3.3
Getting SMBIOS data from sysfs.
SMBIOS 2.7 present.
Handle 0x0004, DMI type 4, 42 bytes Processor Information Socket Designation: CPU 0 Type: Central Processor Family: Zen Manufacturer: Advanced Micro Devices, Inc. ID: 12 0F 80 00 FF FB 8B 17 Signature: Family 23, Model 1, Stepping 2 Flags: FPU (Floating-point unit on-chip) VME (Virtual mode extension) DE (Debugging extension) PSE (Page size extension) TSC (Time stamp counter) MSR (Model specific registers) PAE (Physical address extension) MCE (Machine check exception) CX8 (CMPXCHG8 instruction supported) APIC (On-chip APIC hardware supported) SEP (Fast system call) MTRR (Memory type range registers) PGE (Page global enable) MCA (Machine check architecture) CMOV (Conditional move instruction supported) PAT (Page attribute table) PSE-36 (36-bit page size extension) CLFSH (CLFLUSH instruction supported) MMX (MMX technology supported) FXSR (FXSAVE and FXSTOR instructions supported) SSE (Streaming SIMD extensions) SSE2 (Streaming SIMD extensions 2) HTT (Multi-threading) Version: AMD EPYC 7571 Voltage: 1.0 V External Clock: 100 MHz Max Speed: 3000 MHz Current Speed: 2200 MHz Status: Populated, Enabled Upgrade: Socket SP3 L1 Cache Handle: 0x0005 L2 Cache Handle: 0x0006 L3 Cache Handle: 0x0007 Serial Number: Not Specified Asset Tag: Not Specified Part Number: Not Specified Core Count: 1 Core Enabled: 1 Thread Count: 2 Characteristics: 64-bit capable Multi-Core Hardware Thread Execute Protection
