So when I installed Ubuntu server (with i3 afterwards), I setup my wifi and everything went well. After the install, my laptop would automatically connect to my wifi.
My issue is, I cannot connect to any new wifi connections (or see them) using both TUIs and GUIs (nmcli, nmtui, gnome-network).
But when I use iw and wpa_supplicant I can both see the available wifi devices and connect to them.
sudo iw dev wlp3s0 scan | grep -i ssid
wpa_passphrase SSID PASSWORD > ~/wpa_suppicant.conf
sudo wpa_supplicant -i wlp3s0 -c ~/wpa_supplicant.conf
I isolated it to the fact that my Network Manager sees all my internet connections as unmanaged, this is the output of nmcli device:
DEVICE TYPE STATE CONNECTION
enp0s25 ethernet unmanaged --
lo loopback unmanaged --
wlp3s0 wifi unmanaged --
I tried all the solutions listed in the previous question and none of them worked.
Output of cat /etc/netplan/*.yaml:
cat: /etc/netplan/00-installer-config-wifi.yaml: Permission denied
# This is the network config written by 'subiquity'
network:
ethernets:
enp0s25:
dhcp4: true
version: 2
renderer: NetworkManager
