The instructions that you linked tell you
To install Scala, it is recommended to use cs setup, the Scala installer powered by Coursier.
The same cs program may be used to uninstall the software - as you can verify by invoking its built-in help:
$ ./cs --help
Usage: ./cs <COMMAND>
Coursier is the Scala application and artifact manager.
It can install Scala applications and setup your Scala development environment.
It can also download and cache artifacts from the web.
Install application commands:
install Install an application from its descriptor.
list List all currently installed applications.
setup Setup a machine for Scala development.
uninstall Uninstall one or more applications.
update Update one or more applications.
Application channel commands:
channel Manage additional channels, used by coursier to resolve application descriptors.
search Search application names from known channels.
Java commands:
java Manage installed JVMs and run java.
java-home Print the home directory of a particular JVM.
Launcher commands:
bootstrap Create a binary launcher from a dependency or an application descriptor.
launch Launch an application from a dependency or an application descriptor.
Resolution commands:
fetch Transitively fetch the JARs of one or more dependencies or an application.
resolve Resolve and print the transitive dependencies of one or more dependencies or an application.
Other commands:
version Prints the coursier version
and
$ ./cs uninstall --help
Usage: ./cs uninstall [options] [app-name*]
The given name must be the application executable name, which may differ from the descriptor name.
Examples:
$ cs uninstall amm
$ cs uninstall bloop scalafix
$ cs uninstall --all
Help options:
--usage Print usage and exit
-h, -help, --help Print help message and exit
-help-full, -full-help, --help-full, --full-help Print help message, including hidden options, and exit
Uninstall options:
--dir, --install-dir string?
--all
-q, --quiet Quiet output
-v, --verbose Increase verbosity (specify several times to increase more)
For additional details see the Uninstall section of the coursier documentation
