sudo apt install nvidia-driver-535
 nvidia-driver-535 : Depends: libnvidia-compute-535 (= 535.104.12-0ubuntu1) but 535.113.01-0ubuntu0.22.04.3 is to be installed
                     Depends: libnvidia-extra-535 (= 535.104.12-0ubuntu1) but 535.113.01-0ubuntu0.22.04.3 is to be installed
                     Depends: libnvidia-decode-535 (= 535.104.12-0ubuntu1) but 535.113.01-0ubuntu0.22.04.3 is to be installed
                     Depends: libnvidia-encode-535 (= 535.104.12-0ubuntu1) but 535.113.01-0ubuntu0.22.04.3 is to be installed
                     Depends: xserver-xorg-video-nvidia-535 (= 535.104.12-0ubuntu1) but 535.113.01-0ubuntu0.22.04.3 is to be installed
                     Depends: libnvidia-cfg1-535 (= 535.104.12-0ubuntu1) but 535.113.01-0ubuntu0.22.04.3 is to be installed
                     Depends: libnvidia-fbc1-535 (= 535.104.12-0ubuntu1) but 535.113.01-0ubuntu0.22.04.3 is to be installed
                     Recommends: nvidia-settings but it is not going to be installed
                     Recommends: nvidia-prime (>= 0.8) but it is not going to be installed
                     Recommends: libnvidia-compute-535:i386 (= 535.104.12-0ubuntu1)
                     Recommends: libnvidia-decode-535:i386 (= 535.104.12-0ubuntu1)
                     Recommends: libnvidia-encode-535:i386 (= 535.104.12-0ubuntu1)
                     Recommends: libnvidia-fbc1-535:i386 (= 535.104.12-0ubuntu1)
E: Unable to correct problems, you have held broken packages.```
karel
  • 122,292
  • 133
  • 301
  • 332
Before the update, you need to clear old nvidia file from your system, which requires a reboot. Then, force-install the packages needed. Finally, install the driver as intended.
Run these with sudo, not as root!
1. Purge nvidia-*
sudo apt purge nvidia-*
sudo apt update
sudo reboot
2. Force install dependencies and fix
sudo apt install -y libnvidia-fbc1-535 libnvidia-cfg1-535 xserver-xorg-video-nvidia-535 libnvidia-encode-535 libnvidia-decode-535 libnvidia-extra-535 libnvidia-compute-535
sudo apt --fix-broken install
3. Install driver
sudo apt install -y nvidia-driver-535
Reboot one last time, and you should be golden.
Artur Meinild
  • 31,035
No-one
  • 360
You first must purge existing nvidia driver. lets say you have nvidia-driver-470
  1. Run sudo apt purge nvidia-driver-470. You also need to purge all nvidia stuff related to that driver 470
  2. Install dkms using apt
  3. Run sudo apt update
  4. Restart your PC
  5. Run sudo apt install nvidia-driver-535
Ask me more if you still have any problems!
Improving @noone answer above, this worked for me:
  1. Purge nvidia-*
    sudo apt update
    sudo reboot
  2. Install the exact required version:
    sudo apt libnvidia-compute-535=535.104.12-0ubuntu1
  3. Force install dependencies and fix
  4. Install driver
Edit: If the error persists due to dependencies keep installing the specific versions for each package until you have success. gdebi will list them on by one, always printing the first unmet dependency. apt will print all, so you have to be carefull to install all of the dependencies (almost 10).
