Laptop is an Acer Aspire V3-772 with 8GB and Ubuntu 22.04.3 LTS, Gnome 42.9 & Wayland on UEFI
My friends laptop suffers from shutdown problems and I wanted to take a look at the previous boot.log to see what caused the shutdown, but there is only 1 boot.log file showing when I ask for the logs with ls /var/log and that is the current boot.log.
auth.log  boot.log  btmp  cups  dmesg  gdm3  gpu-manager.log  journal  kern.log  lastlog  private  syslog  ubuntu-advantage.log  unattended-upgrades  wtmp
And when taking a look at journals:
$ /var/log/journal
$ ls
9be0c0a693aa409aa7b4e30f37396627
this also results in just one (the current) journal.
I do not know if the situation has ever be different, i.e. if older log files were retained once, maybe the system always behaved in this manner.
I learned that the behavior of logs depends on logrotate.conf, so here I give its content.
The result of sudo nano /etc/logrotate.conf is pretty standard I guess:
# global options do not affect preceding include directives
rotate log files weekly
weekly
use the adm group by default, since this is the owning group
of /var/log/syslog.
su root adm
keep 4 weeks worth of backlogs
rotate 4
create new (empty) log files after rotating old ones
create
use date as a suffix of the rotated file
#dateext
uncomment this if you want your log files compressed
#compress
packages drop log rotation information into this directory
include /etc/logrotate.d
system-specific logs may also be configured here.
I am not sure if the following errors which are marked as important in the current log might be related, but here they are:
ACPI Error: Aborting method _SB.PCI0.PEG0.PEGP.DD02._BCL due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
ACPI BIOS Error (bug): Could not resolve symbol [_SB.PCI0.GFX0.DD02._BCL], AE_NOT_FOUND (20210730/psargs-330)
Can't chdir to /var/spool/anacron: No such file or directory
Timed out waiting for device /sys/devices/virtual/misc/vmbus!hv_kvp.
Failed to start Application launched by gnome-session-binary.
I looked everywhere for information on missing log files, but to no avail. How this could have happened, why are the older log files, older than the current, missing?
EDIT:
I have read that in cases that only the current log can be viewed, there is no directory journal in /etc/var/ and should be created, OR that in /etc/systemd/journald.conf the option storage = persistent should be set which would cause the directory journal to be created, thus solving the problem.
But because in my system the journal directory already exists and setting storage = persistent did not make any difference, I wonder if it is safe to try to delete the journal directory and let it be created through the mechanism that should result from having storage = persistent been set.
Maybe when created in that automatic way this will result in a system with persistent logs?
plopper
  • 169
