I want to built a docker image on my Intel laptop. The image will be deployed on both x86/x64 and arm64 hosts. The docker file uses ubuntu:20.04 base image. I tried building the image with following command:
docker buildx build . --no-cache --progress plain --platform linux/arm64/v8,linux/amd64 -t mytag
But it fails with error:
#10 [linux/arm64  3/17] RUN apt update &&     apt install -y --no-install-recommends software-properties-common &&     add-apt-repository -y ppa:ubuntu-toolchain-r/test &&     add-apt-repository -y "deb http://security.ubuntu.com/ubuntu xenial-security main" &&     add-apt-repository -y ppa:deadsnakes/ppa  &&     apt-get update &&     apt-get install -y --no-install-recommends     sudo     usbutils     libcanberra-gtk3-module ...*
#10 191.3 Reading package lists...
#10 195.6 E: Failed to fetch http://security.ubuntu.com/ubuntu/dists/xenial-security/main/binary-arm64/Packages  404  Not Found [IP: 185.125.190.39 80]
#10 195.6 E: Some index files failed to download. They have been ignored, or old ones used instead.
#10 ERROR: process "/bin/sh -c apt update &&     apt install -y --no-install-recommends software-properties-common &&     add-apt-repository -y ppa:ubuntu-toolchain-r/test &&     add-apt-repository -y \"deb http://security.ubuntu.com/ubuntu xenial-security main\" &&     add-apt-repository -y ppa:deadsnakes/ppa  &&     apt-get update &&     apt-get install -y --no-install-recommends     sudo     usbutils     libcanberra-gtk3-module ..." did not complete successfully: exit code: 100
Referring to this answer, I added following lines to my Dockerfile:
## add arm64 architecture
RUN apt-get update
RUN dpkg --add-architecture arm64
arch-qualify the current repositories
RUN sed -i "s/deb h/deb [arch=amd64] h/g" /etc/apt/sources.list
add arm64's repos
RUN echo "# arm64 repositories" >> /etc/apt/sources.list RUN echo "deb [arch=arm64] http://ports.ubuntu.com/ubuntu-ports focal main restricted" >> /etc/apt/sources.list RUN echo "deb [arch=arm64] http://ports.ubuntu.com/ubuntu-ports focal-updates main restricted" >> /etc/apt/sources.list RUN echo "deb [arch=arm64] http://ports.ubuntu.com/ubuntu-ports focal universe" >> /etc/apt/sources.list RUN echo "deb [arch=arm64] http://ports.ubuntu.com/ubuntu-ports focal-updates universe" >> /etc/apt/sources.list RUN echo "deb [arch=arm64] http://ports.ubuntu.com/ubuntu-ports focal multiverse" >> /etc/apt/sources.list RUN echo "deb [arch=arm64] http://ports.ubuntu.com/ubuntu-ports focal-updates multiverse" >> /etc/apt/sources.list RUN echo "deb [arch=arm64] http://ports.ubuntu.com/ubuntu-ports focal-backports main restricted universe multiverse" >> /etc/apt/sources.list RUN echo "deb [arch=arm64] http://ports.ubuntu.com/ubuntu-ports focal-security main restricted" >> /etc/apt/sources.list RUN echo "deb [arch=arm64] http://ports.ubuntu.com/ubuntu-ports focal-security universe" >> /etc/apt/sources.list RUN echo "deb [arch=arm64] http://ports.ubuntu.com/ubuntu-ports focal-security multiverse" >> /etc/apt/sources.list
But now it gives me following error:
#23 19.23 E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/focal/main/binary-amd64/Packages  404  Not Found [IP: 185.125.190.39 80]
#23 19.23 E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/focal-updates/multiverse/binary-amd64/Packages  404  Not Found [IP: 185.125.190.39 80]
#23 19.23 E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/focal-backports/main/binary-amd64/Packages  404  Not Found [IP: 185.125.190.39 80]
#23 19.23 E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/focal-security/multiverse/binary-amd64/Packages  404  Not Found [IP: 185.125.190.39 80]
#23 19.23 E: Some index files failed to download. They have been ignored, or old ones used instead.
#23 19.23 W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list:3 and /etc/apt/sources.list:51 #23 19.23 W: Target Packages (restricted/binary-all/Packages) is configured multiple times in /etc/apt/sources.list:3 and /etc/apt/sources.list:51 #23 19.24 W: Target Packages (universe/binary-all/Packages) is configured multiple times in /etc/apt/sources.list:14 and /etc/apt/sources.list:53 #23 19.24 W: Target Packages (multiverse/binary-all/Packages) is configured multiple times in /etc/apt/sources.list:24 and /etc/apt/sources.list:55 #23 19.24 W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list:8 and /etc/apt/sources.list:52 #23 19.24 W: Target Packages (restricted/binary-all/Packages) is configured multiple times in /etc/apt/sources.list:8 and /etc/apt/sources.list:52 #23 19.24 W: Target Packages (universe/binary-all/Packages) is configured multiple times in /etc/apt/sources.list:16 and /etc/apt/sources.list:54 #23 19.24 W: Target Packages (multiverse/binary-all/Packages) is configured multiple times in /etc/apt/sources.list:26 and /etc/apt/sources.list:56 #23 19.24 W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list:34 and /etc/apt/sources.list:57 #23 19.24 W: Target Packages (restricted/binary-all/Packages) is configured multiple times in /etc/apt/sources.list:34 and /etc/apt/sources.list:57 #23 19.24 W: Target Packages (universe/binary-all/Packages) is configured multiple times in /etc/apt/sources.list:34 and /etc/apt/sources.list:57 #23 19.24 W: Target Packages (multiverse/binary-all/Packages) is configured multiple times in /etc/apt/sources.list:34 and /etc/apt/sources.list:57 #23 19.24 W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list:44 and /etc/apt/sources.list:58 #23 19.24 W: Target Packages (restricted/binary-all/Packages) is configured multiple times in /etc/apt/sources.list:44 and /etc/apt/sources.list:58 #23 19.24 W: Target Packages (universe/binary-all/Packages) is configured multiple times in /etc/apt/sources.list:46 and /etc/apt/sources.list:59 #23 19.24 W: Target Packages (multiverse/binary-all/Packages) is configured multiple times in /etc/apt/sources.list:48 and /etc/apt/sources.list:60 #23 ERROR: process "/bin/sh -c apt-get update" did not complete successfully: exit code: 100
#9 [linux/amd64 2/31] RUN apt-get update #9 39.27 Get:16 http://archive.ubuntu.com/ubuntu focal-updates/main amd64 Packages [3553 kB]
#9 CANCELED
> [linux/arm64 16/31] RUN apt-get update: 19.24 W: Target Packages (universe/binary-all/Packages) is configured multiple times in /etc/apt/sources.list:16 and /etc/apt/sources.list:54 19.24 W: Target Packages (multiverse/binary-all/Packages) is configured multiple times in /etc/apt/sources.list:26 and /etc/apt/sources.list:56 19.24 W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list:34 and /etc/apt/sources.list:57 19.24 W: Target Packages (restricted/binary-all/Packages) is configured multiple times in /etc/apt/sources.list:34 and /etc/apt/sources.list:57 19.24 W: Target Packages (universe/binary-all/Packages) is configured multiple times in /etc/apt/sources.list:34 and /etc/apt/sources.list:57 19.24 W: Target Packages (multiverse/binary-all/Packages) is configured multiple times in /etc/apt/sources.list:34 and /etc/apt/sources.list:57 19.24 W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list:44 and /etc/apt/sources.list:58 19.24 W: Target Packages (restricted/binary-all/Packages) is configured multiple times in /etc/apt/sources.list:44 and /etc/apt/sources.list:58 19.24 W: Target Packages (universe/binary-all/Packages) is configured multiple times in /etc/apt/sources.list:46 and /etc/apt/sources.list:59 19.24 W: Target Packages (multiverse/binary-all/Packages) is configured multiple times in /etc/apt/sources.list:48 and /etc/apt/sources.list:60
WARNING: No output specified with docker-container driver. Build result will only remain in the build cache. To push result image into registry use --push or to load image into docker use --load Dockerfile:31
29 | RUN echo "deb [arch=arm64] http://ports.ubuntu.com/ubuntu-ports focal-security multiverse" >> /etc/apt/sources.list 30 |
31 | >>> RUN apt-get update 32 | # Set environment variables to avoid interactive prompts during installation 33 | ENV DEBIAN_FRONTEND=noninteractive
ERROR: failed to solve: process "/bin/sh -c apt-get update" did not complete successfully: exit code: 100
What I am missing here?
Update 1
I forgot to tell that I was able to successfully build the image for the same architecture as my laptop (x86/x64 or amd64) with command:
docker build . --no-cache --progress plain -t mytag
The issue started when I tried to build for arm64 / multi-architecture.
Update 2
I tried by commenting lines corresponding to 404 error:
# RUN echo "deb [arch=arm64] http://ports.ubuntu.com/ubuntu-ports focal main restricted" >> /etc/apt/sources.list
# RUN echo "deb [arch=arm64] http://ports.ubuntu.com/ubuntu-ports focal-updates multiverse" >> /etc/apt/sources.list
# RUN echo "deb [arch=arm64] http://ports.ubuntu.com/ubuntu-ports focal-backports main restricted universe multiverse" >> /etc/apt/sources.list
# RUN echo "deb [arch=arm64] http://ports.ubuntu.com/ubuntu-ports focal-security multiverse" >> /etc/apt/sources.list
But still same error.
This was expected, as the 404 is occuring for amd64 packages and not arm64 packages:
But I am guessing why it is failing for amd64 packages as it used to successfully build the image before I added changes for arm64.
RajS
  • 183
