I've looked through a million threads on this topic but nothing has worked. I'm trying to ssh into my linux through port 22. Connection is refused.
- UFW is inactive and firewall-cmd is not downloaded
- SSH Server is active and up to date
- Tried changing default port in /etc/ssh/sshd_config and restart systemctl and specifying new port in ssh attempt
- Purged and reinstalled openssh-client openssh-server
- I can ssh back and forth between two mac machines on the same wifi network
- ssh was working at one point with same client and same IP address and stopped seemingly at random and has not worked since.
- Verified that client is trying to connect to the current IP address. Again- ssh between other machines on this network works. It is just an issue with the linux machine receiving an ssh request
- Ping [ip address] output from the computer I am trying to remote into outputs a response, but pinging from the client displays request time out
- This is a company wide network so I do not have access to the routers. But again, I have ruled out an upstream network issues because of points 5 and 7 above
- I can access the host remotely with no issues using propriety software (AnyDesk)
- The server (Ubuntu 20.04) seems to only be blocking Mac OS from ssh. SSH from Windows 11 running on same network works fine. Tried on 3 different Mac OS machines all running different versions of Mac OS on the same network as the server and ssh timed out on each one.
Requested output of -vvv user_id@ip_address:
OpenSSH_9.0p1, LibreSSL 3.3.6
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: /etc/ssh/ssh_config line 21: include /etc/ssh/ssh_config.d/* matched no files
debug1: /etc/ssh/ssh_config line 54: Applying options for *
debug2: resolve_canonicalize: hostname 172.xx.xxx.16 is address
debug3: expanded UserKnownHostsFile '~/.ssh/known_hosts' -> '/Users/samcentanni/.ssh/known_hosts'
debug3: expanded UserKnownHostsFile '~/.ssh/known_hosts2' -> '/Users/samcentanni/.ssh/known_hosts2'
debug1: Authenticator provider $SSH_SK_PROVIDER did not resolve; disabling
debug3: ssh_connect_direct: entering
debug1: Connecting to 172.xx.xxx.16 [172.xx.xxx.16] port 22.
debug3: set_sock_tos: set socket 3 IP_TOS 0x48
debug1: connect to address 172.xx.xxx.16 port 22: Operation timed out
ssh: connect to host 172.xx.xxx.16 port 22: Operation timed out
requested output of service sshd status
ssh.service - OpenBSD Secure Shell server
Loaded: loaded (/lib/systemd/system/ssh.service; enabled; vendor preset: e>
Active: active (running) since Tue 2023-10-03 09:42:22 EDT; 24h ago
Docs: man:sshd(8)
man:sshd_config(5)
Process: 2475 ExecStartPre=/usr/sbin/sshd -t (code=exited, status=0/SUCCESS)
Main PID: 2535 (sshd)
Tasks: 1 (limit: 629145)
Memory: 2.4M
CGroup: /system.slice/ssh.service
└─2535 sshd: /usr/sbin/sshd -D [listener] 0 of 10-100 startups
Oct 03 09:42:22 user systemd[1]: Starting OpenBSD Secure Shell server...
Oct 03 09:42:22 user sshd[2535]: Server listening on 0.0.0.0 port 22.
Oct 03 09:42:22 user sshd[2535]: Server listening on :: port 22.
Oct 03 09:42:22 user systemd[1]: Started OpenBSD Secure Shell server.
Oct 03 09:42:22 user sshd[2788]: Unable to negotiate with 127.0.0.1 port 56816: no matching host key type found. Their offer: ssh-dss [preauth]
Oct 03 09:42:22 user sshd[2789]: Connection closed by 127.0.0.1 port 56824 [preauth]
Oct 03 09:42:22 user sshd[2790]: Connection closed by 127.0.0.1 port 56834 [preauth]
Oct 03 09:42:22 user sshd[2792]: Connection closed by 127.0.0.1 port 56836 [preauth]
Oct 03 09:42:22 user sshd[2794]: Unable to negotiate with 127.0.0.1 port 56842: no matching host key type found. Their offer: sk-ecdsa-sha2-nistp256@openssh.com [preauth]
Oct 03 09:42:22 user sshd[2795]: Unable to negotiate with 127.0.0.1 port 56844: no matching host key type found. Their offer: sk-ssh-ed25519@openssh.com [preauth]
