I have Windows 10 on my HP Elitebook dual-booted with Ubuntu 22.04. The primary partition ofc has windows in it. I have decided to ditch Windows entirely and go with Ubuntu. I would like to know how it can be done without any data loss. Also, while doing this do I need a USB of higher storage? The Windows partition occupies around 222GB of the hard disk
The only way not to have data loss is to have a few good and current backups of your own personal data (Documents, Pictures, ...). If you have this, you are fully covered, and nothing can go wrong whatsoever. Operating systems do not need backup. They can be downloaded all over the place. Your data, however, once lost, is lost forever.
The easiest way for you to proceed (which I do all the time) is to install Ubuntu, having it use the entire disk. Then place your data back and do some configuration. In less than two hours, you will be up and running.
vanadium
  • 97,564
