I have downloaded and installed lubuntu-22.04.3-desktop-amd64 onto my old Dell Inspiron 1501 laptop, upgraded to run with 2GB RAM. This is a 64-bit machine with its original 80GB HD and is working fine in all other respects. I have also run a lens cleaner CD.
If I insert a DVD and attempt to open and then run it in VLC, the laptop and VLC recognize the DVD, but VLC then opens it and immediately terminates and disappears off the Desktop.
If I insert an audio CD and then run it, the laptop and VLC recognise and play the CD normally.
I have upgraded the VLC app', as bundled with Lubuntu, by running:
sudo apt-get install ubuntu-restricted-extras
sudo /usr/share/doc/libdvdread4/install-css.sh (which didn't run)
sudo apt-get install libdvd-pkg
sudo apt install libdvd-pkg && sudo dpkg-reconfigure libdvd-pkg.
However, the DVD just 'crashes' the VLC app' every time.
Any suggestions please?
Thank you.
Robin.
Term Window Output as Suggested:
rharwood@Inspiron1501:~$ vlc
VLC media player 3.0.16 Vetinari (revision 3.0.13-8-g41878ff4f2)
[0000556f4139a580] main libvlc: Running vlc with the default interface. Use 'cvlc' to use vlc without interface.
Icon theme "elementary" not found.
Icon theme "breeze" not found.
[0000556f4143aca0] main playlist: playlist is empty
[00007f5354006a20] dvdnav demux: DVD Title: Casino Royale
[00007f5354006a20] dvdnav demux: DVD Serial Number: 36368886
[00007f5354006a20] dvdnav demux: DVD Title (Alternative): Casino Royale
[00007f5354006a20] dvdnav demux: DVD disk reports itself with Region mask 0x00ed0000. Regions: 02 05
[00007f5354006a20] dvdnav demux: Attempting to retrieve all CSS keys
[00007f5354006a20] dvdnav demux: This can take a _long_ time, please be patient
[00007f5354006a20] dvdnav demux error: Zero check failed in src/ifo_read.c:862 for cell_position[i].zero_1 : 0x04
[00007f5354006a20] dvdnav demux error: Zero check failed in src/ifo_read.c:862 for cell_position[i].zero_1 : 0x05
... 2000 char's removed ...
[00007f5354006a20] dvdnav demux error: Zero check failed in src/ifo_read.c:862 for cell_position[i].zero_1 : 0x06
[0000556f4146d0f0] main audio output error: too low audio sample frequency (0)
[00007f53541efee0] main decoder error: failed to create audio output
[0000556f4146d0f0] vlcpulse audio output error: digital pass-through stream connection failure: Not supported
[0000556f4146d0f0] main audio output error: module not functional
[00007f5388011a40] gl gl: Initialized libplacebo v4.192.1 (API v192)
libva info: VA-API version 1.14.0
libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/r300_drv_video.so
libva info: va_openDriver() returns -1
[00007f5388011a40] glconv_vaapi_x11 gl error: vaInitialize: unknown libva error
libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/r600_drv_video.so
libva info: Found init function __vaDriverInit_1_14
r300: driver missing
libva error: /usr/lib/x86_64-linux-gnu/dri/r600_drv_video.so init failed
libva info: va_openDriver() returns 2
[00007f5388011a40] glconv_vaapi_drm gl error: vaInitialize: resource allocation failed
[00007f535407fe20] avcodec decoder: Using G3DVL VDPAU Driver Shared Library version 1.0 for hardware decoding
r300: Branches are not supported on R3xx/R4xx.
r300 FP: Cannot translate a shader. Using a dummy shader instead.
Segmentation fault (core dumped)
Thanks, Robin.
