I saw something unusual on my desktop. I deleted it and never saw that I emptied my whole laptop drive, further I emptied the trash moments later. When I noticed it, I tried to recover using Testdisk, seeing How to recover deleted files? and with help of this site: https://www.makeuseof.com/how-to-recover-lost-damaged-data-with-testdisk/
There was no partition in my disk. I started testdisk with creating logfile.`
elect a media (use Arrow keys, then press Enter):
>Disk /dev/sda - 1000 GB / 931 GiB - TOSHIBA MQ01ABD100
 Disk /dev/sdb - 1000 GB / 931 GiB - Seagate Portable
 Disk /dev/mapper/ubuntu--vg-root - 995 GB / 927 GiB - TOSHIBA MQ01ABD100
 Disk /dev/mapper/ubuntu--vg-swap_1 - 4064 MB / 3876 MiB - TOSHIBA MQ01ABD100
 Disk /dev/dm-0 - 995 GB / 927 GiB - TOSHIBA MQ01ABD100
 Disk /dev/dm-1 - 4064 MB / 3876 MiB - TOSHIBA MQ01ABD100
 Disk /dev/loop0 - 66 MB / 63 MiB (RO)
 Disk /dev/loop1 - 521 MB / 496 MiB (RO)
 Disk /dev/loop10 - 470 MB / 448 MiB (RO)
 Disk /dev/loop11 - 524 KB / 512 KiB (RO)
>[Previous]  [  Next  ]  [Proceed ]  [  Quit  ]
I chose >Disk /dev/sda - 1000 GB / 931 GiB - TOSHIBA MQ01ABD100
I got `
Please select the partition table type, press Enter when done. >[Intel ] Intel/PC partition [EFI GPT] EFI GPT partition map (Mac i386, some x86_64...) [Humax ] Humax partition table [Mac ] Apple partition map (legacy) [None ] Non partitioned media [Sun ] Sun Solaris partition [XBox ] XBox partition [Return ] Return to disk selection
` I chose Intel and got
     CHS 121601 255 63 - sector size=512
[ Analyse ] Analyse current partition structure and search for lost partitions >[ Advanced ] Filesystem Utils [ Geometry ] Change disk geometry [ Options ] Modify options [ MBR Code ] Write TestDisk MBR code to first sector [ Delete ] Delete all data in the partition table [ Quit ] Return to disk selection
On Analyse I got `
Disk /dev/sda - 1000 GB / 931 GiB - CHS 121601 255 63
Current partition structure:
     Partition                  Start        End    Size in sectors
1 * Linux 0 32 33 62 53 55 997376 2 E extended 62 86 23 121601 57 56 1952522242 5 L Linux LVM 62 86 25 121601 57 56 1952522240
It was dead-end, it asked nothing to do there. So I got to the previous screen and chose Advaned
It gave me `
Partition Start End Size in sectors > 1 * Linux 0 32 33 62 53 55 997376 2 E extended 62 86 23 121601 57 56 1952522242 5 L Linux LVM 62 86 25 121601 57 56 1952522240
[ Type ] [Superblock] [Undelete] >[Image Creation] [ Quit ]
On choosing the 2nd part > Extended I got only these option: `
[ Type ] >[Image Creation] [ Quit ]
It did not show which files to recover, so I selected to create image of the partition, which gave me `
Please select where to store the file image.dd (999691 MB), an image of the
partition
Keys: Arrow keys to select another directory
      C when the destination is correct
      Q to quit
Directory /home/alpha
>drwxr-xr-x  1000  1000      4096 10-Oct-2023 15:49 .
 drwxr-xr-x     0     0      4096 28-Aug-2022 23:19 ..
 drwxr-xr-x  1000  1000      4096 28-Jun-2023 18:41 Documents
 drwxr-xr-x  1000  1000     12288  7-Oct-2023 15:22 Downloads
 drwxrwxr-x  1000  1000      4096 17-Sep-2023 21:30 Eternal hard disk
 drwxr-xr-x  1000  1000      4096 28-Aug-2022 23:30 Music
 drwxrwxr-x  1000  1000      4096 29-Sep-2023 20:43 Para
 drwxr-xr-x  1000  1000      4096 28-Aug-2022 23:30 Videos
 drwx------  1000  1000      4096  5-Aug-2023 23:18 snap
 -rw-r--r--  1000  1000 1037917997 12-Dec-2022 08:32 Heat1995[13gb].mp4
 -rw-rw-r--  1000  1000     66719 10-Oct-2023 15:49 Screenshot from 2023-10-10 1
 -rw-r--r--  1000  1000 1751858879  6-Oct-2023 22:11 The.Drop.2014.m720p.rar
 -rw-rw-r--  1000  1000       267  6-Oct-2023 22:11 The.Drop.2014.m720p.rar.aria
 -rw-r--r--  1000  1000   1187407 20-Oct-2022 10:07 hrmd2022654.pdf
 -rw-rw-r--  1000  1000      4942 10-Oct-2023 17:07 testdisk.log
This is where I am facing two problems:
  1. It is said not to copy files to the same location where it belonged, so I wanted to copy the files to an external hard drive. My external hard drive it connected to my laptop but the list doesn't show it. So I cannot choose it.
  2. I don't have an empty 1TB External HDD ready in my hands to copy that image.
So what to to?
Note: I did not use the drive to copy other files, so nothing is overwritten. I just downloaded Testdisk.
Edit 1: I never had to use passcode to open my folders. or used any to my laptop drive. I only have to give password when opening my laptop ie when the ubuntu screen comes.
"Encryption would require you to enter a passphrase when you turn the computer on, before the login password." -- No such passphrase was required for me before user login password.
Edit 2: "What happens if you choose option "5 L Linux LVM"? It may give you more options with folders and files." -- Nothing other than the imaging option.
Partition Start End Size in sectors 1 * Linux 0 32 33 62 53 55 997376 2 E extended 62 86 23 121601 57 56 1952522242 > 5 L Linux LVM 62 86 25 121601 57 56 1952522240
Spectra
  • 211
