Good afternoon dear friends,
The goal: -> Change i2c clock frequency to 400kHz
The motivation: -> Trying to use Adafruit BNO085 via i2c and there are known issues with rpi i2c clock stretching. (This is a known bug, has been going around since 2012. Yeah!)
What have I tried: I have spent a good two days reading into this topic and attempting multiple times to change the i2c clock frequency on my raspberry pi 4b running Ubuntu 22.04 Server (headless).
since I don't use rasbian I can NOT just edit a line in my boot-config file. But rather I have to disassemble, modify and recompile a device-tree file.
Followed this tutorial: Enable SPI and I2C on Ubuntu 20.04 Raspberry Pi
Applied to this file:
/boot/dtbs/5.15.0-1033-raspi/bcm2711-rpi-4-b.dtb
used this command to disassemble:
dtc -I dtb -O dts -o bcm2711-rpi-4-b.dts /boot/dtbs/5.15.0-1033-raspi/bcm2711-rpi-4-b.dtb
Then I modified these areas in that .dts (device-tree-source)
in the following two code chunks I replaced
clock-frequency = <0x186a0>; // 100000
with
clock-frequency = <0x61a80>; // 400000
Block 1
i2c@7e205000 {
compatible = "brcm,bcm2711-i2c\0brcm,bcm2835-i2c";
reg = <0x7e205000 0x200>;
interrupts = <0x00 0x75 0x04>;
clocks = <0x08 0x14>;
#address-cells = <0x01>;
#size-cells = <0x00>;
status = "disabled";
#clock-frequency = <0x186a0>; // 100000
phandle = <0x10>;
and also Block 2
i2c@7e804000 {
reg = <0x7e804000 0x1000>;
pinctrl-names = "default";
pinctrl-0 = <0x18>;
phandle = <0x36>;
Further down I modified the following code Block:
#i2c1_baudrate = "\0\0\06clock-frequency:0"; // modified this
i2c1_baudrate = "\0\0\06clock-frequency:400000"; // modified this
Here the entire overrides Block
__overrides__ {
cam0-pwdn-ctrl;
cam0-pwdn;
cam0-led-ctrl;
cam0-led;
krnbt = "\0\0\00status";
krnbt_baudrate = "\0\0\00max-speed:0";
cache_line_size;
uart0 = "\0\0\01status";
uart1 = "\0\0\02status";
i2s = "\0\0\03status";
spi = "\0\0\04status";
i2c0 = [00 00 00 10 73 74 61 74 75 73 00 00 00 00 35 73 74 61 74 75 73 00];
i2c1 = "\0\0\06status";
i2c0_baudrate = [00 00 00 10 63 6c 6f 63 6b 2d 66 72 65 71 75 65 6e 63 79 3a 30 00];  // left this alone
audio = "\0\0\07status";
watchdog = "\0\0\08status";
random = "\0\0\09status";
sd_overclock = "\0\0\0:brcm,overclock-50:0";
sd_force_pio = "\0\0\0:brcm,force-pio?";
sd_pio_limit = "\0\0\0:brcm,pio-limit:0";
sd_debug = "\0\0\0:brcm,debug";
sdio_overclock = "\0\0\0;brcm,overclock-50:0\0\0\0\0<brcm,overclock-50:0";
axiperf = "\0\0\0=status";
arm_freq;
act_led_gpio = "\0\0\0>gpios:4";
act_led_activelow = "\0\0\0>gpios:8";
act_led_trigger = "\0\0\0>linux,default-trigger";
pwr_led_gpio = "\0\0\0?gpios:4";
pwr_led_activelow = "\0\0\0?gpios:8";
pwr_led_trigger = "\0\0\0?linux,default-trigger";
eth_led0 = "\0\0\0/led-modes:0";
eth_led1 = "\0\0\0/led-modes:4";
sd_poll_once = "\0\0\0@non-removable?";
spi_dma4 = <0x34 0x646d6173 0x3a303d00 0x41 0x34 0x646d6173 0x3a383d00 0x41>;
after that I re-compiled the .dts file back into .dtb using this command:
dtc -I dts -O dtb -o bcm2711-rpi-4-b.dtb bcm2711-rpi-4-b.dts
and then copied the file back into the directory where it was originally found and overwrote the existing file. Of course I have a backup.
sudo cp bcm2711-rpi-4-b.dtb /boot/dtbs/5.15.0-1033-raspi/bcm2711-rpi-4-b.dtb
But it still does not work. When executing the python test file from Adafruit I get the following error:
python3 imu_v2.py
    ********** Packet *************
DBG:: HEADER: DBG:: Data Len: 17 DBG:: Channel: CONTROL (2) DBG:: ** UNKNOWN Report Type **: 0x7c DBG:: Sequence number: 19
DBG:: Data: DBG:: [0x04] 0x7C 0x05 0x00 0x00 DBG:: [0x08] 0x00 0x50 0xC3 0x00 DBG:: [0x0C] 0x00 0x00 0x00 0x00 DBG:: [0x10] 0x00 0x00 0x00 0x00 DBG:: [0x14] 0x00 *******************************
Traceback (most recent call last): File "/home/administrator/Documents/raspberrypi_software/python/src/imu_v2.py", line 19, in <module> bno.enable_feature(BNO_REPORT_ROTATION_VECTOR) File "/home/administrator/.local/lib/python3.10/site-packages/adafruit_bno08x/init.py", line 999, in enable_feature self._process_available_packets(max_packets=10) File "/home/administrator/.local/lib/python3.10/site-packages/adafruit_bno08x/init.py", line 803, in _process_available_packets self._handle_packet(new_packet) File "/home/administrator/.local/lib/python3.10/site-packages/adafruit_bno08x/init.py", line 863, in _handle_packet raise error File "/home/administrator/.local/lib/python3.10/site-packages/adafruit_bno08x/init.py", line 858, in _handle_packet _separate_batch(packet, self._packet_slices) File "/home/administrator/.local/lib/python3.10/site-packages/adafruit_bno08x/init.py", line 373, in _separate_batch required_bytes = _report_length(report_id) File "/home/administrator/.local/lib/python3.10/site-packages/adafruit_bno08x/init.py", line 362, in _report_length return _AVAIL_SENSOR_REPORTS[report_id][2] KeyError: 124
This is the program I'm trying to run, which according to adafruit documentation will require the i2c-clock-frequency to be at 400kHz.
import time
import board
import busio
from adafruit_bno08x import (
    BNO_REPORT_ACCELEROMETER,
    BNO_REPORT_GYROSCOPE,
    BNO_REPORT_MAGNETOMETER,
    BNO_REPORT_ROTATION_VECTOR,
from adafruit_bno08x.i2c import BNO08X_I2C
i2c = busio.I2C(board.SCL, board.SDA, frequency=400000) #i2c = busio.I2C(board.SCL, board.SDA, frequency=100000) bno = BNO08X_I2C(i2c)
bno.enable_feature(BNO_REPORT_ACCELEROMETER) bno.enable_feature(BNO_REPORT_GYROSCOPE) bno.enable_feature(BNO_REPORT_MAGNETOMETER) bno.enable_feature(BNO_REPORT_ROTATION_VECTOR)
while True: time.sleep(0.5)
imu_data = {}
accel_x, accel_y, accel_z = bno.acceleration  # pylint:disable=no-member
imu_data[&quot;linear_acceleration&quot;] = {&quot;x&quot;: accel_x, &quot;y&quot;: accel_y, &quot;z&quot;: accel_z}
gyro_x, gyro_y, gyro_z = bno.gyro  # pylint:disable=no-member
imu_data[&quot;angular_velocity&quot;] = {&quot;x&quot;: gyro_x, &quot;y&quot;: gyro_y, &quot;z&quot;: gyro_z}
mag_x, mag_y, mag_z = bno.magnetic  # pylint:disable=no-member
imu_data[&quot;magnetic_field&quot;] = {&quot;x&quot;: mag_x, &quot;y&quot;: mag_y, &quot;z&quot;: mag_z}
quat_i, quat_j, quat_k, quat_real = bno.quaternion  # pylint:disable=no-member
imu_data[&quot;orientation&quot;] = {&quot;x&quot;: quat_i, &quot;y&quot;: quat_j, &quot;z&quot;: quat_k, &quot;w&quot;: quat_real}
# Populate the 3x3 covariance matrices with zeros (assuming no covariance)
imu_data[&quot;orientation_covariance&quot;] = [0.0] * 9
imu_data[&quot;angular_velocity_covariance&quot;] = [0.0] * 9
imu_data[&quot;linear_acceleration_covariance&quot;] = [0.0] * 9
print(imu_data)
print(&quot;&quot;)
And yes, I tried with both 100000 and 400000 as you can see in the script.
And here the output it produces, before it crashes and produces an error-trace, which can be found further down. Please note the output is heavily redacted due to repetitive information. Usually runs for about 10-15s before crashing. Could be some buffer filling up?
administrator@hostname:~/Documents/raspberrypi_software/python/src$ python3 imu_v2.py
{'linear_acceleration': {'x': 0.3046875, 'y': -0.11328125, 'z': 9.578125}, 'angular_velocity': {'x': 0.001953125, 'y': 0.0, 'z': 0.0}, 'magnetic_field': {'x': -4.0, 'y': -9.5625, 'z': 54.4375}, 'orientation': {'x': -0.005615234375, 'y': -0.01409912109375, 'z': 0.0001220703125, 'w': 0.9998779296875}, 'orientation_covariance': [0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0], 'angular_velocity_covariance': [0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0], 'linear_acceleration_covariance': [0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0]}
{'linear_acceleration': {'x': 0.26953125, 'y': -0.11328125, 'z': 9.58203125}, 'angular_velocity': {'x': 0.0, 'y': 0.0, 'z': 0.0}, 'magnetic_field': {'x': -4.75, 'y': -11.375, 'z': 49.75}, 'orientation': {'x': -0.00567626953125, 'y': -0.01416015625, 'z': 6.103515625e-05, 'w': 0.9998779296875}, 'orientation_covariance': [0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0], 'angular_velocity_covariance': [0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0], 'linear_acceleration_covariance': [0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0]}
<data ommited> Large chunk of data ommited due to character limit </data ommited>
{'linear_acceleration': {'x': 0.3046875, 'y': -0.15234375, 'z': 9.578125}, 'angular_velocity': {'x': 0.0, 'y': 0.0, 'z': 0.0}, 'magnetic_field': {'x': -4.0, 'y': -9.9375, 'z': 54.1875}, 'orientation': {'x': -0.0064697265625, 'y': -0.015380859375, 'z': -6.103515625e-05, 'w': 0.9998779296875}, 'orientation_covariance': [0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0], 'angular_velocity_covariance': [0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0], 'linear_acceleration_covariance': [0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0]}
And finally the error trace that appears after 10-15s of above output:
DBG::        HEADER:
DBG::        Data Len: 191
DBG::        Channel: INPUT_SENSOR_REPORTS (3)
DBG::           Report Type: BASE_TIMESTAMP (0xfb)
DBG::           Sensor Report Type: ACCELEROMETER(0x1)
DBG::        Sequence number: 87
DBG:: Data: DBG:: [0x04] 0xFB 0xFB 0x12 0x00 DBG:: [0x08] 0x00 0x01 0xE1 0x02 DBG:: [0x0C] 0x00 0x45 0x00 0xE3 DBG:: [0x10] 0xFF 0x95 0x09 0x03 DBG:: [0x14] 0xD1 0x00 0x16 0xB4 DBG:: [0x18] 0xFF 0x56 0xFF 0x44 DBG:: [0x1C] 0x03 0x05 0xD0 0x00 DBG:: [0x20] 0x7A 0x99 0xFF 0x00 DBG:: [0x24] 0xFF 0x00 0x00 0x7E DBG:: [0x28] 0xBF 0x44 0x32 0x01 DBG:: [0x2C] 0xE2 0x06 0x3D 0x4E DBG:: [0x30] 0x00 0xE3 0xFF 0x94 DBG:: [0x34] 0x09 0x02 0xD2 0x04 DBG:: [0x38] 0x3F 0x00 0x00 0x00 DBG:: [0x3C] 0x00 0x00 0x00 0x03 DBG:: [0x40] 0xD2 0x08 0x0B 0xBA DBG:: [0x44] 0xFF 0x56 0xFF 0x2B DBG:: [0x48] 0x03 0x05 0xD1 0x08 DBG:: [0x4C] 0x6F 0x98 0xFF 0x00 DBG:: [0x50] 0xFF 0x00 0x00 0xFE DBG:: [0x54] 0x3F 0x44 0x32 0x01 DBG:: [0x58] 0xE3 0x0A 0x78 0x4E DBG:: [0x5C] 0x00 0xD9 0xFF 0x94 DBG:: [0x60] 0x09 0x02 0xD3 0x0C DBG:: [0x64] 0x37 0x00 0x00 0x00 DBG:: [0x68] 0x00 0x00 0x00 0x01 DBG:: [0x6C] 0xE4 0x0E 0xB6 0x45 DBG:: [0x70] 0x00 0xE3 0xFF 0x95 DBG:: [0x74] 0x09 0x03 0xD3 0x10 DBG:: [0x78] 0x00 0xBA 0xFF 0x5B DBG:: [0x7C] 0xFF 0x38 0x03 0x05 DBG:: [0x80] 0xD2 0x10 0x63 0x98 DBG:: [0x84] 0xFF 0x00 0xFF 0x00 DBG:: [0x88] 0x00 0xFE 0x3F 0x44 DBG:: [0x8C] 0x32 0x01 0xE5 0x12 DBG:: [0x90] 0xF7 0x4E 0x00 0xE3 DBG:: [0x94] 0xFF 0x8A 0x09 0x02 DBG:: [0x98] 0xD4 0x14 0x2C 0x00 DBG:: [0x9C] 0x00 0x00 0x00 0x00 DBG:: [0xA0] 0x00 0x03 0xD4 0x14 DBG:: [0xA4] 0xF4 0xB4 0xFF 0x5B DBG:: [0xA8] 0xFF 0xB1 0x03 0x01 DBG:: [0xAC] 0xE6 0x1A 0x36 0x4E DBG:: [0xB0] 0x00 0xE3 0xFF 0x94 DBG:: [0xB4] 0x04 0xFF 0xFF 0xFF DBG:: [0xB8] 0xFF 0xFF 0xFF 0xFF DBG:: [0xBC] 0xFF 0xFF 0xFF 0xFF DBG:: [0xC0] 0xFF 0xFF 0xFF *******************************
Traceback (most recent call last): File "/home/administrator/Documents/raspberrypi_software/python/src/imu_v2.py", line 26, in <module> accel_x, accel_y, accel_z = bno.acceleration # pylint:disable=no-member File "/home/administrator/.local/lib/python3.10/site-packages/adafruit_bno08x/init.py", line 598, in acceleration self._process_available_packets() File "/home/administrator/.local/lib/python3.10/site-packages/adafruit_bno08x/init.py", line 803, in _process_available_packets self._handle_packet(new_packet) File "/home/administrator/.local/lib/python3.10/site-packages/adafruit_bno08x/init.py", line 863, in _handle_packet raise error File "/home/administrator/.local/lib/python3.10/site-packages/adafruit_bno08x/init.py", line 858, in _handle_packet _separate_batch(packet, self._packet_slices) File "/home/administrator/.local/lib/python3.10/site-packages/adafruit_bno08x/init.py", line 373, in _separate_batch required_bytes = _report_length(report_id) File "/home/administrator/.local/lib/python3.10/site-packages/adafruit_bno08x/init.py", line 364, in _report_length return _REPORT_LENGTHS[report_id] KeyError: 255
Not sure what I'm missing. At this point I'm still not sure if my bus has actually changed clock-frequency. Does anyone know:
  1. how to check the clock-frequency of i2c on rpi 4b running Ubuntu 22.04 (NOT raspbian)
  2. what I am missing, what's wrong here?
I was able to solve this problem and wanted to post the solution, for anyone else who:
  1. has a raspberry pi running Ubuntu
  2. needs to change the i2c clock speed (from 100000 to 400000)
After this excursion into dts and dtb it was decided to simply use dt-overlays.
First I created a new file "i2c1-frequency-overlay.dts"
// i2c1-frequency-overlay.dts
/dts-v1/;
/plugin/;
    compatible = "brcm,bcm2711";
    fragment@0 {
        target = <&i2c1>;
        __overlay__ {
            clock-frequency = <400000>; // Set your desired frequency here (e.g., 400 kHz)
Second I compiled this file using:
dtc -I dts -O dtb -o i2c1-frequency-overlay.dtbo i2c1-frequency-overlay.dts
This created the dtb file
which then was copied to /boot/firmware/overlays/
sudo cp i2c1-frequency-overlay.dtbo /boot/firmware/overlays/
Next I modified /boot/firmware/config.txt
sudo nano /boot/firmware/config.txt
and appended the following:
# Added below to change i2c frequency from 100kHz [default] to 400kHz [fast mode]
dtparam=i2c_arm_baudrate=400000
dtoverlay=i2c1-frequency-overlay
Last step reboot
sudo reboot
Just to verify the i2c clock frequency updated:
// this did not work:
cat /sys/class/i2c-adapter/i2c-1/of_node/clock-frequency
did some more research and found the following
// but this worked
echo 0x$(xxd /sys/class/i2c-adapter/i2c-1/of_node/clock-frequency | cut -f 2,3 -d ' ' --output-delimiter='') | xargs printf "%d\n"
-bash: warning: command substitution: ignored null byte in input
400000
-> this confirms the bus is at 400kHz :-)
