I performed a do-release-upgrade from 20.04 to 22.04 LTS on two machines. Both went through.
Now I see different old packages on them:
apt list --installed | grep 20.04
g++-11/now 11.4.0-2ubuntu1~20.04 amd64 [installed,local]
gcc-11-base/now 11.4.0-2ubuntu1~20.04 amd64 [installed,local]
gcc-11/now 11.4.0-2ubuntu1~20.04 amd64 [installed,local]
gcc-13-base/now 13.1.0-8ubuntu1~20.04.2 amd64 [installed,local]
gcc-13-base/now 13.1.0-8ubuntu1~20.04.2 i386 [installed,local]
libasan6/now 11.4.0-2ubuntu1~20.04 amd64 [installed,local]
libatomic1/now 13.1.0-8ubuntu1~20.04.2 amd64 [installed,local]
libatomic1/now 13.1.0-8ubuntu1~20.04.2 i386 [installed,local]
libcc1-0/now 13.1.0-8ubuntu1~20.04.2 amd64 [installed,local]
libgcc-11-dev/now 11.4.0-2ubuntu1~20.04 amd64 [installed,local]
libgcc-s1/now 13.1.0-8ubuntu1~20.04.2 amd64 [installed,local]
libgcc-s1/now 13.1.0-8ubuntu1~20.04.2 i386 [installed,local]
libgcc1/now 1:13.1.0-8ubuntu1~20.04.2 amd64 [installed,local]
libgomp1/now 13.1.0-8ubuntu1~20.04.2 amd64 [installed,local]
libitm1/now 13.1.0-8ubuntu1~20.04.2 amd64 [installed,local]
liblsan0/now 13.1.0-8ubuntu1~20.04.2 amd64 [installed,local]
libmbim-glib4/jammy-updates,now 1.28.0-1~ubuntu20.04.1 amd64 [installed,automatic]
libmbim-proxy/jammy-updates,now 1.28.0-1~ubuntu20.04.1 amd64 [installed,automatic]
libquadmath0/now 13.1.0-8ubuntu1~20.04.2 amd64 [installed,local]
libstdc++-11-dev/now 11.4.0-2ubuntu1~20.04 amd64 [installed,local]
libstdc++6/now 13.1.0-8ubuntu1~20.04.2 amd64 [installed,local]
libstdc++6/now 13.1.0-8ubuntu1~20.04.2 i386 [installed,local]
libtsan0/now 11.4.0-2ubuntu1~20.04 amd64 [installed,local]
libubsan1/now 13.1.0-8ubuntu1~20.04.2 amd64 [installed,local]
linux-generic-hwe-20.04/jammy-updates,now 5.15.0.83.80 amd64 [installed]
the other machine has far less:
libmbim-glib4/jammy-updates,now 1.28.0-1~ubuntu20.04.1 amd64 [installed]
libmbim-proxy/jammy-updates,now 1.28.0-1~ubuntu20.04.1 amd64 [installed]
linux-generic-hwe-20.04/now 5.15.0.82.91~20.04.40 amd64 [installed,local]
linux-headers-generic-hwe-20.04/now 5.15.0.82.91~20.04.40 amd64 [installed,local]
linux-image-generic-hwe-20.04/now 5.15.0.82.91~20.04.40 amd64 [installed,local]
  1. Is this a problem? I tried to install rstudio and it works on the second machine, but fails on the first due to incompatibilities : sudo apt install -f ./rstudio-2023.06.2-561-amd64.deb gives
The following packages have unmet dependencies: libobjc-11-dev : Depends: gcc-11-base (= 11.4.0-1ubuntu1~22.04) but 11.4.0-2ubuntu1~20.04 is to be installed Depends: libgcc-11-dev (= 11.4.0-1ubuntu1~22.04) but 11.4.0-2ubuntu1~20.04 is to be installed E: Unable to correct problems, you have held broken packages.
So I guess it is a problem at least for the first machine.
  1. How can I fix this? Maybe some old packages can simply be deleted (e.g. unused linux header etc) but how to upgrade gcc etc to 22.04?
