14
I wish to write a shell script whereby I could read the file from command and edit the file without manual intervention (based on searching some text and replacing it with another).
I need not use any text editor for this....simply text-searching (like using grep) and then replacing it with some other text and saving the changes....
muru
  • 207,228
5 Answers5
11
That is where sed comes in to play. A sed command has this format:
[pattern1][,pattern2][!] command [args]
It uses regexes so it can/will be a bit difficult. Some basic examples taken from the 2nd link below:
# substitute (find and replace) "foo" with "bar" on each line
sed 's/foo/bar/' # replaces only 1st instance in a line
sed 's/foo/bar/4' # replaces only 4th instance in a line
sed 's/foo/bar/g' # replaces ALL instances in a line
sed 's/\(.*\)foo\(.*foo\)/\1bar\2/' # replace the next-to-last case
sed 's/\(.*\)foo/\1bar/' # replace only the last case
# substitute "foo" with "bar" ONLY for lines which contain "baz"
sed '/baz/s/foo/bar/g'
# substitute "foo" with "bar" EXCEPT for lines which contain "baz"
sed '/baz/!s/foo/bar/g'
# change "scarlet" or "ruby" or "puce" to "red"
sed 's/scarlet/red/g;s/ruby/red/g;s/puce/red/g' # most seds
gsed 's/scarlet\|ruby\|puce/red/g' # GNU sed only
Some references
Rinzwind
  • 309,379
Very late answer. However, this might help others with a similar problem/question.
I would recommend creating and applying a patch. A nice example can be found here.
For example, assuming that a new.txt file contains changes that you want to apply to old.txt. You can execute the commands on a terminal or by creating and executing a patch_file.sh.
Command line: open a terminal and copy and execute the lines below (change the file names as necessary):
diff old.txt new.txt > patch.patch # to create the patch
patch old.txt -i patch.patch -o patched_old.text # to apply patch
Script: using an .sh file approach. In a terminal (keyboard: ctrl+alt+t: gedit patch_file.sh
Copy and paste the commands that would go on the terminal, to the .sh file and below the header as shown below (gedit).
#!/bin/sh
Make the script executable (terminal):
chmod +x patch_file.sh
Run the script (terminal):
./patch_file.sh # may require sudo access depending on the directory affected
muru
  • 207,228
If you want to edit a file, use a file editor, there are command based file editors that can be used from scripts, like ex or ed.
geirha
  • 47,279
You're looking for sed or awk. I find sed to be simpler and awk to be more powerful.
Here's an example from another question.
sed -i 's/gedit.desktop/yournew.desktop/g' /usr/share/applications/defaults.list
This means:
  • search in file /usr/share/applications/defaults.list
  • Find/grep gedit.desktop
  • Replace with yournew.desktop
  • Apply the changes in place -i
muru
  • 207,228
RobotHumans
  • 30,112
Depending on what you need to edit, if you're familiar with vi then ed may be useful.
glenn jackman
  • 18,218
