I am finding what it seems a common issue when upgrading Ubuntu versions - a usrmerge fatal error which also prevents the correct symlink assignments.
An indication that there was something wrong with the usrmerge appeared during the Ubuntu version upgrade from 20.04 to 22.04. The Ubuntu upgrade did happen:
ec@ec:~$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 22.04.3 LTS
Release: 22.04
Codename: jammy
but a warning message said that the upgrade was actually incomplete and error-prone, asking me to solve the issue so the upgrade could be fully completed.
I found that the usrmerge was giving problems to everyone.
The most common solution online was to try to updgrade usrmerge. This is an example on what people normally do:
https://bugs.launchpad.net/ubuntu/+source/usrmerge/+bug/1993943/comments/5
However, when I try sudo apt install usrmerge or similar actions onusrmerge, it always throws a fatal error when finding a first discrepancy:
FATAL ERROR:
Both /lib/x86_64-linux-gnu/libcrypto.so.1.0.0 and /usr/lib/x86_64-linux-gnu/libcrypto.so.1.0.0 exist.
You can try correcting the errors reported and running again
/usr/lib/usrmerge/convert-usrmerge until it will complete without errors.
Do not install or update other Debian packages until the program
has been run successfully.
dpkg: error processing package usrmerge (--configure):
installed usrmerge package post-installation script subprocess returned error exit status 1
usrmerge
The error above suggests that the duplicated files are in these two directories:
- /usr/lib/x86_64-linux-gnu/
- /lib/x86_64-linux-gnu/
Then I found out that the same failing directory pattern is associated to two files:
libcrypto.so.1.0.0 and libssl.so.1.0.0 files.
The ones in /usr/lib/x86_64-linux-gnu/ are originals, while the lib*.so.1.0.0's in /lib/x86_64-linux-gnu/ are symlinks of other symlinks:
lrwxrwxrwx 1 root root 11 apr 26 2019 libssl.so.1.0.0 -> libssl.so.6
lrwxrwxrwx 1 root root 42 apr 24 2019 libssl.so.6 -> /usr/local/ampps/extra/lib/libssl.so.1.0.0
The lib*.so.6 are then pointing to duplicated lib*.so.1.0.0 in a different directory which seems to be related to ampps (MySQL dependencies?).
I have found many examples of usrmerge failure with incorrect links and locations but none similar to my problem. What seems to be relevant to all of them is this explanation: https://askubuntu.com/a/1441239/1728935
So, it appears that I should use only one original of the lib*.so.1.0.0 to be used as source of the symlink in the lib sub-directory, but there are other symlinks, the lib*.so.6, sitting right in between that I don“t know how to solve :L. If someone can explain me the safest way to correct this apparent discrepancy so I don't end breaking something else (Disclaimer: I am not linux-expert)?
