I'm new to Ubuntu desktop from Windows, installed it yesterday. It was working fine, except ACPI error. But today I'm getting error while booting my machine.
[ 0.274572] ACPI BIOS Error (bug): Could not resolve symbol [_SB.PCIO.GPP2.BCM5], AE_NOT_FOUND (20210730/dswload2-162)
[ 0.274580] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20210730/ps
/dev/sda2: clean, 449907/61022208 files, 9220737/244059136 blocks
[FAILED] Failed to activate swap /swapfile.
[DEPEND] Dependency failed for Swaps.
[FAILED] Failed to start Userspace Out-Of-Memory (00M) Killer.
[FAILED] Failed to start Network Name Resolution.
[FAILED] Failed to start Network Time Synchronization.
[FAILED] Failed to start Userspace Out-Of-Memory (OOM) Killer.
[ 11.659491] ACPI BIOS Error (bug): Attempt to CreateField of length zero (202
[ 11.659550] ACPI Error: Aborting method HWMC due to previous error (AE_AML_O
[ 11.659571] ACPI Error: Aborting method \_SB.WMID.WMAA due to previous error
[ 11.685486] ACPI BIOS Error (bug): Attempt to CreateField of length zero (202
[ 11.685547] ACPI Error: Aborting method HWMC due to previous error (AE_AML_O
[ 11.685571] ACPI Error: Aborting method_SB.WMID.WMAA due to previous error
/etc/fstab
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point> <type> <options> <dump> <pass>
# / was on /dev/sda2 during installation
# /boot/efi was on /dev/sda1 during installation
/swapfile none swap sw 0 0
blkid
/dev/sda2: UUID="3554c80c-3021-48ef-b6c2-cd4a7f2ef468" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="9f17a076-e829-4e4f-be84-620be099dd9f"
/dev/sda1: UUID="0535-3488" BLOCK_SIZE="512" TYPE="vfat" PARTLABEL="EFI System Partition" PARTUUID="48f08ef9-73e2-4c60-862c-77519bdf4dba"
NAME FSTYPE FSVER LABEL UUID                                 FSAVAIL FSUSE% MOUNTPOINTS
sda sda1 vfat FAT32 0535-34B8 sda2 ext4 1.0 3554c80c-3021-48ef-b6c2-cd4a7f2ef468 849.3G 2% /
Gourav
/etc/fstab
sudo pico /etc/fstab
there 2 lines were missing
/dev/sda2 / ext4 errors=remount-ro 0 1
and
/dev/sda1 /boot/efi vfat defaults 0 1
Gourav
The ACPI (your powermanagement) errors happen on all of my machines - nothing to worry about.
Your problem is:
Corrected answer:
The “OOM Killer” or “Out of Memory Killer” is a process that the Linux kernel employs when the system is critically low on memory. This situation occurs because processes on your device are consuming a large amount of memory, and the system requires more memory for its own processes and to allocate to other processes.
As Jos pointed out it is not the disk space, but the memory that is missing. To fix this you might have to disable some services which are using that memory. The command free will show, how much memory is used in the system.
Concerning the swap problem. Someone asked this before, maybe your harddisk is readOnly (which will prevent creating any files)
kanehekili
  • 7,426
