Although the podman documentation indicates i should be able to install it into an ubuntu 20.04, i cant:
sudo apt-get install podman
Reading package lists... Done
Building dependency tree
The following packages were automatically installed and are no longer required:
  libevent-dev libevent-extra-2.1-7 libevent-openssl-2.1-7 libhwloc-dev libhwloc-plugins libhwloc15 libpmix2
  libpsm-infinipath1 libpsm2-2 libwireshark13 libwiretap10 libwsutil11 libxnvctrl0 libyajl2
  linux-headers-5.4.0-125 linux-headers-5.4.0-125-generic linux-image-5.4.0-125-generic
  linux-modules-5.4.0-125-generic linux-modules-extra-5.4.0-125-generic ocl-icd-libopencl1
Use 'sudo apt autoremove' to remove them.
The following additional packages will be installed:
  catatonit conmon containernetworking-plugins dns-root-data dnsmasq-base fuse-overlayfs fuse3 libfuse3-3
  podman-machine-cni podman-plugins slirp4netns
The following packages will be REMOVED:
  fuse
The following NEW packages will be installed:
  catatonit conmon containernetworking-plugins dns-root-data dnsmasq-base fuse-overlayfs fuse3 libfuse3-3 podman
0 upgraded, 12 newly installed, 1 to remove and 15 not upgraded.
Need to get 2937 kB/30.1 MB of archives.
After this operation, 148 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 https://provo-mirror.opensuse.org/repositories/devel:/kubic:/libcontainers:/stable/xUbuntu_20.04  podman-plugins 100:1.2.0-1 [1116 kB]
Err:1 https://provo-mirror.opensuse.org/repositories/devel:/kubic:/libcontainers:/stable/xUbuntu_20.04  podman-plugins 100:1.2.0-1
  File has unexpected size (1034528 != 1116320). Mirror sync in progress? [IP: 91.193.113.70 443]
  Hashes of expected file:
   - SHA256:49e09a6ff2b0b827ddc0d830edd160b4ec03875a3f8c8195bfd53b7867fd0b22
   - SHA1:44470e9d5c4b64f1602d3a82f1b28e400e16796c [weak]
   - MD5Sum:d5cc530c789e0fc256ecc02603ff9685 [weak]
   - Filesize:1116320 [weak]
Get:2 https://provo-mirror.opensuse.org/repositories/devel:/kubic:/libcontainers:/stable/xUbuntu_20.04  podman-machine-cni 100:0.0.0-1 [1821 kB]
Err:2 https://provo-mirror.opensuse.org/repositories/devel:/kubic:/libcontainers:/stable/xUbuntu_20.04  podman-machine-cni 100:0.0.0-1
  File has unexpected size (1639592 != 1820908). Mirror sync in progress? [IP: 91.193.113.70 443]
   - SHA256:a55aece52bf91eca31468c2ee3fda0dd8747d9619e6d327731ab9336c5e73185
   - SHA1:04d302c1f0143f8f2c4f7244a3d58e8e5a4f222e [weak]
   - MD5Sum:7972b09bf0a15658d711d55f5f295b45 [weak]
   - Filesize:1820908 [weak]
E: Failed to fetch https://provo-mirror.opensuse.org/repositories/devel:/kubic:/libcontainers:/stable/xUbuntu_20.04/amd64/podman-plugins_1.2.0-1_amd64.deb  File has unexpected size (1034528 != 1116320). Mirror sync in progress? [IP: 91.193.113.70 443]
E: Failed to fetch https://provo-mirror.opensuse.org/repositories/devel:/kubic:/libcontainers:/stable/xUbuntu_20.04/amd64/podman-machine-cni_0.0.0-1_amd64.deb  File has unexpected size (1639592 != 1820908). Mirror sync in progress? [IP: 91.193.113.70 443]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
I tried sudo apt-get update --fix-missing, also tried this, this and this and the result is the same.
I also opened up this issue but im not sure if the problem is with podman, ubuntu or myself.
Am i doing something wrong?
Turns out i had an unstable repo in my /etc/apt/sources.list.d:
https://download.opensuse.org/repositories/devel:/kubic:/libcontainers:/unstable/xUbuntu_22.04/
Im also used a version of crun that conflicted with that actually used by podman. Removing it from /etc/apt/sources.list.d, calling apt-update and removing and reinstalling podman slved the issue.
Try this 'Kubic' repository:
Step 1: Add the "Kubic" repository, which provides additional packages for the Podman container engine:
. /etc/os-release
sudo sh -c "echo 'deb http://download.opensuse.org/repositories/devel:/kubic:/libcontainers:/stable/xUbuntu_${VERSION_ID}/ /' > /etc/apt/sources.list.d/devel:kubic:libcontainers:stable.list"
Step 2: Add the GPG key and verify the package integrity:
wget -nv https://download.opensuse.org/repositories/devel:kubic:libcontainers:stable/xUbuntu_${VERSION_ID}/Release.key -O- | sudo apt-key add -
Step 3: Update the package list:
sudo apt update
Step 4: and finally install Podman:
udo apt -y install podman
