I bought a USB lamp that I want to turn ON/OFF using commands (my purpose is to setup some CRON jobs to turn it ON at certain times).
I researched several answers, but none worked.
I tried outputting to /sys/bus/usb/drivers/usb/unbind, /sys/bus/usb/devices/usb1/power/level, the uhubctl tool, using all USB ports including ports in a USB Hub, etc. Nothing worked.
The lamp is a dumb device, it simply gets turned ON when plugging it to the port.
My PC is MouseComputer Co.,Ltd. MB-R500.
The lamp is this one.
lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 22.04.3 LTS
Release: 22.04
Codename: jammy
sudo lsusb
Bus 002 Device 004: ID 2109:0813 VIA Labs, Inc. VL813 Hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 123: ID 13d3:56af IMC Networks USB2.0 HD UVC WebCam
Bus 001 Device 121: ID 0bda:0129 Realtek Semiconductor Corp. RTS5129 Card Reader Controller
Bus 001 Device 119: ID 2808:9338 Focal-systems.Corp FT9201Fingerprint.Ěš
Bus 001 Device 054: ID 19d2:1405 ZTE WCDMA Technologies MSM ZTE Technologies MSM
Bus 001 Device 053: ID 046d:c52b Logitech, Inc. Unifying Receiver
Bus 001 Device 052: ID 046d:c548 Logitech, Inc. USB Receiver
Bus 001 Device 051: ID 2109:2813 VIA Labs, Inc. VL813 Hub
Bus 001 Device 125: ID 8087:0aaa Intel Corp. Bluetooth 9460/9560 Jefferson Peak (JfP)
sudo uhubctl
Current status for hub 2-2 [2109:0813 VIA Labs, Inc. USB3.0 Hub, USB 3.00, 4 ports, ppps]
Port 1: 02a0 power 5gbps Rx.Detect
Port 2: 02a0 power 5gbps Rx.Detect
Port 3: 02a0 power 5gbps Rx.Detect
Port 4: 02a0 power 5gbps Rx.Detect
Current status for hub 1-2 [2109:2813 VIA Labs, Inc. USB2.0 Hub, USB 2.10, 4 ports, ppps]
Port 1: 0100 power
Port 2: 0103 power enable connect [046d:c548 Logitech USB Receiver]
Port 3: 0103 power enable connect [046d:c52b Logitech USB Receiver]
Port 4: 0503 power highspeed enable connect [19d2:1405 ZTE,Incorporated ZTE Technologies MSM MF9751ZTED000000]
This is a fragment of lsusb -v output, then searched for Anker which is the name of my HUB.
Bus 001 Device 068: ID 291a:8365 Anker Anker USB-C Hub Device
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.01
bDeviceClass 17
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x291a
idProduct 0x8365
bcdDevice 0.01
iManufacturer 1 Anker
iProduct 2 Anker USB-C Hub Device
iSerial 3 0000000000000001
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 0x0012
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 3 0000000000000001
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 100mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 0
bInterfaceClass 17
bInterfaceSubClass 0
bInterfaceProtocol 0
iInterface 3 0000000000000001
