I bought a Lenovo ThinkPad X1 Yoga Gen 7 with:
  32 GiB RAM
  CPU: 12th Gen Intel Core i7-1260P x 16
  Mesa Intel Graphics (ADL GT2)
  SSD: 2 TB
  FHD camera system with 4 microphones   3840x2400 Display which implies a MiPi camera as I     learned*
and installed Ubuntu 23.04.
* I wasn't able to detect the camera hardware with Linux or Windows. I found "MiPi" by research.
As far as I tested yet everything works well except the build in camera. I could not test the microphones yet.
It seems to be a well-known problem similar to this question
I tried to follow the described solution. Unfortunately the build of the icamerasrc.git fails because the prior installed libcamhal is not found. I am not very experiences with building and installing manually on my system, so I probably made beginner's mistakes, and any help is appreciated.
What I tried in detail:
First I installed Ubuntu 22.04. After it failed I tried Ubuntu 20.04.06 because some ThinkPads of this kind was sold with Ubuntu 20.04, but it failed again. Now I have Ubuntu 23.04, and I am still trying to get it work.
I realized that there are some packages needed that are not installed by default like dkms and git. Also I assume working with sudo should work, but since I don't know what causes the problem, I tried installing it as root. Then I got some problems that where caused by a path which contained spaces. I came from macOS and got surprised. Anyway I eliminated the unnecessary spaces.
What I actually did at last was this:
sudo su
mkdir -p /media/data/shared/Installer/Linux/avp/Lenovo_ThinkPad_X1_Yoga_Gen_7_internal_Cam/
cd /media/data/shared/Installer/Linux/avp/Lenovo_ThinkPad_X1_Yoga_Gen_7_internal_Cam/
sudo apt-get update
sudo apt-get upgrade
sudo apt-get install git build-essential dkms cmake libdrm-dev v4l-utils libexpat-dev automake libtool libgstreamer1.0-dev libgstreamer-plugins-base1.0-dev
Hinweis: »libexpat1-dev« wird an Stelle von »libexpat-dev« gewählt.
git clone https://github.com/intel/ipu6-drivers.git
cd ipu6-drivers
git clone https://github.com/intel/ivsc-driver.git
cp -r ivsc-driver/backport-include ivsc-driver/drivers ivsc-driver/include .
rm -rf ivsc-driver
cd ..
git clone https://github.com/intel/ipu6-camera-bins.git
git clone https://github.com/intel/ipu6-camera-hal.git
git clone https://github.com/intel/icamerasrc.git
cd icamerasrc/
git checkout icamerasrc_slim_api
cd ..
cp ipu6-camera-hal/build.sh .
cd ipu6-drivers
sudo dkms add .
sudo dkms autoinstall ipu6-drivers/0.0.0
cd ..
sudo cp -r ipu6-camera-bins/include/* /usr/include/
sudo cp -r ipu6-camera-bins/lib/* /usr/lib/
sudo ./build.sh
Libraries have been installed in:
   /media/data/shared/Installer/Linux/avp/Lenovo_ThinkPad_X1_Yoga_Gen_7_internal_Cam/out/install/lib/gstreamer-1.0
###############   build_icamerasrc  OK   #############
sudo cp -r ./out/install/include/* /usr/include
sudo cp -r ./out/install/lib/* /usr/lib
sudo cp -r ./out/install/share/* /usr/share
cd icamerasrc
export CHROME_SLIM_CAMHAL=ON
export PKG_CONFIG_PATH="/usr/lib/x86_64-linux-gnu/pkgconfig"
sudo ./autogen.sh
Building with libcamhal
checking for libcamhal... no
configure: error: Cannot find libcamhal pkgconfig
configure failed
Though I just installed ipu6-camera-hal it is not recognized as libcamhal. Is this something different? Did I forget an important step? ./out contains among other things:
out/install/lib/libhal_adaptor.so
out/install/lib/libgsticamerainterface-1.0.so
out/install/lib/ipu_mtl/libcamhal.so
out/install/lib/gstreamer-1.0/libgsticamerasrc.so
out/install/lib/ipu_tgl/libcamhal.so
out/install/lib/ipu_adl/libcamhal.so
Aren't these the libs which are just installed by copying them to /usr/lib?
As requested here are some outputs:
$ sudo dmesg|grep ipu6
[    3.935647] intel-ipu6 0000:00:05.0: enabling device (0000 -> 0002)
[    3.935884] intel-ipu6 0000:00:05.0: Device 0x465d (rev: 0x2)
[    3.935906] intel-ipu6 0000:00:05.0: physical base address 0x603c000000
[    3.935908] intel-ipu6 0000:00:05.0: mapped as: 0x000000000721f56d
[    3.935954] intel-ipu6 0000:00:05.0: IPU in secure mode
[    3.935956] intel-ipu6 0000:00:05.0: IPU secure touch = 0x0
[    3.935957] intel-ipu6 0000:00:05.0: IPU camera mask = 0xff
[    3.952548] intel-ipu6 0000:00:05.0: IPC reset done
[    3.952552] intel-ipu6 0000:00:05.0: cpd file name: intel/ipu6ep_fw.bin
[    3.953693] intel-ipu6 0000:00:05.0: FW version: 20230102
[    3.962943] intel-ipu6 0000:00:05.0: Device 0x465d (rev: 0x2)
[    3.962966] intel-ipu6 0000:00:05.0: physical base address 0x603c000000
[    3.962968] intel-ipu6 0000:00:05.0: mapped as: 0x00000000d3a0191d
[    3.963175] intel-ipu6 0000:00:05.0: IPU in secure mode
[    3.963177] intel-ipu6 0000:00:05.0: IPU secure touch = 0x0
[    3.963179] intel-ipu6 0000:00:05.0: IPU camera mask = 0xff
[    3.968141] intel-ipu6 0000:00:05.0: IPC reset done
[    3.968144] intel-ipu6 0000:00:05.0: cpd file name: intel/ipu6ep_fw.bin
[    3.968273] intel-ipu6 0000:00:05.0: FW version: 20230102
[    3.971715] intel-ipu6 0000:00:05.0: Device 0x465d (rev: 0x2)
[    3.971737] intel-ipu6 0000:00:05.0: physical base address 0x603c000000
[    3.971739] intel-ipu6 0000:00:05.0: mapped as: 0x000000000721f56d
[    3.971777] intel-ipu6 0000:00:05.0: IPU in secure mode
[    3.971779] intel-ipu6 0000:00:05.0: IPU secure touch = 0x0
[    3.971780] intel-ipu6 0000:00:05.0: IPU camera mask = 0xff
[    3.974112] intel-ipu6 0000:00:05.0: IPC reset done
[    3.974115] intel-ipu6 0000:00:05.0: cpd file name: intel/ipu6ep_fw.bin
[    3.974204] intel-ipu6 0000:00:05.0: FW version: 20230102
[    3.982624] intel-ipu6 0000:00:05.0: Device 0x465d (rev: 0x2)
[    3.982640] intel-ipu6 0000:00:05.0: physical base address 0x603c000000
[    3.982642] intel-ipu6 0000:00:05.0: mapped as: 0x00000000d3a0191d
[    3.982680] intel-ipu6 0000:00:05.0: IPU in secure mode
[    3.982682] intel-ipu6 0000:00:05.0: IPU secure touch = 0x0
[    3.982683] intel-ipu6 0000:00:05.0: IPU camera mask = 0xff
[    3.987948] intel-ipu6 0000:00:05.0: IPC reset done
[    3.987951] intel-ipu6 0000:00:05.0: cpd file name: intel/ipu6ep_fw.bin
[    3.988080] intel-ipu6 0000:00:05.0: FW version: 20230102
[    3.991085] intel-ipu6 0000:00:05.0: Device 0x465d (rev: 0x2)
[    3.991101] intel-ipu6 0000:00:05.0: physical base address 0x603c000000
[    3.991103] intel-ipu6 0000:00:05.0: mapped as: 0x000000005eca06cc
[    3.991145] intel-ipu6 0000:00:05.0: IPU in secure mode
[    3.991146] intel-ipu6 0000:00:05.0: IPU secure touch = 0x0
[    3.991148] intel-ipu6 0000:00:05.0: IPU camera mask = 0xff
[    3.993267] intel-ipu6 0000:00:05.0: IPC reset done
[    3.993270] intel-ipu6 0000:00:05.0: cpd file name: intel/ipu6ep_fw.bin
[    3.993351] intel-ipu6 0000:00:05.0: FW version: 20230102
[    4.000086] intel-ipu6 0000:00:05.0: Device 0x465d (rev: 0x2)
[    4.000108] intel-ipu6 0000:00:05.0: physical base address 0x603c000000
[    4.000110] intel-ipu6 0000:00:05.0: mapped as: 0x000000005cc98771
[    4.000150] intel-ipu6 0000:00:05.0: IPU in secure mode
[    4.000152] intel-ipu6 0000:00:05.0: IPU secure touch = 0x0
[    4.000153] intel-ipu6 0000:00:05.0: IPU camera mask = 0xff
[    4.005098] intel-ipu6 0000:00:05.0: IPC reset done
[    4.005100] intel-ipu6 0000:00:05.0: cpd file name: intel/ipu6ep_fw.bin
[    4.005171] intel-ipu6 0000:00:05.0: FW version: 20230102
[    4.016569] intel-ipu6 0000:00:05.0: Device 0x465d (rev: 0x2)
[    4.016584] intel-ipu6 0000:00:05.0: physical base address 0x603c000000
[    4.016586] intel-ipu6 0000:00:05.0: mapped as: 0x00000000d3a0191d
[    4.016618] intel-ipu6 0000:00:05.0: IPU in secure mode
[    4.016619] intel-ipu6 0000:00:05.0: IPU secure touch = 0x0
[    4.016621] intel-ipu6 0000:00:05.0: IPU camera mask = 0xff
[    4.020530] intel-ipu6 0000:00:05.0: IPC reset done
[    4.020532] intel-ipu6 0000:00:05.0: cpd file name: intel/ipu6ep_fw.bin
[    4.020631] intel-ipu6 0000:00:05.0: FW version: 20230102
[    4.036195] intel-ipu6 0000:00:05.0: Device 0x465d (rev: 0x2)
[    4.036209] intel-ipu6 0000:00:05.0: physical base address 0x603c000000
[    4.036210] intel-ipu6 0000:00:05.0: mapped as: 0x000000005eca06cc
[    4.036235] intel-ipu6 0000:00:05.0: IPU in secure mode
[    4.036236] intel-ipu6 0000:00:05.0: IPU secure touch = 0x0
[    4.036237] intel-ipu6 0000:00:05.0: IPU camera mask = 0xff
[    4.040313] intel-ipu6 0000:00:05.0: IPC reset done
[    4.040316] intel-ipu6 0000:00:05.0: cpd file name: intel/ipu6ep_fw.bin
[    4.040424] intel-ipu6 0000:00:05.0: FW version: 20230102
[    4.052389] intel-ipu6 0000:00:05.0: Device 0x465d (rev: 0x2)
[    4.052424] intel-ipu6 0000:00:05.0: physical base address 0x603c000000
[    4.052426] intel-ipu6 0000:00:05.0: mapped as: 0x000000000721f56d
[    4.052472] intel-ipu6 0000:00:05.0: IPU in secure mode
[    4.052475] intel-ipu6 0000:00:05.0: IPU secure touch = 0x0
[    4.052477] intel-ipu6 0000:00:05.0: IPU camera mask = 0xff
[    4.054276] intel-ipu6 0000:00:05.0: IPC reset done
[    4.054279] intel-ipu6 0000:00:05.0: cpd file name: intel/ipu6ep_fw.bin
[    4.054385] intel-ipu6 0000:00:05.0: FW version: 20230102
[    4.079801] intel-ipu6 0000:00:05.0: Device 0x465d (rev: 0x2)
[    4.079830] intel-ipu6 0000:00:05.0: physical base address 0x603c000000
[    4.079832] intel-ipu6 0000:00:05.0: mapped as: 0x00000000d3a0191d
[    4.079898] intel-ipu6 0000:00:05.0: IPU in secure mode
[    4.079899] intel-ipu6 0000:00:05.0: IPU secure touch = 0x0
[    4.079901] intel-ipu6 0000:00:05.0: IPU camera mask = 0xff
[    4.083581] intel-ipu6 0000:00:05.0: IPC reset done
[    4.083584] intel-ipu6 0000:00:05.0: cpd file name: intel/ipu6ep_fw.bin
[    4.083661] intel-ipu6 0000:00:05.0: FW version: 20230102
[    4.147389] intel-ipu6 0000:00:05.0: Device 0x465d (rev: 0x2)
[    4.147410] intel-ipu6 0000:00:05.0: physical base address 0x603c000000
[    4.147411] intel-ipu6 0000:00:05.0: mapped as: 0x00000000d3a0191d
[    4.147472] intel-ipu6 0000:00:05.0: IPU in secure mode
[    4.147475] intel-ipu6 0000:00:05.0: IPU secure touch = 0x0
[    4.147476] intel-ipu6 0000:00:05.0: IPU camera mask = 0xff
[    4.149845] intel-ipu6 0000:00:05.0: IPC reset done
[    4.149848] intel-ipu6 0000:00:05.0: cpd file name: intel/ipu6ep_fw.bin
[    4.150028] intel-ipu6 0000:00:05.0: FW version: 20230102
[    4.191684] intel-ipu6 0000:00:05.0: Device 0x465d (rev: 0x2)
[    4.191708] intel-ipu6 0000:00:05.0: physical base address 0x603c000000
[    4.191710] intel-ipu6 0000:00:05.0: mapped as: 0x0000000002ee22b0
[    4.191756] intel-ipu6 0000:00:05.0: IPU in secure mode
[    4.191758] intel-ipu6 0000:00:05.0: IPU secure touch = 0x0
[    4.191759] intel-ipu6 0000:00:05.0: IPU camera mask = 0xff
[    4.193603] intel-ipu6 0000:00:05.0: IPC reset done
[    4.193605] intel-ipu6 0000:00:05.0: cpd file name: intel/ipu6ep_fw.bin
[    4.193716] intel-ipu6 0000:00:05.0: FW version: 20230102
[    4.262608] intel-ipu6 0000:00:05.0: Device 0x465d (rev: 0x2)
[    4.262621] intel-ipu6 0000:00:05.0: physical base address 0x603c000000
[    4.262622] intel-ipu6 0000:00:05.0: mapped as: 0x0000000002ee22b0
[    4.262722] intel-ipu6 0000:00:05.0: IPU in secure mode
[    4.262725] intel-ipu6 0000:00:05.0: IPU secure touch = 0x0
[    4.262727] intel-ipu6 0000:00:05.0: IPU camera mask = 0xff
[    4.264803] intel-ipu6 0000:00:05.0: IPC reset done
[    4.264805] intel-ipu6 0000:00:05.0: cpd file name: intel/ipu6ep_fw.bin
[    4.264943] intel-ipu6 0000:00:05.0: FW version: 20230102
[    4.299846] intel-ipu6 0000:00:05.0: Device 0x465d (rev: 0x2)
[    4.299857] intel-ipu6 0000:00:05.0: physical base address 0x603c000000
[    4.299859] intel-ipu6 0000:00:05.0: mapped as: 0x00000000c6ca14e3
[    4.299888] intel-ipu6 0000:00:05.0: IPU in secure mode
[    4.299891] intel-ipu6 0000:00:05.0: IPU secure touch = 0x0
[    4.299892] intel-ipu6 0000:00:05.0: IPU camera mask = 0xff
[    4.301706] intel-ipu6 0000:00:05.0: IPC reset done
[    4.301707] intel-ipu6 0000:00:05.0: cpd file name: intel/ipu6ep_fw.bin
[    4.301837] intel-ipu6 0000:00:05.0: FW version: 20230102
[    4.319503] intel-ipu6 0000:00:05.0: Device 0x465d (rev: 0x2)
[    4.319523] intel-ipu6 0000:00:05.0: physical base address 0x603c000000
[    4.319525] intel-ipu6 0000:00:05.0: mapped as: 0x00000000cf4333ff
[    4.319564] intel-ipu6 0000:00:05.0: IPU in secure mode
[    4.319565] intel-ipu6 0000:00:05.0: IPU secure touch = 0x0
[    4.319567] intel-ipu6 0000:00:05.0: IPU camera mask = 0xff
[    4.321381] intel-ipu6 0000:00:05.0: IPC reset done
[    4.321382] intel-ipu6 0000:00:05.0: cpd file name: intel/ipu6ep_fw.bin
[    4.321488] intel-ipu6 0000:00:05.0: FW version: 20230102
[    4.323547] intel-ipu6 0000:00:05.0: Found supported sensor INT3474:01
[    4.323651] intel-ipu6 0000:00:05.0: Connected 1 cameras
[    4.324616] intel-ipu6 0000:00:05.0: Sending BOOT_LOAD to CSE
[    4.333343] intel-ipu6 0000:00:05.0: Sending AUTHENTICATE_RUN to CSE
[    4.401681] intel-ipu6 0000:00:05.0: CSE authenticate_run done
[    4.401698] intel-ipu6 0000:00:05.0: IPU6-v3 driver version 1.0
[    4.403190] intel-ipu6-isys intel-ipu6-isys0: bind ov2740 5-0036 nlanes is 2 port is 1
[    4.411593] intel-ipu6-isys intel-ipu6-isys0: All sensor registration completed.
[    4.411836] intel-ipu6-psys intel-ipu6-psys0: pkg_dir entry count:8
[    4.411955] intel-ipu6-psys intel-ipu6-psys0: psys probe minor: 0
[    7.312145] intel-ipu6-isys intel-ipu6-isys0: isys port open ready failed -16
[    7.312152] intel-ipu6-isys intel-ipu6-isys0: Device close failure: -16
[    8.460580] intel-ipu6-isys intel-ipu6-isys0: isys port open ready failed -16
[    8.460618] intel-ipu6-isys intel-ipu6-isys0: Device close failure: -16
[213694.863767] intel-ipu6 0000:00:05.0: IPU in secure mode
[257080.442282] intel-ipu6 0000:00:05.0: IPU in secure mode
$ lspci -nn
00:00.0 Host bridge [0600]: Intel Corporation Device [8086:4621] (rev 02)
00:02.0 VGA compatible controller [0300]: Intel Corporation Alder Lake-P Integrated Graphics Controller [8086:46a6] (rev 0c)
00:04.0 Signal processing controller [1180]: Intel Corporation Alder Lake Innovation Platform Framework Processor Participant [8086:461d] (rev 02)
00:05.0 Multimedia controller [0480]: Intel Corporation Device [8086:465d] (rev 02)
00:06.0 PCI bridge [0604]: Intel Corporation 12th Gen Core Processor PCI Express x4 Controller #0 [8086:464d] (rev 02)
00:07.0 PCI bridge [0604]: Intel Corporation Alder Lake-P Thunderbolt 4 PCI Express Root P[edit] ort #0 [8086:466e] (rev 02)
00:07.2 PCI bridge [0604]: Intel Corporation Alder Lake-P Thunderbolt 4 PCI Express Root Port #2 [8086:462f] (rev 02)
00:08.0 System peripheral [0880]: Intel Corporation 12th Gen Core Processor Gaussian & Neural Accelerator [8086:464f] (rev 02)
00:0a.0 Signal processing controller [1180]: Intel Corporation Platform Monitoring Technology [8086:467d] (rev 01)
00:0d.0 USB controller [0c03]: Intel Corporation Alder Lake-P Thunderbolt 4 USB Controller [8086:461e] (rev 02)
00:0d.2 USB controller [0c03]: Intel Corporation Alder Lake-P Thunderbolt 4 NHI #0 [8086:463e] (rev 02)
00:0d.3 USB controller [0c03]: Intel Corporation Alder Lake-P Thunderbolt 4 NHI #1 [8086:466d] (rev 02)
00:12.0 Serial controller [0700]: Intel Corporation Alder Lake-P Integrated Sensor Hub [8086:51fc] (rev 01)
00:14.0 USB controller [0c03]: Intel Corporation Alder Lake PCH USB 3.2 xHCI Host Controller [8086:51ed] (rev 01)
00:14.2 RAM memory [0500]: Intel Corporation Alder Lake PCH Shared SRAM [8086:51ef] (rev 01)
00:14.3 Network controller [0280]: Intel Corporation Alder Lake-P PCH CNVi WiFi [8086:51f0] (rev 01)
00:15.0 Serial bus controller [0c80]: Intel Corporation Alder Lake PCH Serial IO I2C Controller #0 [8086:51e8] (rev 01)
00:15.1 Serial bus controller [0c80]: Intel Corporation Alder Lake PCH Serial IO I2C Controller #1 [8086:51e9] (rev 01)
00:16.0 Communication controller [0780]: Intel Corporation Alder Lake PCH HECI Controller [8086:51e0] (rev 01)
00:19.0 Serial bus controller [0c80]: Intel Corporation Alder Lake-P Serial IO I2C Controller #0 [8086:51c5] (rev 01)
00:1c.0 PCI bridge [0604]: Intel Corporation Device [8086:51b8] (rev 01)
00:1f.0 ISA bridge [0601]: Intel Corporation Alder Lake PCH eSPI Controller [8086:5182] (rev 01)
00:1f.3 Audio device [0403]: Intel Corporation Alder Lake PCH-P High Definition Audio Controller [8086:51c8] (rev 01)
00:1f.4 SMBus [0c05]: Intel Corporation Alder Lake PCH-P SMBus Host Controller [8086:51a3] (rev 01)
00:1f.5 Serial bus controller [0c80]: Intel Corporation Alder Lake-P PCH SPI Controller [8086:51a4] (rev 01)
04:00.0 Non-Volatile memory controller [0108]: Samsung Electronics Co Ltd NVMe SSD Controller PM9A1/PM9A3/980PRO [144d:a80a]
08:00.0 Wireless controller [0d40]: Intel Corporation XMM7560 LTE Advanced Pro Modem [8086:7560] (rev 01)
karel
  • 122,292
  • 133
  • 301
  • 332
tmj
  1. Install Ubuntu 22.04.3. It includes the latest Linux kernel 6.2.0.34.
  2. Install all software updates that are offered by the Software Updater.
  3. Run the following commands in a terminal:
    sudo apt update
    sudo apt upgrade
    sudo apt full-upgrade
    sudo apt install linux-modules-ipu6-generic-hwe-22.04 linux-modules-ivsc-generic-hwe-22.04
    sudo add-apt-repository ppa:oem-solutions-group/intel-ipu6
    sudo apt install libcamhal0 v4l2loopback-dkms v4l2-relayd v4l-utils vlc
    sudo reboot
Now you can use VLC with the camera as a recording device.
karel
  • 122,292
  • 133
  • 301
  • 332
