After running apt dist-upgrade in a root shell in Ubuntu Server 22.04.3, sometimes the question Which services should be restarted? is shown. Example:
Restarting services...
Daemons using outdated libraries
  1. dbus.service 2. getty@tty1.service 3. multipathd.service 4. networkd-dispatcher.service 5. packagekit.service 6. polkit.service 7. ssh.service 8. systemd-logind.service 9. systemd-manager 10. thermald.service 11. unattended-upgrades.service 12. user@1000.service 13. none of the above
(Enter the items or ranges you want to select, separated by spaces.)
Which services should be restarted? 1-13
Which services should be restarted? 1 - 13
Which services should be restarted? 1..13
Which services should be restarted? 1 .. 13
Which services should be restarted? 1...13
Which services should be restarted? 1 ... 13
Which services should be restarted? 1 to 13
Which services should be restarted? 1 2 3 4 5 6 7 8 9 10 11 12 13
Which services should be restarted? 1,2,3,4,5,6,7,8,9,10,11,12,13
The only answer I got working in this prompt was to input a single number, which would only restart that one service and then exit. Example:
/etc/needrestart/restart.d/dbus.service Service restarts being deferred: systemctl restart getty@tty1.service systemctl restart multipathd.service systemctl restart networkd-dispatcher.service systemctl restart packagekit.service systemctl restart polkit.service systemctl restart ssh.service systemctl restart systemd-logind.service /etc/needrestart/restart.d/systemd-manager systemctl restart thermald.service systemctl restart unattended-upgrades.service systemctl restart user@1000.service
No containers need to be restarted.
No user sessions are running outdated binaries.
No VM guests are running outdated hypervisor (qemu) binaries on this host. root@ubuntu-server:~#
How do I answer this prompt to restart all (or a selection of multiple) services?
x-ray
  • 141
Do you realize that option 13 is none of the above? Meaning, it should not be included if you wanted to restart any of the other items?
So just respond with omitting option 13:
or since ranges are also accepted:
Which services should be restarted? 1-12
